Old 08-16-2009, 02:51 PM   #1
christianjax
christianjax's Avatar
Drives: 1999 Trans Am
Gear Swap?
Anyone considering a rear gear swap? I would think something around 3.90's would really wake it up and make 6th gear actually usable.
christianjax is offline   Reply With Quote
Old 08-16-2009, 03:13 PM   #2
Drive fast, take chances
Driving Camaros 40 yrs
Drive fast, take chances's Avatar
Drives: 70 Z28/RS, 99 SS, 2010 2SS/RS w/SC
4.10s
I have a 2SS, 6sp manual but I have not changed gears yet. I am looking for a good set of gears for the 2010 that won't whine - be careful of that, design is everything on the gear angle.
However, in my 4th gen SS 6sp manual I swapped in a set of 4.10s. This made the car very friendly to drive in town, the 1/4 mile was reduced by .2 sec, and the mileage on the highway only dropped 1 mpg. RPMs went from ~2,000 at 90mph to 2,000 at 75mph.
When dragging there certainly is quicker shifting required with the 4.10s, but, you're dragging so who cares.
These are Richmond gears and they whine a small amount (I've re-set them about 4 times to get rid of the whine, and it is less, but not totally gone away) - but the rear end housing is so small in the 4th gen I believe there is no alternative to keep the strength required and get more teeth in the housing.
The standard rear gear is a small amount lower in the 2010 but the tires (I got the 21") are way taller - at least 2", the over drive is not quite as steep in the 2010, so in the end the RPMs will probably be real close to what they are in my 4th gen.
Good luck.
Drive fast, take chances is offline   Reply With Quote
Old 08-16-2009, 03:16 PM   #3
christianjax
4.10's would be good. Perhaps a little more aggressive than I would want.
Old 08-16-2009, 03:17 PM   #4
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
I can't wait for some nice 3.73's to come out. Best of both worlds
BigMatt is offline   Reply With Quote
Old 08-16-2009, 03:25 PM   #5
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I also had 4.10's in my 4th gen and loved them. These 5th gens could use a lower gear to get them rolling a little faster.
MODS:
Old 08-16-2009, 03:47 PM   #6
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
Everyone wants gears so far and yet nobody has released any. If I made gears for a living i would get on it and fast. I don't even have my car yet, its en route but I probably looking for 3.90's also from what i've read.
jpsuperman81 is offline   Reply With Quote
Old 08-16-2009, 04:32 PM   #7
GEN-IV
HEMI Hunter
GEN-IV's Avatar
Drives: 06 GTO / 79 Z28
3.90s or 4.10s would be perfect with the SS. The 6-sp makes it a natural! The Challenger gets a 3.92:1 axle and it works out very well.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 08-16-2009, 04:37 PM   #8
jpsuperman81
Yep I'm back!
I don't know much about gears and at first I figured this car would have plenty of power for me coming from a civic si, but everyone has mentioned gears. I originally figured 3.73's would be ok but few people mentioned it better to take to steps up as minimum or your wasting your time. So I definitely hoping for 3.90's.
Old 08-17-2009, 08:21 AM   #9
christianjax
Well from what I'm hearing, 6th is pretty useless unless you're cruising on the highway at 75mph or so. That plus the 20 inch wheels means the Camaro could take at least a 3.90 and still do very well on the highway. Probably loose 1mpg, but you'll pick quite a bit in acceleration.
Old 08-17-2009, 09:44 AM   #10
Gen5SSRS
Gen5SSRS's Avatar
Drives: Black 2010 1SS RS,
I Had 4.10's in my 4th Gen, used the Hyper-tech for the speedo. I was very happy with the setup and did not wish they were a higher or lower ratio.
Gen5SSRS is offline   Reply With Quote
Old 08-17-2009, 11:06 AM   #11
WeeZee
Drives: SuperSport's
based on power to weight & the touque curve 4.10's on a M6. If you wanted a strip car some 4.30's & 20" drag radials would work well
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD"
Plans : 2013 CamaroSS 1LE
WeeZee is offline   Reply With Quote
Old 08-17-2009, 11:15 AM   #12
jpsuperman81
Yep I'm back!
Will 4.10's keep everyday driveability in tact? This car will never see the strip.
Old 08-18-2009, 02:51 PM   #13
usmcjlp
Drives: 2SS/RS LS3 RJT
I spoke to Ron at Vengeance Racing on Friday about gears. He told me there is a gear swap coming in about 2 months. He said it would require a complete differential swap. Due to the unique design, it is not as simple as swapping a single ring and pinion. This would raise the cost significantly to somewhere above $2000.
I am not an expert. This is what I was told. Ron is very active here and is an authorized dealer for Pedders, Pfadt, magnusson, procharger, etc. He has always given good advice and has steered me away from buying parts I didn't need. Just thought I would put this out there.
usmcjlp is offline   Reply With Quote
Old 08-18-2009, 03:01 PM   #14
mark_p
Drives: 2010 2SSRS m6
for 2000 bucks i think I will just put some 15" tires on when I need to go fast...LOL That would be the most expensive gear swap in the world. Surelly someonw will come out with something better than that
mark_p is offline   Reply With Quote
L99, A6 (1st gear discussion?) SGOS252382 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 31 07-26-2015 11:56 AM
Using 6th gear? ladysman07 5th Gen Camaro SS LS LT General Discussions 33 08-17-2009 08:35 PM
I R S Gear swap jonny5cam V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 07-30-2009 11:37 PM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
blew second gear. carguy_z28 4th Generation Camaros 5 09-18-2008 12:14 AM
