Cold Air Inductions
Old 08-16-2009, 06:39 PM   #1
Corvin
Corvin's Avatar
Drives: Soon to have a 2SS 2010 Camaro
ARH Headers Question
Now anyone correct me if I'm wrong but I was under the impression that installing these makes your car have error codes. If this is true has there been any word on a fix for it?
So I said.. "I want you to Twitter my Yahoo until I Google all over your Facebook"
2SS/RS - SIM M6 Order# NKNBS6 Reordered on 6/9/09 2G1FT1EW0A9134351 Born on date = 8/10/09
1100, Preliminary order accepted 6/9/09
3000, Order accepted by production control6/27/09
3100, Order available to sequence7/20/09
3300, Order scheduled for production7/20/09 TPW 8/03/09
3400, Order broadcast08/07/09
3800, Order produced08/10/09 2G1FT1EW0A9134351
4000, Available to ship08/11/09
4200, Shipped08/11/09
5000, Delivered to the dealer08/18/09
6000, Delivered to the customer08/18/09
Corvin is offline   Reply With Quote
Old 08-16-2009, 07:09 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i have installed several of the long tube header set ups with the small bullet cats and all of them have eventually set the p0420/421 cat efficiency codes, these were not the arh headers but other brands that have the same style small bullet cats
only way to fix it is to have a tune done and turn off the codes
Old 08-16-2009, 07:17 PM   #3
Corvin
Corvin's Avatar
But wouldn't that show up when you have your emissions test done and cause it to fail?
Old 08-16-2009, 07:28 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Yes. Long tube headers and cats will cause your car to fail the emission test if you live in an area that does it.
Old 08-16-2009, 07:30 PM   #5
camaro1
camaro1's Avatar
yes if the code is current,, from what i have seen these small bullet converters are hit and miss,, sometimes when the ecm runs the cat efficiency test they will pass then sometimes they wont. your ecm is always doing emmision test while you drive, all depending on your driving cycle/ style of driving
Old 08-17-2009, 09:35 AM   #6
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2012 Silverado LTZ
I've put LT headers on my 02 Camaro SS(FLP) and my 05 Corvette(Kooks). I have never thrown a code with either one at anytime. Some will and some won't.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 08-17-2009, 02:51 PM   #7
A.R. Headers
Drives: Pontiac G8 GT
Guys, This is always a popular question. The easiest fix, and consequently what produces the best results, is a tune. This eliminates any possibility of a CEL and at the same time boosts performance throughout the RPM range. Regardless of headers used, tuning is a must.
Nick
A.R. Headers is offline   Reply With Quote
Old 08-17-2009, 02:53 PM   #8
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
but even with a tune will it fail emissions testing??
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 08-17-2009, 03:03 PM   #9
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
no a lot of times with high flow cats you will still pass the sniffer with the same or better and you can pass even easier if the cats are nice and hot so get on it when going to get the inspection lol
but if you don't live in a state that has to pass the sniffer all they do is hook up the obdII check for codes and a visual inspection which i easy to pass because most don't care and the others just look see the cats and have no idea if they are factory location or not so pass
Gentry78 is offline   Reply With Quote
ZZ-Motorsports: ARH Systems on order at the best prices ZZcamaro V8 Bolt-Ons & Tunes 61 10-01-2009 03:38 PM
TSP Intake & ARH Headers Install Dyno Results Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 08-04-2009 10:05 PM
Question: LT Headers to 2.5 Exhaust RyanG Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 06-21-2009 07:29 PM
Headers Question SIK07GTSTANG Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 04-23-2009 07:14 PM
