BORLA
Old 08-16-2009, 10:57 PM   #1
VALOR
Drives: L99 cyber grey
Magnacharger Kit Questions
Had a couple of questions regarding the magnacharger kit:
1. What exactly comes with the kit? I believe the following -- anything else:
TVS 2300 Compressor
Larger Fuel Injectors
Custom Fuel Rails
Reflash of ECU
2. Should any of these components be upgrades prior to installation?
3. Do you still need to upgrade the air intake -- (for example, buy a vararam, etc.)?
Thanks
VALOR is offline   Reply With Quote
Old 08-16-2009, 11:09 PM   #2
JoshJ81
JoshJ81's Avatar
Drives: '10 Camaro 2SS/RS Black
The kit comes with an air intake that replaces the factory (the charger sits high, and the angled tube is slightly pointing downward to give it clearance below the hood), so you wouldn't need to get a VaraRam. I was wondering if the Vararam would give it some better flow?
JoshJ81 is offline   Reply With Quote
Old 08-17-2009, 12:22 AM   #3
VALOR
I would think the Vararam would have a better flow.
Old 08-17-2009, 12:48 AM   #4
LPFSTheFett
Drives: 2010 2SS Camaro
Will give it lower IAT's for sure.
LPFSTheFett is offline   Reply With Quote
Old 08-17-2009, 12:50 AM   #5
VALOR
Any suggestions on what intake to go with on the magnacharger then? Or do you think the one the kit comes with will suffice? Thanks.
Old 08-17-2009, 01:11 AM   #6
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Speed Inc. used the Roto CAI combined with the magnacharger tube:
JM
JM10 is offline   Reply With Quote
Old 09-04-2009, 09:09 AM   #7
Octaneman
Octaneman's Avatar
Drives: Camaro ZL1
The Magnuson does not come with an air intake, the supercharger inlet tube fits into the original air box.
At this time they still flash the computer for you, there is no hand held programmer as of yet. Still in the works as far as I know.
Steve
Octaneman is offline   Reply With Quote
Old 09-04-2009, 12:23 PM   #8
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I would use the Roto-Fab intake....They are going to have a new tube for the intake which is specific for the Magna, and will be a perfect fit!!!
ZZcamaro is offline   Reply With Quote
Old 09-04-2009, 03:05 PM   #9
carfansince73
carfansince73's Avatar
Drives: Carefully
Since we are talking about the Magnacharger, I was looking over the install directions, and I didn't see where they modified the fuel rail brackets. I read how they were removed, and then later on, it says to reattach the modified brackets.
Also, how hard is it to take off that harmonic balancer and drill those holes for the new one. I think that's the part that makes me the most nervous. F that up, and you are screwed bigtime.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! I wonder if the state would allow this vanity plate---> KISSMYSS
2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock
carfansince73 is offline   Reply With Quote
Old 09-04-2009, 03:05 PM   #10
rharon
rharon's Avatar
Drives: 2010 Yellow 2SS/RS
here is a pic of mine with roto-fab and a maggie
Magnacharger TVS2300, ARH HEADERS, ROTO-FAB CAI, NOWEEDS.NET DIVERTERS
rharon is offline   Reply With Quote
Old 09-04-2009, 04:32 PM   #11
Mister HP
Mister HP's Avatar
Drives: Speed Shop owner
You dont have to remove the balancer, just the bolt. The kit comes with a fixture, and the proper drill and reamer and the pins. Its pretty simple, but the bolt can be a PITA the remove and re-install.
Ed
Mister HP is offline   Reply With Quote
Camaro Brembo Big Brake Kit, Installed!! SS Mike Suspension / Brakes / Chassis 125 09-09-2010 01:34 PM
Group Buy - Turbo Kit ZZcamaro Forced Induction 32 11-30-2009 01:52 PM
Questions and Open Items for GM Rodrunner 5th Gen Camaro SS LS LT General Discussions 31 01-26-2009 08:39 PM
Interior Leather/Trim Kit Color Option Questions JMAN311 Cosmetics and Lighting Modification Discussions 6 10-18-2008 06:04 PM
