Old 09-21-2014, 06:45 AM   #1
Silverado60
Silverado60's Avatar
Drives: 2010 camaro 2SS/RS M6
Vin # breakdown
Does anyone have an accurate vin # breakdown for my 2010 ss ?
Silverado60 is offline   Reply With Quote
Old 09-21-2014, 06:50 AM   #2
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
This should help you out: See below for link to complete GM VIN Decoding.
http://service.gm.com/dealerworld/vi...2011%20car.pdf
Simplified Example: VIN 2G1FJ1EJXD9123775
Positions #1, #2, #3 GM make Identifiers
"2" for Canadian Made
"G" for GM
"1" for Chevrolet
Position #4 Car line
"F" for F-body
Position #5 Series
“E” for 1LS man (1EE37)
"A" for 1LS auto
“F” for 1LT man (1EF37)
"B" for 1LT auto
“G” for 2LT man (1EH37)
"C" for 2LT auto
“S” for 1SS man (1ES37)
“T” for 2SS man (1ET37)
"J" for 1SS auto
"K" for 2SS auto
Position #6 Body Types
"1" for Two Door Coupe/Sedan (1E?37)
Position #7 Restraint Codes
Always "E" for Camaro
Position #8 Engine Codes
"V" for the LLT (3.8 V-6 DI VVT)
"W" for the LS3
“J” for the L99
Position #9 Check Digit
Position #10 Model Year Code
"A" = 2010
“B” = 2011
“C” = 2012
“D” = 2013
Position #11 GM Plant Code
"9" for Oshawa #1
Positions #12 through #17 Plant Sequence Number. Position 12 is for production run. There are 99,999 in run 1, 100k after that
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 09-21-2014, 08:18 AM   #3
Silverado60
Thank you that's what I was looking for!
10 th digit is the letter A and then a bunch of numbers is that just production numbers?
Old 09-21-2014, 08:40 AM   #4
EmeryZ28
EmeryZ28's Avatar
Drives: 2011 Camaro 2SS/RS LS3
there is a guy on here, if you send him your VIN he will send you your build sheet
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
EmeryZ28 is offline   Reply With Quote
Old 09-21-2014, 09:55 AM   #5
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
There is also a sticker in the trunk with all of the RPO codes that identify specific features. Not sure if the 2010 model has it in the trunk or somewhere else though.
RobertRS is offline   Reply With Quote
Old 09-21-2014, 10:02 AM   #6
Silverado60
Dou you know who?
I do have a sticker in my trunk under the mat
Old 09-21-2014, 10:06 AM   #7
RobertRS
RobertRS's Avatar
Here's the thread
http://www.camaro5.com/forums/showthread.php?t=347878
Old 09-21-2014, 10:16 AM   #8
Silverado60
Originally Posted by RobertRS View Post
Pm sent. Thanks for the great info!
Old 09-22-2014, 10:26 AM   #9
PalmerGA
PalmerGA's Avatar
You're welcome and, yes... your 11th digit should be a 9 (for Oshawa). the 12th is the production run number and the remaining 5 digits are the production sequence. In my example, 2G1FJ1EJXD9123775, this car was the 23,775th build of run #1.
**Someone please correct me if I'm misinterpreting the code**
Old 09-22-2014, 10:32 AM   #10
PalmerGA
PalmerGA's Avatar
OP, your Build Sheet will look something like this:
Vehicle Build Model: 1ES37-2013 CAMARO 1SS Coupe
VIN: XXXXXXXXXXXXXXXXX (Deleted)
Order Number: QMMTKT
Gross Vehicle Weight: 2,147
Build Date: 08/16/2012
Build Plant: 9
Option Codes *IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
01A - SEAT TRIM JET BLACK
1AB - DR PANEL TRIM JET BLACK
1SS - BASE EQUIPMENT PACKAGE
1SZ - OPTION PACKAGE DISCOUNT
3BI - MOLDING I/P JET BLACK
4AA - INTERIOR TRIM JET BLACK
5A7 - TIRE SEALANT AND INFLATOR KIT (IN PLACE OF SPARE TIRE)
6X1 - COMPONENT FRT LH NON-COMPUTER SEL SUSP
7X1 - COMPONENT FRT RH NON-COMPUTER SEL SUSP
8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP
9L3 - TIRE SEALANT AND INFLATOR KIT (IN PLACE OF SPARE TIRE)
9X2 - COMPONENT RR RH NON-COMPUTER SEL SUSP
AE4 - SEATS, FRONT SPORT BUCKET
AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN
AFJ - BLACK
AKQ - PWR SEAT ADJUSTER, FRONT PASSENGER, 6 WAY
AL0 - SENOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AMM - PWR SEAT ADJUSTER, DRIVER 6 WAY W/ PWER RECLINER
AT8 - RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING
ATG - REMOTE KEYLESS ENTRY
AX2 - KEY COMMON, VEHICULAR UNIQUE
AXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN
AXJ - PASSENGER CAR
AY0 - CURTAIN SIDE IMPACT AIRBAGS
B34 - FLOOR MATS, FRONT
B36 - COVERING FLOOR MAT, LUGG COMPT.
B56 - MOLDING ROCKER BODY COLOR
BD8 - MOLDING BODY-COLOR ROOF DITCH
BTV - REMOTE VEHICLE START
C67 - AIR CONDITIONING
CF5 - POWER SUNROOF
D75 - OUTSIDE DOOR HANDLES
D80 - REAR SPOILER
DBW - MIRROR, INSIDE REARVIEW MANUAL DAY/NIGHT
DCP - ONSTAR PROCESSING DIRECTIONS & CONNECTIONS
DG7 - POWER OUTSIDE MIRROR
EF7 - COUNTRY CODE, U.S.A.
EMG - TRIM SEAT CLOTH, SPEED
FCQ - TRIM DOOR CLOTH, MONTILE
FE4 - SPECIAL RIDE & HANDLING
FE9 - 50-STATE EMISSIONS
FHO - VEHICLE FUEL GASOLINE E10
G80 - LIMITED SLIP DIFFERENTIAL
GAN - SILVER ICE METALLIC
GW6 - AXLE, 3.27 RATIO
I13 - ENGINEERING MODEL YEAR
JL9 - ANTI LOCK BRAKE SYSTEM, 4 WHEEL DISC
KG4 - ALTERNATOR, 150 AMPS
KTI - TIRE SEALANT & INFLATOR KIT (IN PLACE OF SPARE TIRE)
L99 - ENGINE, 6.2L V8 SFI
LHD - VEHICLE DRIVE LEFT HAND DRIVE
M97 - SHIFTER INTERLOCK BRAKE, TRANS
MAH - MARKETING AREA US, PUERTO RICO/ USVI
MX0 - TRANSMISSION, 6 SPD AUTOMATIC W/ TAP SHIFT AND REMOTE START
MYC - TRANSMISSION, 6 SPD AUTOMATIC
N10 - EXHAUST, DUAL TIPS
N34 - LEATHER WRAP STEERING WHEEL
NT7 - FEDERAL EMISSIONS SYSTEM
NV9 - PWR STEERING, VARIABLE RATIO
NZL - STEERING WHEEL MOUNTED AUDIO CONTROLS
OSH - OSHAWA PLANT CODE
R0C - TIRES, REAR BLACKWALL, SUMMER
R42 - WHEELS, 20" PAINTED ALUMINUM
R9N - PROCESSING CODE-SEAT
SBF - RESTRAINT SEAT BELT
SGC - SPARE TIRE/WHEEL NOT DESIRED NFLATOR KIT REPLACES SPARE SLM
- STOCK ORDERS
SRU - * REAR VISION PACKAGE * REAR PARKING ASSIST * REAR VISION CAMERA SYSTEM * MIRROR, INSIDE REARVIEW AUTO DIMMING W/ REARVIEW CAMERA DISPLAY
T3N - LAMP SYSTEM DAYTIME RUNNING SEPARATE CAVITY
T4F - HEADLAMPS HIGH INTENSITY
T83 - HEADLAMPS CONTROL AUTOMATIC ON-OFF
TB8 - HEADLAMPS CONTROL RH RULE OF THE ROAD
U2K - XM RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUSXM AFTER 3 MTHS
U77 - ANTENNA, ROOF MOUNTED
UD7 - REAR PARKING ASSIST
UDC - DISPLAY INSTRUMENT DRIVER INFO ENHANCED (ONE COLOR GRAPHIC)
UDY - COLOR INFO DISPLAY (CID) 7", WVGA, TOUCH SCREEN
UE1 - * 6 MTHS ONSTAR DIRECTIONS AND CONNECTIONS WITH AUTOMATIC CRASH RESPONSE, TURN-BY-TURN NAVIGATION AND ONSTAR REMOTELINK (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
UFU - AM/FM STEREO COLOR TOUCH RADIO W/ 7" SCREEN DISPALY
UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE)
UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER
UP9 - CHEVROLET MYLINK
UQ3 - AUDIO SYSTEM
USR - USB PORT
UTJ - THEFT DETERRENT ELECTRICAL UNAUTHORIZED ENTRY
UVC - REAR VISION CAMERA
V8D - VEHICLE STATEMENT US
VRG - VAA/COMPONENT REL COCKPIT
VRH - VAA/COMPONENT REL STEERING COLUMN
VRK - VAA/COMPONENT REL ROOF TRIM
VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION
VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION
VRN - VAA/COMPONENT REL REAR SUSPENSION
VRR - VAA/COMPONENT REL TIRES & WHEELS
VY7 - LEATHER TRIMMED SHIFT LEVER
VZD - MODEL YEAR IDENTIFIER
W2D - CARGO NET (DEALER INSTALLED)
WRS - RS PACKAGE: * HEADLAMPS, HIGH INTENSITY DISCHARGE WITH LED HALO RING * 20" MIDNIGHT SILVER PAINTED ALUMINUM WHEELS * BODY COLOR ANTENNA * BODY COLOR ROOF MOLDINGS
WZI - STEERING WHEEL CONTROLS, REDUNDANT TRANSMISSION
XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE
XR5 - POLLEN FILTER
YM8 - IDENTIFICATION - LPO
