B&M Racing
Old 08-17-2009, 07:37 PM   #1
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Question Oil level?????
I just had my oil changed at the dealership....1270 miles. The owners manual says it takes 8.0 quarts. That is what we put in....We cranked it, let it warm up, and the level on the stick was mid way in the cross hatch area.....shouldn't it be at the top of the cross hatch, at the first hole?? I drove home 15 miles and the level was the same...do I need to add a little more? I guess I can check it cold in the morning, but?
Where have I been seeing people adding 8.3-8.6 quarts? Or did I dream that? Sorry if this is an ignorant question, but I have to know....
Also did the rear end fluid change....glad to get that out of the way. We used the GM rear end PN to refill....and Mobil1 5-30 for the oil and....K&N oil filter....
Angela
350 HRSS is offline   Reply With Quote
Old 08-17-2009, 09:14 PM   #2
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
I put 8.5 qt. in mine to get it to the full mark on the stick.
Oldrocker is offline   Reply With Quote
Old 08-17-2009, 11:09 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The technically schematics of the LS3/L99 says 8.6 quarts
Old 08-18-2009, 10:41 AM   #4
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Thanks...why isn't that stated in the owners manual?
I will fix that this evening.....
Angela
Old 08-18-2009, 12:04 PM   #5
John Farnen
Drives: 1969 RSSS Convertable
Mine took 8.5 to fill it.
John Farnen is offline   Reply With Quote
Old 08-19-2009, 09:32 AM   #6
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Thanks again, added 1/2 quart, and it's fulll.....thanks for the replies
Angela
Old 08-19-2009, 12:57 PM   #7
Moth
Drives: 2010 Black 2LT/RS camaro
same on the 2lt?
Moth is offline   Reply With Quote
Old 08-19-2009, 04:16 PM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Originally Posted by Moth View Post
same on the 2lt?
No. The V6 has a 7.5 quart capacity.
Old 08-20-2009, 02:15 AM   #9
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
Like it states in the the " Owners Manual "
Oil with filter for the V6 is 6 qts ....
fee5fofum is offline   Reply With Quote
Old 08-20-2009, 02:41 PM   #10
toehead93
Drives: 2014 2SS/1LE
Is 5W/30 reccomended or 10W/30?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-20-2009, 05:11 PM   #11
ALLT4
ALLT4's Avatar
Drives: 2010 Camaro 2SS RJT
It says 8 quarts with filter, that's what I would use and did. The dipstick probably isn't the most accurate thing in the world and over filling it will only cause windage and a loss of power. As long as the pick up is immersed it's fine. I looked at my stick afer putting in exactly 8 quarts and it was half way into the hash. That's where it will always stay now, it's a reference now.
ALLT4 is offline   Reply With Quote
Old 08-20-2009, 10:36 PM   #12
fee5fofum
fee5fofum's Avatar
Originally Posted by toehead93 View Post
Is 5W/30 recommended or 10W/30?
Owners Manual section 11-2
Engine Oil w/ Filter
3.6L V6 Engine : 6-qts
6.2L V8 Engine : 8-qts
(L99 & LS3)
V6 : SAE 5w-30 GM6094M
Do Not use 10w-40, 20w-50 or any other viscosity grade oil not recommended
V8 : SAE 5w-30 / GM4718M (L99 & LS3) Mobil 1 is Factory fill ..
Do Not use 10w-40,20w-50 or any other viscosity grade oil not recommended
I changed my oil twice already with Dino , on my next oil change at 2500-3000 mi. I'm switching over to Mobil 1 from there on...
10w-30 is not mention in the Owners Manual , I would check with your Dealerships Service Dept. to see what they have to say about that.. But I would go by your Owners Manual recommendations..
Old 08-21-2009, 09:54 AM   #13
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
So, 8.6 qt or 8.0 qt.?
Ok, I am seeing almost 50/50 on this in here....
I know the owners manual says 8 qts, but then that is half way up the hash mark on the stick....and then others are putting 8.5-.6 qts in....to get to the top of the stick.
I would guess the owners manual is the boss here....but I would just like to hear the reasons on filling it to an extra 1/2 quart?
I may acutally go and drain out 1/2 quart of mine before I drive it again....
This thread is for input only.....thanks!
Angela
Old 08-21-2009, 11:45 PM   #14
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Well hell, now I am debating on whether I should drain 1/2 quart out from in there.....
Angela
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 10:38 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
