SDTW Custom Wheels & Tires
Old 04-21-2008, 03:13 AM   #15
Jose_The_Great_Cuervo
Jose_The_Great_Cuervo's Avatar
Drives: Purple/Pink Ford Escort Lx
lol damn. Oh well. I'd rather sacrafice my Camaro for individuality than to be mundane. I'm not knocking on the purist crowd, its just personal taste. Shit, its that crowd that usually sell their Camaro's for 70-120k when they turn 50 or 60 years old.
Can you say retirement?
Jose_The_Great_Cuervo is offline   Reply With Quote
Old 04-21-2008, 03:45 AM   #16
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Originally Posted by camaro5 View Post
Do it all as a package. All those pieces work together and it is critical to have performance matched components.
Translation: Find a good high performance shop, tell them how much power you want and they can specify a package...Cam, headers, supercharger, etc.
But, kiss your GM engine warranty bye-bye.
to the entire post.
Old 04-21-2008, 09:51 AM   #17
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
this engine should fit in a 3rd or 4th gen right???
Old 04-21-2008, 10:25 AM   #18
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe most of it should be a straight sway, physically. You'll likely need electrical connections, fuel connections, and intake manifold (among others) changes to a 3rd and 4th Gen., but the Gen III and Gen IV are nearly identical on the exterior (except for things like cam, crank, and knock sensor changes.)
IMHO, this is the exactly reason I'm trying to wait for a top dog model, so I don't have to spend $1K on mods' that will void my warranty. Regardless, there isn't anything quite like the sound of a cammed V8 though.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-21-2008, 11:07 AM   #19
Wedgy
Drives: 2004 Aveo
Ya.. You cant just toss a cam in a stock ls3 and get 50 extra HP for a $300.
You need to do ALL the supporting mods first. And don't forget the custom tune thats about $500.
O ya.. and I would go with thunderracing. I loved their 224/224/114 cam in my LS1. with all the supporting mods, I got 395RWHP. and they have the best customer service too.
Wedgy is offline   Reply With Quote
Old 04-21-2008, 11:45 AM   #20
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
how easy is a cam swap compared to most other engine mods? Is it recomended for gearheads only or would it be possible for someone with basic knowledge to do?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-21-2008, 12:08 PM   #21
Wedgy
Drives: 2004 Aveo
I did my own cam swap with basic tools at my house. I did a lot of research, and took my time to make sure I did it correctly.
I pretty much learned how to work on a car by moding my 02 camaro. I did everything but tune it, and weld in the sub frames. Spend your money on tools, not install fees at a shop. And take the time to teach your self, its worth it.
Also If you plan it correctly you will end up doing the easy mods first and get better with a wrench along the way, so by the time your car is ready for a cam, you will be able to install it your self.
Old 04-21-2008, 03:22 PM   #22
Grape Ape
Drives: 96 Bronco w/ a 5 speed
Itís not difficult, itís just a lot of work. You have to remove the water pump, timing chain, intake manifold, valve covers, rockers, a mess of hoses and wire. You also have to either remove the radiator and (some or all of) the grill/front clip or pull the engine out. The only really tricky part is getting the cam timing right and not leaving any leaks.
You shouldnít have to buy any tools, and if you do they are tools you should own anyway (except the engine hoist which you can rent). An experieced freind and/or shop manual will make things a lot easier.
You may also need new, more compressible valve springs if the new cam adds enough lift to make the stock springs stack or bind. If so then you will need a valve spring compressor and length of rope to stuff into the chamber (though the spark plug hole) to keep the valve from falling in. Iíve seen kits that allow you to use compressed air to hold the valves up, but if you lose pressure, you may end up having to pull the head to get the valve out.
Grape Ape is offline   Reply With Quote
Old 04-21-2008, 03:29 PM   #23
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
anything else??? we have done this to our camaro, this sounds right...its a lot of work but its worth it to have a knowledgeable friend there to help out because if you screw it up, you have to do it again....
Old 04-21-2008, 08:00 PM   #24
swazworth
the nerd king
swazworth's Avatar
Drives: 2005 scion xb...
ok then, i say we just let gm save us all this work and let us order one from the factory with this cam.
who is with me???
swazworth is offline   Reply With Quote
Old 04-21-2008, 08:05 PM   #25
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
2nd
Old 04-22-2008, 04:46 AM   #26
TAG UR IT
TAG UR IT's Avatar
3rd!!!!!!!!!!!
Old 04-22-2008, 04:48 AM   #27
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
/signed
Old 04-22-2008, 07:26 AM   #28
Camaro68
Camaro68's Avatar
Thumbs up thanks
http://www.karlperformanceparts.com/...?idproduct=547
Holy snikies!!!
I tell you right now....if my 5th Gen comes w/ an LS3, I'm going to make every attempt at ordering mine w/ a factory installed cam like this one. It's going to kick all the others @sses! Sheat, yeah!!
Thanks for the link awesome motor. If it makes it in the new Camaro
it better have 19....teens in the back
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Edmunds: GM Foreign-Exchange Program: Holden Special Vehicles Getting LS3 Scotsman General Automotive + Other Cars Discussion 5 03-27-2008 01:51 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
0-60 Article on the LS3 JeepinMatt Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 08-28-2007 11:00 PM
