SDTW Custom Wheels & Tires
Old 08-18-2009, 11:31 AM   #1
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
DYNO, INSTALL, DYNO, TUNE, DYNO
Hey guys I thought you would enjoy this info.
We are doing an install of ARE headers W/C and Maganaflow axle back then dyno tune using HP Tuners.
We just baselined the car 5 pulls averaged for 370 RWHP and 370 RWTQ. with a best pull of 375 RWHP and 375 RWTQ and a hot soaked 360 RWHP and 360 RWTQ.
We will install the exhaust systems then dyno again untuned then tune it and dyno again and post the results.
We are video recording the highlights and will post a video in the next few days after we edit footage to keep it to down to the important stuff.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-18-2009, 11:45 AM   #2
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
sounds good!
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 08-18-2009, 11:45 AM   #3
thecamaroguy
thecamaroguy's Avatar
Drives: 2010 Camaro SS/1967 Camaro SS
Cant' wait to see the results!
thecamaroguy is offline   Reply With Quote
Old 08-18-2009, 05:50 PM   #4
JANNETTYRACING
Here is a tease to hold you over till I can sit down and crunch the numbers, Still Working on the Tune there are a few more ponies hidden in there.LOL
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-19-2009, 11:57 AM   #5
JANNETTYRACING
The Real Results No padding here
Starting with a fully warmed up engine strapped to the Superflow Chassis dyno, we did 5 pulls for each combination, took our average from each group and compared RWHP and RWTQ.
The American Racing headers W/Cs coupled to the Magnaflow Axle back system requires 2 stainless 2 1/2 inch pipes to connect the 2 systems 1-9 inches and 1-4.5 inches long along with some carefull twisting and aligning it all worked pretty well.
This provided an honest and solid repeatable 28 RWHP and 25 RWTQ.
A tune without being overly agressive with timing, keeping Knock retard to under 1 degree, cleaned up the air fuel ratio to a flat 12.5:1 again safe, worked with the torque management, turned off Skip shift, raised speed limiter, lowered fan turn on temps.
Netted us another honest solid and repeatable 9 HP and 12 RWTQ for a total gain of 37 RWHP and 37 RWTQ.
Total numbers were 410 RWHP 407 RWTQ.
I realize these numbers are lower than advertised but I assure you they are accurate and repeatable.
Engine oil temp plays a major roll in the power to the wheels so if your not paying attention you can easliy show the lowest numbers against the highest numbers.
This is the main reason we do 5 pulls for each combination.
We also pulled the air filter from the stock air box and made 1 HP and 1 TQ, so I will be curious to see if the cold air system really make what they advertise.
The most impressive thing is how this car drives with the torque managment adjusted, Throttle Response is Amazing, Feels more like 50 HP from the Seat O Pants Meter.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-20-2009, 05:02 PM   #6
JANNETTYRACING
Penny for your thoughts?
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-20-2009, 05:56 PM   #7
CDBiker220
Drives: 98 camaro z28
You said you needed (2) 1.5" pipes to connect the AR Headers system to the axle back system. Why 1.5", wouldnt that be a restriction in an exhaust that is 2.5"?
CDBiker220 is offline   Reply With Quote
Old 08-21-2009, 08:05 AM   #8
JANNETTYRACING
Typo, Sorry, Edited.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-21-2009, 11:17 AM   #9
CDBiker220
Yea I figured it was just a typo but had to ask. Numbers look pretty good, about 40 hp with bolt ons is not bad. I was curious exactly what the torque management on the LS3 is doing and how much of it there is? Does it have a noticeable impact on acceleration by adjusting it?
Old 08-21-2009, 11:37 AM   #10
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
Nice and honest...
Vengeance did something similar when they were building mine and the ARH netted 28.69RWHP 23.58RWTQ.
You can see additional info in my build thread....
So...between you and them...I think we have a pretty honest answer. Mine was done in Atlanta in the summer, so it was hot and humid...but, then...so was the baseline
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 08-21-2009, 12:02 PM   #11
JANNETTYRACING
The torque managament is the single biggest difference in the street performance.
When I adjust it, the engine gets to full throttle quicker which makes if feel like 50 hp.
Torque management does not show up on the dyno it shows up on the street.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-29-2009, 09:46 AM   #12
JANNETTYRACING
Bump for new members to see.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-29-2009, 12:26 PM   #13
Daddyo01545
New England C5 Member
Daddyo01545's Avatar
Drives: 2010 Camaro 2SS/RS
Base numbers look at bit high...was this done on the dyno with a load? Or just sitting on top of the dyno? What was the weather conditions on baseline? Thanks for additional information.
Daddyo01545 is offline   Reply With Quote
Old 08-29-2009, 12:46 PM   #14
JANNETTYRACING
With a Superflow Dyno with or without a load makes no difference, because it measures torque at the wheel.
The only difference is how long the RPM Sweep takes, Tested this hundreds of times.
Baseline and finish were done same day 90 degrees throughout the day.
The car was fully broken in and fully warmed up oil temps were held consistant.
These cars gain 10 hp just getting the oil up to temp.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Another L99 Dyno tune (with headers and CAI) pcmforless Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 02-26-2011 07:36 AM
Dyno Tune Dewdude Tuning / Diagnostics -- engine and transmission 0 08-11-2009 03:26 PM
New Era Intake before and after Dyno (26rwhp) No tune alex33x Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 08-10-2009 10:24 AM
SGOS's - L99 A6 Dyno results (after dyno tune) SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 07-27-2009 02:13 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
