| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#101 | |
Drives: 2SS Victory Red Join Date: Jul 2009
#102 |
Boosted Moderator
J.R.
I have taken the time to read this entire thread. If I missed anything, I apologize, but I have a few questions. First off, thank you for taking the time to explain your area of expertise. I am torn between Supercharging and Turbo-Supercharging my Camaro. I have an SS with the LS-3. You mentioned the cooling of the Turbo system by undercar air flow. Are the turbo's in your system mounted under the car at the exit point of the exhaust manifold, or are they mounted at the rear? I read where with a properly sized system, there is relatively no "turbo lag." Can you explain this a little more. I am very intrigued by this. My next question has to do with some of the dyno graphs that have been posted. It seems that unless I'm reading them incorrectly, there is a huge in-rush of power, starting from near idle up to around 5000-5500 and then the powers drops off. Is this common. I was under the impression that Turbos created power up to and beyond the RPM capability of the engine. Is there something in the way the boost comes on that reads differently from the "blown" engines on the Dyno. The blown engines seem to make torque hard and fast and build HP all the way to or almost all the way to the red line. The charts shown here seem to show the turbo engines climbing abruptly and then peaking and dropping back off... I know there is some professional difference of opinion related to this, but at the same relative boost level, if a turbo system provides more net gain, is there any relative difference on the long range strain on the engine? Would it be prudent to go ahead and put forged internals in the short block, or would that be un-necessary at moderate boost levels? Is it recommended to put a fuel booster or different injectors on a supercharged engine. I would not want to lean an engine out and risk breaking a piston through ring binding against the cylinder walls.... I never really knew the way a waste gate worked until reading this thread, and a question related to that is is the waste gate adjustable in small increments at any time or is this something should only be done during a dyno session? For example, could you have a hand held tuner and "adjust" the waste gate from say 6 to 8 lbs of boost and just plug in a different tune....I guess if would be a boost on the fly so to speak... I've ridden turbo'ed motorcycles and they are amazing, and therfore I am leaning a little towards a turbo system... I'm also a fan of sleepers. To me there is nothing more satisfying than knocking the smirk off someones face as their much more expensive car is suddenly trailing far behind a car they just knew they could smoke. If I was to buy one of your systems, do you have a recommendation for an installer you have used in the Central South Texas area. I live between Austin and San Antonio... I'm still a couple of months away from purchasing, but I want to have my ducks lined up when the time comes... I apologize for the long post... but really want the information from someone that has been there done that.... Anyone else with arguments for something else, or supporting information, feel free to chime in... |
#103 |
Lots of people are torn as both methods offer a great power increase. It just comes down to what you really want vs. what you can afford. The twin turbo set ups are at the top of the food chain and of all the twin turbo kits out there the Granatelli/TTi system offers the most power with superior fit and finish. We are talking about “real” production style kits. You can always find companies that promise the world with no ability to deliver. I have exhausted my opinion as to why I feel the turbo is the best choice – But basically it makes the most power (or should I say, it has the ability to make mega power and always superior torque).
Our turbos are mounted directly off the exhaust manifolds – Here are a few pics: ![]() The black plate you see is spaced down .75” This allows cools air to vent over the turbos – it is natural airflow and therefore has the same cooling effect as it would on a stock application.. (We do not offer the muffler turbo style kits – they have tremendous turbo lag. As an example we dyno’d an STS kit the other day and at 3800 it had only reached 3psi on its way to 7 at 6000 rpm – that is just not right) Turbo Lag – As defined lag is the delay or time it takes for positive pressure to reach the intake after going WOT (wide open throttle). In the past, turbos would have a lag, meaning it would take more time for a turbocharger to get positive pressure than say a roots type blower. What they don’t tell you is it takes a ton of power to drive the blower so it is all a trade off – fast forward 20 year later and it still take a ton of power to drive the blower but turbos have come a long way and the way they work now, TWINS have virtually no lag. That means when you step on it – you see positive pressure in the manifold. Search any Granatelli and Hellion customer on this board – NO ONE complains about lack of boost right off idle. – Therefore LAG is a non issue with Twins – single turbos may have a small amount but nothing to worry about. If you see power drop off in the graphs it is because we are all turning the dyno of at that point. I can tell you for sure our turbo kit will just keep making power until you blower the engine up – it does not give up at any RPM – the camshaft may drop off but ….. it will pull until you lift – I think the dyno graph are confusing you – if you are comparing our TT kit to say a Maggie – the Maggie may have more torque below 2000 rpm but after that – we win hands down all the way to 10,000 if you have the balls to go that high You do not need to forge the internals if you plan to stay below 575 to the tires Something just came up – I hope to complete this tonight – see ya Last edited by Granatelli; 11-30-2010 at 12:06 PM. |
#104 |
most of the forced induction kits sold will include the mating (required) injectors. As for a fuel pump booster, the stock system will support 475 to 500 at the rear. After that you need at minimum a fuel pump booster. To be safe an in tank pump and system upgrade should be done when going over 600 rwhp.
If you had a prof tune for say 8 psi then it would be fine at 6psi because the MAF would correct for it. However if you had a tune for say 12 psi and then only made 6, it would be super rich and yes a hand held with 2 tunes can accomplish your goal. If the question was can you adjust boost on the fly, yes with a turbo boost can be adjusted very easily and there are controllers that make it easy to go from 3 psi to 20 psi and beyond with ease As for installer - we are happy to hook you up with the right company in your area - we have a few |
#105 |
mcnhammer
Drives: 2010 Cyber grey Camaro SS Join Date: Jul 2010
Procharger 8 lbs. boost
2010 CGM SS M6
Upgrades: Procharger S/C (8 lbs. boost / 60# injectors) Aquamist methanol injection American racing LT headers w/mids Magnaflow axle back Meziere electric water pump
2010 CGM Camaro SS
582rwhp / 518rwtq COTW: 8/30/10 |
#106 |
I love the Procharger, I just don't like the air filter sucking the hot air like that
#107 |
"Silver Street"
Drives: 2010 2SS/RS L99 Join Date: Oct 2009
525 RWHP/490 RWTQ - L99 with Magnuson TVS2300 (6 lbs, 3.8"), Comp Cams (219/223 115+3)
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing Last edited by bi11ymc; 10-07-2010 at 06:49 PM. |
#108 |
Futral Motorsports Beast
I love the look of the Maggie but i'm not impressed with their performance
#109 |
![]() Drives: Red Jewel SS RS 625 RWHP Join Date: Sep 2009
Jusy wanted to say great thread and lots of good info. I have an Edlbrock SC and love it. Great for low end torque. I have 625 RWHP.
#110 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Jan 2007
I haven't seen anybody with the Edelbrock E-Force S/C post any results on here. Before installing the E-Force S/C I had Kooks 1 7/8" LT headers, Ported intake, LMR CAI and dyno tune. It put down 414/rwhp and 406/rwtq. After installing the E-Force S/C( minus the ported intake) adding a Roto-Fab CAI and getting a dyno tune by Jeremy Formato it put down 546/rwhp and 522/rwtq with 6# of boost.
![]() Ralph's Camaros 2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, Roto-Fab CAI, Elite Catch Can, Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. 546/rwhp & 522/rwtq Tune by Jeremy Formato. |
#111 |
That sounds about right - congrats
#112 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
#113 |
A few of the other kit guys turbos hang so low, plus they mount their filter down there as well. In an effort to show people how our kit does not drag the turbo we put a plate across the bottom and people just started expecting it - so in short yes it is cover that we include with the kit - however - you do not need it as our turbos sit about 1.75" above the frame rail plus our filtering system draw cool filtered air from both sides of the nose - not under the car
#114 |
Granatelli vs. Hellion?
#115 |
Camaro SS Lover
The skid plate is a great idea with or without turbos. I'm always bumping the flang's connected to my LT headers attached at the bottom of my vehicle, on shitty roads or messed up speed bumps.
Does it require drilling to attach? |
#116 | |
![]() ![]() ![]() ![]() ![]() Drives: 2012 zl1 Join Date: May 2009
#117 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
I saw someone wanted an Edelbrock E Force write up so here mine is.
Edelbrock E Force, forged bottom end Cam Stroked Well you get the point and can see detail in my signature. I love the smooth power and torque provided by the E Force. Limit is reached fairly quickly with a 2.75 pulley and that is as small as you can go. No belt slip if you use the Gatorback belt that is recommended by Edelbrock. And it is only a 6 rib belt. Nice look and good low IAT numbers. 115 yesterday under load and fairly hard driving with a lot of boost. Of course I am on E85 so numbers might be higher on pump fuel. Injectors supplied are undersized if you are going for bigger numbers but whose are not...
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
#118 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: a Jet :-) Join Date: May 2009
I love TQ, but so early can hold you down by spinning your wheels off. But awesome results if you control your right foot. |
#119 | |
Camaro SS Lover
How, much boost are you using surely above 9psi. and how much hp's do you think are attributed to stroking the engine, and do you also have ported heads? |
#120 | |
Very Nice! And I thought I had a lot of HP. Congrats! ![]() |
#121 |
Camaro SS Lover
Awwwhhhh..... I just realized your engine is 418ci. stroked. That' explains it. I expect close to 600rwhp., even with a blower CAM, no way in hell gonna' acheive 700+rwhp. with safe boost levels on a stock case.
#122 | ||
Thanks so much...I am pretty pleased as well. The stoker added a good amount low rpm torque. But overall not huge amounts of hp and torque top end numbers. I did keep my compression around 10.07 to 1 but still lowered the compression from stock.....just not as low as some of the old school builds would be. This was based primarily on discussions with several ls3 builders and race teams. In fact, our original plan was to have our compression around 10.3 to 1 but I was not able to use thinner head gaskets as the heads are zero clearance heads and I already had my push rods purchased. So we used ZR1 head gaskets and ended up with less compression.
#123 |
Camaro SS Lover
Have you done anything to the stock suspension, bushings, springs, braces (chassis / struts)? I have all Hotchkis systems in place now, but haven't done any bushings yet, thinking Phadt to control wheel hop and traction.
#124 |
Nope but that is this winters project. Probably end up going pfadt mainly cause they are in Utah and I might go there and have them install and train me how to adjust for max benefit. Like the hotchkis stuff though a lot.
#125 |
Camaro SS Lover
Yeah. I really like Hotchkis, it would have been nice if they had bushing kits too. However, sometimes good to mix / match so your not stuck with one vendor. So, I have Hotchkis springs, sway bars, chassis / strut braces, and end-links, will go with Phadt for all their bushings. Like Pedders too but their way too complicated with all the varying versions of their products.
Problem for me is if I were close to these vendors I could just go by and say hello as in your case, for me they're not located anywhere in Canada, so have to do research, discuss with installer and take a chance. I will tell you though, the Hotchkis kit made a huge difference until I got the new CAM and got an additional 50-60rwhps., and then wheels spinning, hops are occassiion but want to reduce any chances of hopping considering I know this creates potential to break things. |
| Thread Tools | |
| Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread | UCF w00t | Camaro Price | Ordering | Tracking | Dealers Discussions | 4241 | 09-19-2011 03:27 PM |
| PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143815 | 11-06-2010 11:00 AM |
| Really? Why is the DealerInfo Thread Gone? | renderinfo | 5th Gen Camaro SS LS LT General Discussions | 2 | 02-11-2009 08:01 AM |
| Changing Photoshop Thread Format | headpunter | Site Related Announcements / Suggestions / Feedback / Questions | 20 | 11-06-2008 05:40 PM |
