| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#126 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
#127 |
so heres the deal, once i get back from afganistan, my 2010 camaro ss will be payed off in full and i was woundering, should i do supercharger or turbocharger, i wana do cams, headers and exhaust, how much and what kind, need help plz, i have a black 2010 camaro ss, LS99
#128 | |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
However, turbos do provide higher end power, than a supercharger. |
#129 | |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Feb 2010
#130 |
Boosted Moderator
You dont "have" to do shorties...There are at least two kits out there that use the stock exhaust manifolds... The turbos bolt onto them.
I am having a Twin Turbo set up put on my car right after the new year... We are building custom one off exhaust manifolds with stainless tubing, mandrel bent, and hand welded. They will have half inch flanges on both ends. It doesn't make sense to hang 1500 HP worth of turbos on 600 HP worth of exhaust manifolds. We are also building the short block, heads, and installing axles and a clutch. After I have this done, I'm going hunting for a suspension kit to help get the power to the ground. 850 or more RWHP is very possible... I'll have it back by mid Feb or so, as soon as I get back from my next trip to Brazil... |
#131 | |
Camaro SS Lover
But, very, very .
#132 | |
#133 | |
Drives: 2SS Victory Red Join Date: Jul 2009
#134 | |
This question has been asked and answered over and over. Naturally we are prejudice as to our opinion but I will take a stab at it again
Just looking at each kit side by side tells a big part of the story. Our fit and finish, our design and layout and most importantly, our end results speak volumes. GMS uses Bell Engineering Intercooler cores. They are hand built and have been regarded as the best of the best in terms of air flow vs. pressure drop and inlet vs. outlet temp efficiency. We use the largest, custom fitting parts that are designed around the frontal area of the Camaro. ![]() ![]() ![]() ![]() The competitiors use a simple generic intercooling system designed by Vibrant http://www.vibrantperformance.com/main.php The parts are pretty but not "custom" by any stretch of the imagination. Side by side, again, it is easy to see the real difference. You can also see it at the wheels. Lbs. for lbs of boost the difference shows up exponentially. Turbos - Turbonetics makes nice stuff - there is no denying. We offer and sell many kits using thier product. However when it came time build the ultimate TT kit for the Camaro Platform, we looked no further than our own past 10 years experience of racing and designing LS engine single and twin turbo systems. Here is a video that shows our off the shelf TT kit we sold in years past for the C5 and C6 Corvette Here is a proven bolt on 1000hp and 1100ft/lbs twin turbo kit. You will note both our Camaro and Corvette kit use the same intercooler core layout proving there efficiency and room for growth. At the end of the video, you will note we ran this with Turbonetics turbos. We saw and know where the turbos give up and what kind of boost it takes to make those numbers. Therefore when the 2010 Camaro kit was designed we went directly to the Precision PTE 6265 turbos. Each turbo is capable of 650 to 676 hp at only 15psi meaning our kit WILL MAKE 1300hp plus HP at only 15psi. That is 300hp more then the Turbonetics turbos at the same boost and that translate to better efficiency and better power down low in the REAL Area of the curve that 90% of us are looking for. You get what you pay for – Simply put we use better parts and better material through the kit and that translates into a $1000 price hike over the other kit. When you go to install the kit you see the difference and after you have had the kit for 6 months you really come to appreciate the kit even more so. Compound that with the fact we hard pipe and properly design a custom intake for each turbo to insure they always get fresh cool clean air and you have a winner. All too often when kits are designed they forget about the air going into the turbos – We Did Not ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#135 | |
#136 | ||||
![]() It all comes assembled – just bolt it to the stock manifold and the back slide into your stock or aftermarket exhaust system – you can even pre order with 2.5” or 3” collectors ![]() ![]() Quote:
If you go as far and ½ flanges then great but in the end, I still contend it makes an insignificant difference – at up to 1300 proven hp Last edited by Granatelli; 11-30-2010 at 05:19 PM. |
#137 | |
Camaro SS Lover
However, why two different styles? |
#138 | |
Middle is Chrome moly with forged ends Bottom is Billet |
#139 |
Spoonful of Pain.
How practical are exhaust cutouts with a TT setup?
-DAN
2010 Camaro SS2/RS Black with Cyber Gray stripes Proud new owner 3/18/2010 ![]() |
#140 | ||
![]() Drives: 2009 G8 Gt Twin turbo Join Date: Nov 2010
torque is king when u have a camaro or G8 thats 4000 lbs. My old stock with dod l76 made 616whp at 5000 rpm and 649 wtq at 3700 rpm on 10 psi on pump gas. Cant beat that to get a tank rolling!!!! STS 60-1 twins.... |
#141 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: a Jet :-) Join Date: May 2009
I'd say very practical, if there are placed close to the release of the turbos. As long as there is no back pressure on the release side, those turbos will spin freely and much quicker and response is much faster.
To me, the cutouts, specially the good ones like NoWeeds.net when connected to stock exhaust, you get the best of both worlds. In normal driving and cursing, it's quiet and no drone like you get from open exhaust and as soon as you want to have fun, click a switch and you get 3" open exhaust at your finger tips. Just be sure the tune is made for it, sine you get the boost much earlier than stock and you should have fuel much earlier too. |
#142 |
#143 | |
![]() STS is nice but will always lag compared to the turbs mounted off the manifolds up front Last edited by Granatelli; 01-17-2011 at 04:41 PM. |
#144 |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS 6 Speed Join Date: Mar 2010
Just had my 2010 LS3 dynotuned after installing a Maggie 2300 last week. I have the Maggie, K&N CAI and Stainless Works Cat-Back and registered 490tq and 513hp on a conservative tune. Running stock pulley on SC, the boost measured 8+ peak.
#145 |
Here is the latest Dyno for my car.. TVS2300, Kooks Headers, Stage II Blower Cam, ADM Street Cold Air Intake, 3.70 Gears, Innovators West 8-Rib Pulley System with 3.4 Blower Pulley and ADM Custom Dyno Tune.
ADM Performance ROCKS !!
#146 |
Camaro SS Lover
Decided. Going with the D-1SC procharger. Estimating I'll make very close to 660rwhp. and close to 550tq. with very moderate and safe 6psi. of boost.
Cleaner, easier install (don't have to remove stock intake or modify engine cover), air-to-air intercooled, reduced detonation, no meth needed and much easier on the engine than higher boost numbers to achieve the same goals. Can always increase boost with upgraded internals, and Procharger has a great warranty @3yrs. and a fabulous upgrade program to go from the lower end P-1, to the D-1SC or even the F-1 series. Will start with the Stage II, with D-1SC upgrade, 12rib. serpentine, and custom race valve, with the massive intercooler, and the ADM dual-pump fuel kit. Seen the HO system P-1 on an SS @6psi. make 640rwhp / 550lbtq. with very moderate tune, very safe, no BAP, no fuel, no meth, no detonation and sounds amazing. Can't beat those options. Have to admit though the Maggie looks cool, and the turbos look cool'er with all the complicated tubing. |
#147 |
Congrats on your choice but complicated tubing of a turbo? Have you seen the plumbing that goes into an intercooled centrifugal? It is the same as any other turbo or centrifugal running air to air intercooling with forced induction.
Plus to make 660 at only 6psi you will have to add headers and a not so mild tune. 6 psi is a 40% increase of stock. Assuming 100% efficiency at stock motor with headers that makes 410 to the tires will make 590. I agree you can get to 660 but that will not be a mild tune - it will be good pump gas and aggressive timing. No question the procharger can make big power over the Magnuson but you give up on torque down low and that is what all the maggie guys keep holding on too. Why not it is a wonderful thing
#148 | |
Camaro SS Lover
My installer has done quite a few Maggies, Turbos, Meth, NO and ProCharger too. So, I have to take their experiences into consideration as well. When making my decision the cool factor and power gains are always part of the process, however the best decision for my engine has to take precedence, I think the ProCharger is the safest, most powerfull way to go. My understanding is to stay away from knock sensors as much as possible, and seems like ProCharger behave really well in that area. Might have something to do with the intercooling system. There is an intake to the SC, and the boost flows to the intercooler, and from the intercooler to the TB, and a few other minor connections for run-off and cooling, and it's all in front of the the rad. Pretty simply to do except for removal of the front fender, but that needs to be done for any SC that has a cooling system anyway, The part I'm concerned about most is all the work for the dual-pump system. Practically, taking the whole back end apart to get to the gas tank. As for the rest I'm already setup with headers, exhaust and booster cam. So, making the 660rwhp. with about 500lbtq. low down should be enough. I haven't seen too many Maggie setups make much more than that down low without forged internals, and stroked engines. But, I do admit they do hold the TQ higher up. I guess there's always a bit of a trade off regardless of the system. But, if I wanted to I could always do like the maggie dudes, and increase the boost to 8-10psi., but I don't want to push it for a few extra lbs. of torque. |
#149 | |
Boosted Moderator
Sounds like you will end up with a mean car... A good friend of mine, Kyle, has a Procharger, and it is sic... He was the big dog in our area for a long time with at or just over 700 HP. He has a LSx 427 after he popped his LS-3... I'm trying to topple him from the BIG DOG throne ... lol, actually he is an awesome person and I have no issues with whom is the biggest or has the most power... I am fortunate that in this area, as this site shows in most parts of the continent, there are some amazing people involved with this car...Good Luck with your build, and start a build thread for us to follow... |
#150 | |
No question a centrifugal makes the least amount of power down low so for that reason – YES it I safe. However, the Procharger takes power off the crank and puts added stress on the nose of the crank – that is why they tell you to “pin” the nose of the crank pulley when doing the install. It stops the blower from ripping the pulley off the crank like unscrewing a nut from a bolt or reverse rotating a cap off a beer bottle. Also the Procharger will move a ton of air and make HUGE power in the latter part of the RPM range so caution should always be taken. When you say the MOST POWERFULL?? - I mean a turbo will always make the most power per lb of boost - Hands down As for Knock sensors and intercooling – the coolest air possible is always the best way to go but again Centrifugals are not better than turbos in that department either – that is based on the intercooler – So that would be a toss up. There is no front fender removal required on the twin turbo install – at least not on any of the systems I have seen As for torque – the Maggie will make way more down low and the Procharger will carry it higher You made a great choice either way |
| Thread Tools | |
| Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread | UCF w00t | Camaro Price | Ordering | Tracking | Dealers Discussions | 4242 | 09-19-2011 03:27 PM |
| PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143815 | 11-06-2010 11:00 AM |
| Really? Why is the DealerInfo Thread Gone? | renderinfo | 5th Gen Camaro SS LS LT General Discussions | 2 | 02-11-2009 08:01 AM |
| Changing Photoshop Thread Format | headpunter | Site Related Announcements / Suggestions / Feedback / Questions | 20 | 11-06-2008 05:40 PM |
