BORLA
Old 08-18-2009, 08:00 PM   #1
AntiVnm
AntiVnm's Avatar
Drives: '10 IBM Camaro
octane boost
So with all the ho-hum about dealers putting in 87 octane before delivery, would it be beneficial to run a can of octane boost in the first tank to make sure it didnt happen to you? gonna take delivery soon and not sure on the "shadyness" of my dealer. any input would be helpful.
Dynateck 1 7/8 headers, CAI intake, Nitto DR, 3:73 Richmond gears, Vigilante 2800 stall converter, tune
AntiVnm is offline   Reply With Quote
Old 08-18-2009, 08:56 PM   #2
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
tell him not to fill it up until you pick it up .dealers do take requests you know .good luck when you get it . by being there you will know what they put in .
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 08-19-2009, 04:10 AM   #3
AntiVnm
AntiVnm's Avatar
yeah i did say something to him. there is a good chance i will be out of town for work when it comes in and i was just looking at it as a precautionary measure. i was thinking if it would screw with the computer then i might do it just in case.
Old 08-19-2009, 04:13 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Octane boost does nothing. Many test show it actually hurts performance since they really have nothing in them that helps your car.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-19-2009, 04:46 AM   #5
AntiVnm
AntiVnm's Avatar
thanks scott!! i was just lookin for some advice one way or another.
Old 08-19-2009, 04:50 AM   #6
Scott@Bjorn3D
No problem. I looked into it when my car was running slow and after reading about 10 different lab test all the stuff off the shelf is worthless. The only thing that maybe you could do is see if you could go to a drag strip and fill up with the real high octane stuff.
But the GM guys says it would take like a tank or two to raise it back up.
Old 08-19-2009, 06:55 AM   #7
Scrapppy666
Scrapppy666's Avatar
Drives: 2010 2SS/RS M6 Black/Black
I was once a member of clubhotrod forums and there were some old timers on there and quite a few people who raced in all different categories. I remember a thread about octane boost and basically they said anything off the shelf will be useless, may keep your system clean but that's about it. Some octane boost is actually harmful to emission equipment so use it with caution. A booster substitute would be Xylene or Toluene, both of which you can find at a paint store or some hardware stores. Toluene was the recommended choice and Xylene was known to cause some seals and rubber lines to dry out.
Do some research, there is tons of info on this... Personally I would probably stay away from both as I don't know enough about it to risk it
Pittsburgh Automotive Photography
Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake
Scrapppy666 is offline   Reply With Quote
Octane Ratings? Icefsh Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 03-10-2015 05:10 AM
Octane Booster? MikeBing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 10-25-2009 06:08 PM
The Much Awaited #230 (L99) Update. Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 140 08-20-2009 09:52 AM
Anyone else using octane booster in their SS? OHIOSS 5th Gen Camaro SS LS LT General Discussions 27 07-08-2009 05:03 PM
High Compression Ratio + Boost = Uh Oh AirGoya Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 50 09-21-2008 08:55 PM
