JDP Motorsports
Old 08-19-2009, 12:58 AM   #1
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
Talking After HP tuners tune.....
After you got your HP tuners custom tune.... was there a starter lag, ie: When you go to start it did it turn a few times before it cranked?
EDIT: I reset my ecu but it still has a slower crank than stock. Def better, but still a bit slow! What else can do?
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 08-19-2009, 04:54 AM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
un plug the ecm for 20-30 sec and it will start fine
Old 08-19-2009, 06:54 AM   #3
EAkrish
Scout Sniping
EAkrish's Avatar
Even if it's happening everytime?
Eric
Old 08-19-2009, 07:51 AM   #4
mstrfdsstr
mstrfdsstr's Avatar
Drives: 2010 SS/RS CAMARO
yes i had the same prob disconnect the neg battery terminal for a minute then you will be fine.
IOM 2 SS/RS LS3 vin9862
mstrfdsstr is offline   Reply With Quote
Old 08-19-2009, 07:55 AM   #5
EAkrish
Scout Sniping
EAkrish's Avatar
Roger that, I am going scalloping today so I won't be able to try it till later. Thanks for your help guys!
Eric
Old 08-19-2009, 08:28 AM   #6
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Where did u get the tune done? Nevermind...i see in ur sig Fasterproms
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 08-19-2009, 09:18 AM   #7
EAkrish
Scout Sniping
EAkrish's Avatar
He did a awesome job!!!!
Eric
Old 08-19-2009, 10:12 AM   #8
thecamaroguy
thecamaroguy's Avatar
Drives: 2010 Camaro SS/1967 Camaro SS
How much?
What all had you done to the car prior to taking it in to them?
Do you get free re-visits for other tunes?
thecamaroguy is offline   Reply With Quote
Old 08-19-2009, 10:44 AM   #9
SK360
Drives: 2005 Pontiac GTO
Sounds like you had Formato do your car, congrats bet it runs great now
I have seen some other complaints on the HPTuners forums about slow crank after tune too, you dont seem to be alone
SK360 is offline   Reply With Quote
Old 08-19-2009, 02:05 PM   #10
EAkrish
Scout Sniping
EAkrish's Avatar
I am going to try the ecu pull for one min, that seemed to do the trick
for others...
Eric
Old 08-19-2009, 02:35 PM   #11
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
i wanna know how he tuned the car with hpt. ur basically tuning blindly right now. it sucks.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 08-19-2009, 03:07 PM   #12
EAkrish
Scout Sniping
EAkrish's Avatar
He had to get some upgrade from hpt. He could only read my car at first. Then I came back the next day and he had bought updated software from them. He could watch everything that was going on just like he was tuning a 95 camaro. Looked the same. I got a street tune with o2 measurement for 100% accuacy. The car feels great! The only things I had done to it were cai, and a ported tb. It is way faster!
Eric
Old 08-19-2009, 05:27 PM   #13
EAkrish
Scout Sniping
EAkrish's Avatar
Worked like a charm!!! Thanks for the help.
Eric
Old 08-19-2009, 07:27 PM   #14
Mike TexaSS
Drives: 454 LS7 Camaro SS
Disconnecting the battery in the trunk works for me.
Mike TexaSS is offline   Reply With Quote
American Racing Headers for 2010 Camaro yields +32rwhp w/o tune, +50rwhp with tune ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 226 08-09-2013 06:01 PM
Do I really need a tune or will the Computer re-calibrate? Edrock Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 07-30-2009 02:56 PM
GMPP LNF Tune The_Blur General Automotive + Other Cars Discussion 22 01-07-2009 05:57 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
HP Tuners fullthrottle Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 08-27-2008 02:47 PM
