Solo Performance
Old 08-19-2009, 04:46 AM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Those who have done a HARD break in
How did you do it? I am considering MotoMan's procedure, but Im a little confused as to exactly when to change the oil for non-synthetic, before or after you do the steps, Id like to know if anyone did things his way or a little different. Thanks
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 08-19-2009, 09:03 AM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Yeah I want to make sure as well picking up my car next week in OH, 500 mile ride, and want to make sure I do it right. From what I have read, keep the speeds varied as well as the gears. keep the speed under 100mph and rpms under 4500.
mydreamcar is offline   Reply With Quote
Old 08-20-2009, 08:03 PM   #3
ALLT4
ALLT4's Avatar
Drives: 2010 Camaro 2SS RJT
Pffft, picked it up, got on highway and wound it out pretty good. Then varied speeds, 3/4 throttle accelerations, didn't really drive any differently than any other car I own. Hammer down, changed the oil at 500, re-set the life, and now am going to wait until like 1500, then regular oil changes when it tells me to.
I drove mine hard right off the lot and it seemed to get better and better. Now it seems to have settled in at 1000 miles, doesn't really feel any different with successive drives anymore.
Honestly I don't know if there is a right way or wrong way anymore unless you baby it toooo much.
To each his own though.
ALLT4 is offline   Reply With Quote
Old 08-22-2009, 05:32 AM   #4
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
I beat the he$$ out of mine from mile 7. I am going in for an oil change at 1k. I am at 730 currently.
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 08-22-2009, 09:25 AM   #5
slacker
Troubled 40 something
slacker's Avatar
Drives: 2010 IOM RS/SS M6
I'm using the DILYSI break in method, but I'm not running it to the ragged edge. I've read all the threads on proper break in, but honestly, I know some engineers and they create more problems for themselves by being so damn anal about everything. Don't beat it to death, but "Drive It Like You Stole It" has always worked for me- my first Grand National went 157k miles and never used a drop of oil.
My work truck- 05 Colorado - 193,000 miles, runs like a top, doesn't use any oil, works hard every day- the key is change the oil every 3500 miles. To open another box, I've never change transmission fluid or filter either on any car I've owned, and I've never had a transmission problem- examples 87 GN 157k, 86 GN 175k, 98 S10 253k, 05 Colorado 193k and counting....and all 4 of these were run hard.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=8680&dateline=1260288  130
slacker is offline   Reply With Quote
Old 08-22-2009, 11:30 AM   #6
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
I responded awhile back about this.. in essence, uncle GM engineer, dyno lab..always told me with my LSX engines to "drive hard". I did that with both Trans Am's upon delivery and never had a problem with either..NEVER!
Did the same thing with the Camaro.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-23-2009, 10:29 PM   #7
skisax80
Drives: 2010 camaro ss/rs
define drive hard if you would please...
skisax80 is offline   Reply With Quote
Old 08-24-2009, 12:48 AM   #8
ALLT4
ALLT4's Avatar
Basically disregard the owners manual. Lots of medium to 3/4 throttle accelerations to 5000 or 5500 RPM each shift until you attain the speed limit or whatever you're comfortable with. Personally I didn't want to get tooo close to redline until I felt it was fully broken in. You know, pretend you're half assed racing someone. But not to the full extreme redline. Do it a lot then some town driving normally mixed in. I'd get the oil changed quickly if you proceed like that, things will wear in a lot faster especially the rings and they will make particles in the oil. I changed mine at 500 miles and will do it again at 1500 but follow the life meter after that.
Best I can explain it.
Old 08-24-2009, 09:27 AM   #9
Banshee
Banshee's Avatar
Read the following site
http://www.mototuneusa.com/break_in_secrets.htm
Further explained in MANY threads in this break in section..just look at posts in last month or two.
Break In Period?!?!?! SimC33 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 87 07-07-2012 06:27 PM
How hard is it. . . 09fathomgreen Off-topic Discussions 7 10-14-2010 12:03 AM
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-05-2010 12:49 AM
Hard top--> top hard top convert YaKKO21 5th Gen Camaro SS LS LT General Discussions 12 04-13-2009 06:57 PM
Coupe, Vert, Hard Top Vert, T-Tops, or Removable Roof Panel? TAG UR IT 5th Gen Camaro SS LS LT General Discussions 42 08-02-2007 11:46 AM
