Old 08-19-2009, 08:07 PM   #1
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Strange "grind" in Reverse V6 M6
This has happened on two occasions, both times as I back the car out of the garage in the morning. Start it up, already in Reverse, release parking brake and go.
Sounds almost like I'm running over something plastic. Doesn't sound like a typical gear grind, but sounds like it's coming from the trans.
The car was clearly in gear all the way and I could move backwards like normal.
Anyone experience this?
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 08-20-2009, 05:04 PM   #2
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
grinding
Make sure the motor isn't torqued over causing an oxygen sensor or something to hit the trasmission shaft or drive shaft. Mine did in forward with hard acceleration. This was with after market headers.
nuptualnemesis is offline   Reply With Quote
Old 10-01-2009, 06:19 PM   #3
Den4176
El Maligno....
Den4176's Avatar
Drives: 2ss/rs,'10-E350, E46 328i
did you find out what the problem was? im having the same issue
Den4176 is offline   Reply With Quote
Old 10-01-2009, 06:23 PM   #4
Den4176
El Maligno....
Den4176's Avatar
edit: i thought that your car was a v8... anyhow what was the fix on your car?
Old 10-03-2009, 12:48 AM   #5
ckaram
ckaram's Avatar
I haven't heard the noise in about a month or so. I just wrote it off that I must not have had it fully in reverse even though I heard the "beep" and/or saw the R in the dash.
I also make sure I start the car in neutral and then go to reverse to ensure it's in gear versus just backing out of the garage after starting it in reverse from the night before.
Old 10-04-2009, 09:42 PM   #6
LyssaRaen
LyssaRaen's Avatar
Drives: 2010 SS/RS SIM W/ CGM Stripes
I've had a similar issue in a M6 V8. My fiance and I are honestly thinking that its the ABS system. I had hard braking instance that triggered the ABS and it was the same sound and feeling in the brake pedal, although, no dash light. I havent had the car back to the dealer yet, but its good to know someone else is having the issue.
LyssaRaen is offline   Reply With Quote
Old 10-14-2009, 03:30 PM   #7
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
I have the m6 v8 as well and have had this happen at least two to three times both in the morning, it sounds like your scraping your spoiler on something even though I know I'm not. I have 2800 miles on mine, I am wondering if I need to go have it checked out? I have not had any hard braking to activate the ABS so I will out rule that scenario.
Skyblu is offline   Reply With Quote
Old 10-14-2009, 05:16 PM   #8
ace2777
ace2777's Avatar
Drives: 2010 2SS RS Inferno Orange
This has happened to me also... in reverse with the wheel turned slightly its like a short grinding sound for just a second.
Any answers ???
IOM 2SS / RS / LS3 / IO INTERIOR
VORTECH V3 SI SUPERCHARGER
JRE UPGRADE KIT
AMERICAN RACING HEADERS
SOLO MACH-X CAT BACK EXHAUST
JRE CUSTOM TUNE
EIBACH PRO SPRINGS AND SWAYS
CATCH CAN
604 RWHP / 547 TQ
ace2777 is offline   Reply With Quote
Old 10-14-2009, 09:18 PM   #9
ckaram
ckaram's Avatar
I never heard it again. I now have about 3800 miles on the car.
Old 10-15-2009, 11:22 AM   #10
Skyblu
Skyblu's Avatar
Any answers ???
No, I haven't found out anything, it may be the brakes like someone else said but I have no idea.
Old 10-15-2009, 10:57 PM   #11
TGSS
Drives: 2010 1SS Camaro
Same thing happened to me. Usually happens when backing into the garage. I pull up to the driveway, clutch it, and go into reverse from a complete stop. After rolling back about 5 feet, I hear the noise. My wheels are generally turned slightly to the right when this happens. V8-M6. If anyone finds anything out, please let us know. Thanks.
TGSS is offline   Reply With Quote
Old 10-16-2009, 08:54 AM   #12
Wingnut
GOT IT....LOVE IT!!!
Wingnut's Avatar
Drives: 2010 2SS, Silver Ice
It's happening to me as well. When just starting in reverse....sounds like something breaking away as I start moving. I'm afraid it's in the transmission. The brakes are a different issues. I back down a steep incline out of my driveway.......I get about half-way down and the pedal gives some feedback and it's audible. Sounds like something is wrong, but it does it every time, consistantly, which points towards a normal mode of operation. The grinding is really concerning!~
2SS, Silver Ice......delivered June 10th!
Wingnut is offline   Reply With Quote
Old 10-19-2009, 01:09 PM   #13
Skyblu
Skyblu's Avatar
My husband told me he noticed me complaining about it the morning after I had washed it, so maybe it is the rust thing on the rotors? I'm going to try it again after I was it and see what happens.
Old 10-19-2009, 08:59 PM   #14
IAPCamaro
Drives: 2010 Camaro rs/ss
OK, so I am not going nuts and my 2010 manual trans with 1200 miles give the same noise. It almost sounds like a frog, very consistant and yet the car functions very normal. I have tried with the wheel slightly turned and straight as an arrow, it seems to happen either way flat surface or slant. This has to be some weird GM issue they decided not to inform all of us about. I am open to any and all input. I thought I would check here before taking it to my dealer. Thanks for any input.
IAPCamaro is offline   Reply With Quote
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 01-19-2018 05:18 AM
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
Is anyone else dissapointed by the V6 ENGINE COVER ?? Grandeos Cosmetics and Lighting Modification Discussions 59 11-01-2010 02:13 PM
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 03:41 PM
V8 appearance vs. V6 Discussion! jpsuperman81 5th Gen Camaro SS LS LT General Discussions 19 08-08-2009 10:01 AM
