BeckyD @ James Martin Chevy
Old 12-18-2009, 03:27 AM   #15
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
I have used "Invisible Glass" glass cleaner and a micro fiber cloth from WalMart to take off hard water spots from the paint and it works great also. It is ammonia free and it doesn't remove the wax.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline
Old 01-16-2010, 12:31 PM   #16
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
1/2 vinegar and 1/2 water did the job!!!
Iwantone2 is offline
Old 01-20-2010, 12:03 PM   #17
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
CamaroScotty is offline
Old 02-17-2010, 08:18 PM   #18
brtaus
brtaus's Avatar
Drives: None
Wish I would have known this years ago! It's Awesome!!!!
brtaus is offline
Old 02-22-2010, 02:53 PM   #19
kryologik
Drives: 2010 Camaro 2SS
I always keep a bottle of distilled white vinegar handy incase I need to wash my car other than somewhere at home.. If you always wash your car at home, you should look into buying an inline filter and softener for your house. A complete setup can run you like $120, but it's so worth it. You can spray your car down and have 0 water spots
kryologik is offline
Old 02-23-2010, 09:03 AM   #20
bucky1399
bucky1399
bucky1399's Avatar
Drives: 1LT, '99 Chevy ZR2
The vinegar will not hurt the clear coat?
bucky1399 is offline
Old 04-19-2010, 01:01 AM   #21
Mickalo
Who Dat?
Mickalo's Avatar
Drives: 2010 Camaro 2LT/RS A6
Send a message via Skype™ to Mickalo
Christ in a thread lol
Mickalo is offline
Old 05-04-2010, 03:55 PM   #22
CamaroScotty
BUMP for the Doc!
Old 05-30-2010, 11:17 PM   #23
tgblacker
tgblacker's Avatar
Drives: 2010 Camaro
Hi Scotty. I have this problem on my Black stripes and was wandering if I can use this method without harming the decal?
tgblacker is offline
Old 05-31-2010, 01:06 PM   #24
nice
2010 SSRS is offline
Old 06-12-2010, 08:49 PM   #25
CamaroScotty
Not sure....I'd be interested to know though.... you'd think that if it was "paint safe" it would be ok on taped stripes.
Old 08-03-2010, 11:43 AM   #26
Tati
I ♥ my Camaro
Tati's Avatar
Drives: Black 2LT, RS w/ Sunroof. SRY0FZR
Send a message via Yahoo to Tati
Can someone please open the document, copy and paste it. I can't open it, forces me to close it :( I have a black car and are very much in need of this instructions lol pleaseee!
You are what you drive!
Tati is offline
Old 08-19-2010, 11:31 AM   #27
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
How to Eliminate Water Spots
Get rid of them before they ruin your paint & glass
Leonard Emanuelson / autoMedia.com
Water should be a fairly harmless liquid. After all, we drink it, we bath in it and we even use water to wash our vehicles, so how bad could it be? The answer to that question depends on where you live and the minerals that are present in the local water supply. For example, the water in the Southwestern portion of the U.S. is full of hard mineral deposits that will literally etch themselves into paint and window glass if they are left on your vehicle for an extended period of time. Lawn sprinklers are the worst. Leave your vehicle where it gets water-spotted by the sprinklers, then baked by the sun, and the spots are not only difficult to remove, but they may do irreparable damage as well.
Offense, Defense
Like most problems, the best defense is a good offense. In this case, keeping a good coat of wax on your paint and window glass (that's right, use a glass wax) is the first line of defense against acid rain or water-spot etching. The second line of defense is to act fast to remove any water spots that may get on your vehicle. Time is relative. If you have a dark-colored vehicle and it stays out in the bright sun, you have less time to deal with the problem than a white vehicle in overcast conditions. It all has to do with surface temperature—the hotter it is, the tougher the water spots are to remove.
Removing water spots is fairly easy if you catch them soon enough. Re-washing your vehicle won't do a thing. Instead, mix up a solution of 1/2 distilled water and 1/2 distilled white vinegar in a spray bottle and carry it in your vehicle along with a soft, clean cloth. When you notice water spots, move the vehicle into the shade, let the surface cool down, spray the paint with this water/vinegar solution and wipe it off with the soft, clean cloth. The spots should come right off. Your waxed surface may be dulled by this solution, so apply a coat of wax when you get the chance
If you don't like the smell of vinegar and don't mind spending more money, commercial water-spot removers are available at most boat shops. They work the same way: Just spray the surface down and wipe off with a clean cloth. (I've found the white vinegar just as effective and a lot less expensive.) What if the water spots have gone too far and actually etched the clear coat of your paint or the window glass? More drastic measures are called for. For window glass, try a good dry scrubbing with 000-grade steel wool to remove the spots without damaging the glass. If that doesn't do the job, then the windows will have to be polished with a commercially available glass polish and a power buffer.
Because today's water-based paints are very delicate (especially the clearcoat), you'll want to experiment with the least-aggressive polish available. Try hand-polishing with a cleaner-type liquid wax. If the spots persist, then have a professional buff the surface with a fine polishing compound and machine buffer. Follow with a good hand waxing. Today's clearcoats are very soft and thin, so make sure that everyone who attacks water spots with a power buffer knows what they're doing. Ideally, you'll keep the water/vinegar "first aid kit" handy so that the water damage will never get to this point.
New vehicles and new paint jobs are expensive. Keeping your vehicle looking new will add miles of driving pleasure and protect your investment.
Tori
heRS is offline
Old 09-13-2010, 11:03 PM   #28
tronic
Drives: 2011 camaro ss rs IBM
Is it OK to use this solution to touch up other imperfections on the paint or should I only use it for water spots?
Also, can anyone tell me what they think of the Ammonia free Armor All window cleaner? I know not many people think that highly of their interior "protection" wipes.
tronic is offline
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 120 07-31-2016 06:37 PM
Expert?!?!?!? Michael Moore?!?!?!?!?!?!? Rogue Leader General Automotive + Other Cars Discussion 93 10-03-2010 02:57 PM
After claybar, there are still spots? sooner25 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 24 07-10-2009 12:09 PM
Water Spots !!!! fieldgoal00 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 10 06-19-2009 07:36 PM
California Water Blade xxbrankxx Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 7 06-04-2009 02:31 PM
