| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
RAM AIR MYTH OR TRUTH
Google is a powerful tool.
Marketers just can't resist it. Ram air! The words themselves summon up images of rushing wild beasts, or of secret military aircraft operating on futuristic principles. Unfortunately, on most perofrmance cars, ram-air is as functional as tail fins were on cars of the ’60s. What is it? Ram air just means using a forward-facing air intake to gain some extra intake pressure. We have all, as children, felt the pressure of moving air on our hands when we held them out the window of the family car. When moving air is brought smoothly to rest, the energy of its motion is converted into pressure. Motorcycles went through a "ram-air" period in the early 1990s, during which street bikes were equipped with the forward-facing "rocket-launcher" engine air intakes seen on many road-racing machines. While it's appealing to imagine the forward velocity of a car being converted into free supercharge, the actual air pressure gain is extremely small at normal speeds. For example, at 150 mph, the pressure gain when air is efficiently brought to rest is 2.75 percent. Because this is a dynamic effect, it is proportional to the square of the air velocity. At a more realizable automobile speed of 75 mph, the effect (again with 100 percent efficient conversion of velocity into pressure) will be only one-quarter as great — that is, just under seven-tenths of one percent. In fact, velocity energy is not converted into pressure at 100 percent efficiency. A figure of 75 percent efficiency is usual, which reduces our notional ram-air gain at 75 mph to one-half of one percent. Therefore, at normal speeds, ram air is a myth. However, something much more interesting lies behind it, ignored by the advertiser's busy pen. That something is airbox resonance. In order to implement ram air, the carburetors or throttle-bodies of our engine must seal to an airbox whose volume is large enough that the intake cycle of one cylinder cannot pull its internal pressure down significantly. Box volume is typically 10-20 times the engine's displacement. Then the forward-facing air intake is connected to the box. When this assembly is tested on the dyno — even without an external fan to simulate the high-speed rush of air past the intake — it is discovered that the engine's torque curve is greatly altered, with new peaks and hollows. Why? The answer is airbox resonance. If you hold the mouth of an empty bottle near your open mouth as you loudly hum scales, you find that at certain “hum frequencies” the bottle reinforces your humming, which becomes louder. What is happening is that the springy compressibility of the air in the bottle is bouncing the slug of air in the bottle's neck back and forth at a particular frequency — higher if the bottle is small, lower if it is larger. Your humming is driving a rapid plus-and-minus variation of the air pressure inside the bottle. The same thing happens inside a resonant airbox. The volume of air in the box is the “spring” in this kind of oscillator. The mass of air in the box's intake pipe is what oscillates. The “humming” that drives the oscillation is the rapid succession of suction pulses at the carb or throttle-body intakes. If the volume of the airbox and the dimensions of the intake pipe(s) are correctly chosen, the airbox can be made to resonate very strongly, in step with the engine's suction pulses. The result, when this is done correctly, is that the engine takes air from the box only during the high-pressure part of its cycle, while the box refills from atmosphere through its intake between engine suction pulses. This produces a useful gain in torque. Using this idea, motorcycle engines have been able to realize torque increases, in particular speed ranges, of 10-15 percent. In race engines, it is usual to tune the airbox to resonate at peak-power rpm to increase top speed. For production engines, it is often more useful to tune the box resonance to fill in what would otherwise be a flat-spot in the torque curve, resulting in smoother power and improved acceleration. Early resonant airbox systems used long intake pipes that terminated in forward-facing intakes. More recent designs do not connect the ram-air pipe to the box at all, but terminate it near the airbox entry. The actual entry pipe is a short piece of tubing with bellmouths on both ends. This is done because (a) the potential gain from actual ram air is too small to worry about, and (b) it's easier to tune the airbox with a short tube. Where vehicle speeds are very high, gains from ram air are significant. This was discovered by Rolls-Royce in the late 1920s as the company developed its R Schneider Trophy air racing engine. At speeds above 300 mph, it was noticed that the R’s fuel mixture leaned out enough to cause backfiring. When the mixture was corrected for ram-air pressure gain, the engineers realized they had a "free" source of power. At 350 mph the gain from ram air is almost 15 percent. Similar mixture correction is necessary when ram air is used on drag-race and Bonneville cars and bikes. Intuition suggests that a forward-facing intake made in the form of a funnel, large end foremost, should somehow multiply the pressure of the air, resulting in a much larger pressure gain at the small end. Sadly, intuition is wrong. In order to convert velocity energy into pressure, the air has to be slowed down, and this requires a duct that widens rather than narrows. Next time you fly on a commercial airliner, note that its engine intakes widen as the airflow approaches the compressor face. Such widening passages are called diffusers, and they are universally used in the conversion of velocity into pressure. Language often plays tricks on us — especially when language is used by product advertisers. "Ram air" sounds much more appealing than "resonant airbox." Nevertheless, it is airbox resonance that actually generates a significant power gain. ------------------------------------------------------------------ Cliffnotes: -Ram Air a myth? = NO -Does it work on a road car = NO -At 150mhp there is next to no gain. -Significant gains arn't seen until 300mph+ -The air box is the key, not the ducting. -When buying a CAI/induction kit look for the one that uses air box resonance Edit: Additional Reading Intake temperature is a whole different ball game. The simple rule is: 'Cool for power (maximum charge density), hot for economy (minimum charge density to reduce losses due to throttling).' Although in many cars the under bonnent temperatures are no where near as bad as many people beleive. This refers to a 5.3 liter Jguar XJS V12. So a big engine in a small engine bay. The under-bonnet air temperature at idle can easily get up around 70 C but the faster the car goes the lower the air temperature falls - simply because the radiator is passing its heat to a much larger quantity of air per second - so at 80 mph. the engine is breathing air at around 45 C. That's still a bit higher than the ideal but not nearly so bad as many people think. Obviously the standard arrangement helps to maximise economy in moderate speed urban cruise without compromising top end power too much. In setups that duct cool air from outside. The power gains from such a system are almost certainly attributed to the filter, and less restritive intake (meaning quite simply a bigger opening), and a form of air box resonance coupled with a 'cool air intake' from outside the engine bay. Sadly even at very high speeds (well over 100mph) I doubt that it has any form of 'Ram Air' effect. If you reconfigured the system to take air from the inside of a wheel arch it would produce the same results as having the intake ducts at the front of the car. The source of the air, not the location of the ducts is the important factor. Remember the only way to get a greater volume of air into the engine is to compress it. This is what turbo and superchargers do. An air intake scoop either on the front of a car or on the bonnet will not compress the air at any speed most people are likely to travel at. Taking the airbox resonance theory futher with the intake manifold itself by optimising the length and entry profile into each of the tracts to better exploit induced harmonic resonances in the air as it flows towards the cylinder. Any tube containing air can be made to resonate at certain critical frequencies in the manner of an organ pipe. Such is the case with the inlet tracts of an engine and if the natural resonance frequencies can be matched to the engine speed then a mild supercharging effect can be induced. Get it wrong and the reverse will apply, resulting in a loss of performance.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
#3 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
Let's not F up all this ram air hype going on all over this sub-forum around all these CAIs. Perception is reality in the consumer's mind. We all "believe" that Ram-Air works. Therefore is does. Since this belief "Makes" it true, manufactures build our perceptions into reality.
#4 | |
Dances With Mustangs
Good post! Lots of worthwhile info here.
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#6 |
Ram Air look cool though. Doesn't it!
#7 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
WOW - great reading. This must be the information I heard about.
Thanks for sharing. That's very interesting info'. I wonder if that's why some of the prototype pics' we've been given has had some of the obstructions to seeing the entire kit, like there have been. I remember there being rags and such placed over the TB opening and the actual air boxes in a couple instances. Very interesting...
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#8 | |
#9 |
Good Reading back from the Archives.
#10 |
![]() Drives: it like I stole it. Join Date: Feb 2010
So you are saying I should abandon Project RamRod!
![]() In all seriousness, that is some interesting info. Nice work.
#11 |
H-Town Camaro Club
#12 |
![]() Drives: '10 2SS S/C'd, '12 Challenger SRT8 Join Date: May 2010
On our racebikes we found that with a VERY efficient ram air system and sealed air box we didn't see any positive pressure to offset the vaccum on the engine till at least 90 mph.
Keep in mind, this is on a much smaller engine; 600cc's. I wouldn't even want to try to figure out at what point a 6.2 V8;s vacuum would be overcome. Good info, thanks Ted! |
#13 |
I can't take any credit for it, I Researched it and this was a product of my research.
I just thought it makes good discussion and education for those who are mislead by advertising. Ted.
#14 |
Watch This!
Drives: Super Charged 1SS/RS, M6, CGM Join Date: Dec 2009
So as we come to the anniversary of this thread, the only thing left for all the money I have spent is the "coolness" factor, OK, It's All Good
K&N CAI, Wet Okole Seat Covers, MagnaFlow Street Perf. Ex. (Axle Back), MPD Hood, Gary's Customz ZL1 Fascia/Vented Fenders/Custom Stripes/Paint, AAC Afterburners/Fog Light Halos/Side Markers/Misc LEDs, Bee-Otch Air Freshener, Hurst Shifter and Line-Loc(APEX), RPI Splash Guards, MagnaCharger (Texas-Speed)(Installed by ME), Rx Catch Can and Breather, Billet Pulleys (SC2150),Custom Tune 542rwhp, 513rwtorq (MTI), Boost Gauge and Single Pod (MTI)
#15 | |
![]() ![]() Drives: C63 P31 Join Date: Feb 2010
They measured MAP in KPa and explained for their "testing, 100 KPa roughly represents normal atmospheric conditions and shows that the engine is consuming air without any restriction. Numbers higher than 100 represent extra air that is being forced into the intake by a "ram-air" effect, while lower numbers show a slight vacuum in the intake manifold." Most of the intakes that they tested showed a slight vacuum between 40 and 75 mph, with numbers slightly less than 100 KPa, but there were a few intakes like the ADM street intake, for example, that maintained a 100 KPa result for one of the two runs that were performed for each intake. The AFE intake showed 102 KPa at 40 mph, 101 Kpa at 52 mph, 100 KPa at 63 mph, and 101 Kpa at 75 mph. Granted, there were a number of other relevant factors to consider for this group comparison, such as IAT drop, outside air temperature, and hp/tq gains. It was a very interesting article. I'm not claiming to know the answer on the ram-air debate, but I just wanted to point out these findings given your mention about when the vacuum is overcome on our engines. |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
The idea of ram air, back in its day was quite effective, but not in the way it implies. The early big block cars from the factory were feeding air through a 12" long snorkel with a 1 1/2" openning, adding any free flowing filter arangement had great bennefits in itself. Also keep in mind ram air was designed in the day of normally aspirated engines, an increase in air velocity does affect the the way a carburetor performs differently than it does fuel injection. In the case of Harley's longer intake tracks produce more power in general and "ram air" via velocity stacks etc. inreases air velocity, this along with the scavenging effect created by exhaust gases when the valves are in the overlap position produces significant hp gains, again on carburetored engines. With all that said the the early muscle car years with large hood scoops,cowl induction and ram air will always be what we think of when it comes to performance, it's in our blood, I'll even go as far as saying our kids will be putting scoops on their electric cars.
#17 |
![]() Drives: 2010 SS/RS M6 Join Date: Nov 2009
The true mystery here is how Mr. Ted Jannetty builds all these cool cars when he spends 23 hours a day on this forum.
![]() Mav
SS/RS M6, SIM, CGM stripes, Barton S/T, BMR trailing arms, ADM Race intake(no scoop), Texas Speed 1 7/8" headers and full 3" exhaust, RMCR custom tune.
#18 |
Ram Air only works on SCRAM jets
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
So you are saying that the CAI such as Vararam is not letting any more air in as like the CAI, K&N, RotoFab etc..... Performance of the Ram Air CAI would only work if you were going like 300 MPH?????
#21 |
Yep. That's why most people now are calling them a OTR (over the radiator) CAI and getting away from calling them a Ram Air CAI.
#22 |
Ahhh, I see. A friend of mine had a normal CAI (cant remember what brand), but someone (his mechanic) told him he needed a Vararam OTR so he could get more air flow in, for more HP, since he had a cam in it.
#23 |
speed freak
Drives: 2012 Cadillac Escalade,10 IOM 2ss Join Date: Jun 2009
Good read Ted
Current:2012 Cadilac Escalade.2011 CVO StreetGlide cammed,tuned&loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779
Del 7/10/09 Former Camaros 72 LT1 Z28, 86 z28 |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) JRE tuned Aint nobody got time for that |
#25 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS L99 Join Date: Nov 2009
So how does the LS1 WS6 get its extra 15hp? It has the same airbox as the normal Trans Am right? So was GM just lying to all who bought the car saying it had 325hp when it only had 310? Just wondering.
| Thread Tools | |
| g5cr cai system anybody install or looking at one "pics" | camarossrs2150 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 07-14-2011 08:26 PM |
| Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
| List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
| AirAid Cold Air Intake anyone? | Flynnaz | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 09:05 PM |
| Ram air kits ? | danraz98 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 05-24-2009 01:10 PM |
