JDP Motorsports
Old 08-20-2009, 11:47 AM   #1
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
TVS 2300 / Supercharger CAM Results and thoughts
Since my other thread jumps around, let me post up the results with different pulley sizes in one post.
Modifications: TVS 2300, Blower Cam (ADM Spec'd), ADM Intake (street version), ARH Catted header system with stock axelback (this will go for a full 3 inch magnaflow axelback soon), Tuned by ADM.
Below is the stock 3.8 pulley. This is what I went with since this is my daily driver. The tune is very conservative and this is what I will run for a while.
Below is the comparision between the 3.6 and 3.4 pullys: With the 3.4 pulley we had belt slip up top or we would have made well over 600rwhp .. look at the TQ curve for both of these ... really nice I'd like to maybe try the 3.6 eventually since we had no slip with that ... but again .. for my daily driver we want safe
Below is the 3.4 with belt slip (see post above ). This is compared to my stock dyno and my dyno with the ARH catted system and tune.
ADM still has the car as he is fitting me with his new Boost gauge so I haven't gotten a chance to drive it yet. Once I do, you will have more pics, vids and my thoughts. Go here for pics of the gauge and location: http://www.camaro5.com/forums/showthread.php?t=38289
Thanks,
Crowley
Crowley is offline   Reply With Quote
Old 08-20-2009, 12:18 PM   #2
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
Thanks,
Crowley
Why is the belt slipping??
Can you get a tighter belt??
rpepka is offline   Reply With Quote
Old 08-20-2009, 01:00 PM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
It is recomended at the boost range to have a larger ribbed pulley. They are coming out with them very soon if they aren't already out
Old 08-20-2009, 01:36 PM   #4
ADM PERFORMANCE
Drives: 2016 CAMARO SS
10 rib is required...hence ZR-1 runs over 10psi with a 2300
Also very high octane is required with stock compression
Ls3 when 10 psi and above.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 08-20-2009, 01:40 PM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Andy
Thanks for coming in Andy .... Since this is my Daily Driver, I won't be running very high octane ... maybe at the track someday with the boost turned up some
Old 08-20-2009, 04:21 PM   #6
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Can you define Very High octane?
93? 100?
Crowley,
If you wouldn't mind, not sure if you posted this anywhere else, PMing me the price tag for the parts on your build... If not I completely understand.
Old 08-20-2009, 04:39 PM   #7
vsgls1
vsgls1's Avatar
Drives: 07 GMC Sierra
Send a message via AIM to vsgls1
Are you still using the kit injectors?
Keith 2SS/RS MN6 in CGM. Delivered 6/22/09. Blown 7/29/09. Sold 12/6/10.
07 GMC Sierra
vsgls1 is offline   Reply With Quote
Old 08-20-2009, 07:14 PM   #8
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
With you living in McKinney just hit 75 and go north to Exit 51 and poof 100 octane race gas in a pump at the Exxon on the NE Corner of the service rd and whatever exit 51 is.
Spent many a day making that drive for my ADM built toy....
ADD THE OCTANE and UP THE BOOST!
KUDOS to you and Andy both!
Pure artwork as always Andy!
Pat
freemaSSon is offline   Reply With Quote
Old 08-20-2009, 07:19 PM   #9
ADM PERFORMANCE
93? 100?
Crowley,
We use 100 octane fuel for safety.
I personally think 550-580 is a bit high for stock internals.Back in 2001-2004 we built Twin Turbo Stage 2(Forged bottom end ls1) LPE Corvettes and we were happy with 550-580 rwhp, it was rated at 650 flywheel.
Andy
Old 08-20-2009, 07:21 PM   #10
ADM PERFORMANCE
Pat
Were you come from.......
Old 08-20-2009, 07:24 PM   #11
freemaSSon
freemaSSon's Avatar
SHOPPING....what else would I be doing......
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
Old 08-20-2009, 08:42 PM   #12
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
What up Pat?!
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 08-21-2009, 08:06 AM   #13
old motorhead
Drives: Maggie blown LS3 vette
Just curious what your cam specs are. Or, are they "secret"? If you open that exhaust, you might not need to go to a wider belt. Im making 8.5 psi on my LS3 2300 with 2.9" pulley and stock width belt. No slip.
old motorhead is offline   Reply With Quote
Old 08-21-2009, 09:39 AM   #14
ADM PERFORMANCE
I left the 3.8 belt on when I changed pulley.Looked like enough load....but was not.
I recommend 10+ ribs for more than 10 psi,8.5 should be fine.
We run a real tight lobe seperation.
Andy
