Caryle Racing
Old 08-20-2009, 03:13 PM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
My L99 Case is Closed.
Got the call from GM and my case is closed. The car thinking it was running on 87 Octane is all they found wrong and they just reset that. They said that is it and all is well.
End of my story.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-20-2009, 03:14 PM   #2
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 08-20-2009, 03:15 PM   #3
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Well sounds like there are many on this board who have the same problem. We could sure use your help to let everyone else with sluggish problems know the potential problem and solution.
Hylton is offline   Reply With Quote
Old 08-20-2009, 03:17 PM   #4
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Amen..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 08-20-2009, 03:24 PM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Scott,
Are you still happy with the performance of your car? Seems to be completly resolved now?
Old 08-20-2009, 03:27 PM   #6
Scott@Bjorn3D
Moves pretty good, 2010 GT tried to get away from me at a stop light the other day. I was right behind him and the light changed. He jumped and smoked his but I caught him right on his bumper. I backed off at the speed limit of 50.
Video I made last weekend showed 0-60 in 5.0 second. So looks like it is working Chris.
Old 08-20-2009, 03:28 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Old 08-20-2009, 03:32 PM   #8
Slvr1SSA6
Slvr1SSA6's Avatar
Drives: 2010 1SS A6---1968 SS Camaro
I hope GM is on this with a TSB soon, so the rest that have issues can get this taken care of.
2010 Camaro SS A6
http://www.indycamaro.com
1968 Camaro SS 396
512 CI BBC producing 653 RWHP @ 6400 RPM
Slvr1SSA6 is offline   Reply With Quote
Old 08-20-2009, 03:48 PM   #9
Multi-Ball
Multi-Ball's Avatar
Drives: White 1SS
What can the "normal" person do to reset the timing curves? Does everyone need GM to come to there homes to reset the curves?
Multi-Ball is offline   Reply With Quote
Old 08-20-2009, 03:53 PM   #10
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
So what if Scott puts 87 back in his car accidentally...Is he hosed again... This is not good news!!! especially since they didn't change out a defective ECM.
I have no clue what my dealer put in on delivery but I have run 93 ever since...
This would affect LS3s also
Old 08-20-2009, 03:55 PM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
What happens if you accidentally put in 87 or even 89 ocatane again? I'm sure you don't want to test that but while the GM guys had your case open that should have been one of the tests. That way they can determine if it was a fluke bug or if anytime someone puts in a low octane it's not re-learning properly (a flagrent - needs to be fixed bug).
Build Journal
Old 08-20-2009, 03:59 PM   #12
GTAHVIT
Blessed
GTAHVIT's Avatar
The LS3 tune is completely different than the L99. Remember the L99 has Variable Valve Timing and Cylinder Deactivation...
That will require completely differents tunes/programs. From what I've been able to learn from some of our insiders. This issue is only found in the L99 tune.
FWIW
Welcome back BTW!
Old 08-20-2009, 04:01 PM   #13
Supermans
Supermans's Avatar
It is interesting to know if GM is going to make any changes to the ECU programming down the road or not.. If they are closing the case, what exactly does that mean for those still affected and what does it mean for Scott if he puts in a lower octane gas..
Old 08-20-2009, 04:09 PM   #14
jhmurphy
jhmurphy's Avatar
Drives: Grey Beast
End of my story.
Scott
Did they say if or when they might have a fix for the rest of us?
jhmurphy is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
VIN decoding, Check Digit Help PAUL SS 5th Gen Camaro SS LS LT General Discussions 5 04-29-2009 04:51 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
