SDTW Custom Wheels & Tires
Old 08-20-2009, 07:52 PM   #1
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Exclamation Blackstone Labs OIL report at 1270 miles...
As reported on homepage.
Hey everyone!
Most of the time I do an oil report from Blackstone Labs on a few of my cars to see what is going on inside, kinda like blood work Anyway, for the heck of it, I sent in my first oil sample from the new Camaro, at it was at 1270 miles. Here is what the oil experts had to say:
We typically find a lot of metals and silicon in the oil from new engines. The metals are from new parts wearing in while the silicon is from lubes and sealers used during engine assembly. All should decrease after future oil changes, with copper taking the longest to settle down. Oil filtration (see insolubles) was excellent and we did not find any moisture, coolant, or gasoline in the oil. This type of V-8 takes its time wearing-in so we suggest short (~1500-mile) oil changes as a steady diet up to ~10,000 miles. This should be a nice engine for you.
I can send the file to someone w/ ALL of the metal wear stats, ect. This is a very nice lengthy report, and if you are interested in seeing all the metal wear, info, ect. just send me a PM.
I have been using Blackstone Labs since 99 and they have been right on every time....
Thought I would share
Angela
350 HRSS is offline   Reply With Quote
Old 08-20-2009, 08:56 PM   #2
nassau97
Drives: 2010 2SS/RS, 97 Vette 91 Vette
very interesting, thanks for sharing
nassau97 is offline   Reply With Quote
Old 08-20-2009, 09:03 PM   #3
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
If you want to send me the file I'll change it to pdf and host it.
"everyone wants to go to heaven. but nobody wants to die" "you gotta pay to play"
SEMA PICTURES-PARTS & CARS
http://www.pbase.com/haveblue/sema_2009
HaveBlue is offline   Reply With Quote
Old 08-20-2009, 09:25 PM   #4
GEN-IV
HEMI Hunter
GEN-IV's Avatar
Drives: 06 GTO / 79 Z28
Change the oil every 1,500 miles till 10,000? Wow, interesting suggestion.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 08-20-2009, 11:12 PM   #5
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
I would be interested in seeing the full file as well, and will see about getting mine done as well after a) break-in and b) after 5,000 km
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 08-21-2009, 12:38 AM   #6
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
I'm breaking mine in with measured run-ups in 2nd gear and then backing off the gas and letting the engine slow down the car with engine braking. I changed the oil and filter at 65 miles to clear out the metals and junk that were in there from assembly at the plant. I switched to non-synthetic to aid in the break-in and because I'm going to change it again at 1500 miles. The synthetics are too good and can actually interfere with engine break-in and rings seating properly.
Another reason for changing the oil and filter at 65 miles was to make sure I wasn't circulating those metals and stuff through the engine and everything else while breaking in the engine. At 1500 miles I'll change to a synthetic; break-in will be done by then.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 08-21-2009, 08:51 AM   #7
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
I can do that....can you PM me your email address?
Thanks!
Angela
Old 08-21-2009, 11:14 AM   #8
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Blackstone is EXCELLENT! I used them for both my 98 and 02 WS6's. I had 165k on the 98 when sold in Feb. The LSX engines are great if you take care of them. She didn't blow any oil, burned none and the reports came back excellent up until last check at 158k.
Pennzoil Platinum oil, K&N/Mobil1 filters and changed every 5-7k. Broke it in hard and never babied her.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-21-2009, 11:20 AM   #9
Tran
Administrator
Tran's Avatar
Oil report attached to first post.
Old 08-21-2009, 11:44 AM   #10
Zeus95
Zeus95's Avatar
Drives: IOM 2010 - 2SS/RS
Excellent info. I changed mine at 900miles and then again at 5000 miles, so a little late for me to do the 1500 mile thing. But this Mobile 1 Syhetic isn't cheap ! Thanks again, nice stuff.
2010 2SS/RS IOM Upgrades: Fastlane CAI / SLP II Loudmouth axle back / V Max Ported TB / Kook's Step Long Tube Headers / High flow cats / Straightline Tune / BMR front & rear sway bars / Hotchkin End Links / Hurst Short Throw. LG ZR28 Wheels 1 of 2 sets made. Pfadt trailing arms / Diff Bushings & Sub Frame bushings / 1LE Axle & Hubs.
Zeus95 is offline   Reply With Quote
Old 08-21-2009, 12:37 PM   #11
rcracer78
rcracer78's Avatar
I've seen this on other automotive and motorcycle forums. It seems logical. Will I void my warranty if I take out the synthetic? Once I hit 1500 miles I'll replace with synthetic again.
rcracer78 is offline   Reply With Quote
Old 08-21-2009, 12:58 PM   #12
HARD CORE MUSCLE
Drives: Muscle Cars
Thanks for the info!!
HARD CORE MUSCLE is offline   Reply With Quote
Old 08-21-2009, 01:08 PM   #13
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
1500,4500,6000,7500,9000...then what? when the computer tells you to change it?
Moorepheus is offline   Reply With Quote
Old 08-21-2009, 01:41 PM   #14
manimsoblack
manimsoblack's Avatar
Drives: 04 Pontiac Grand Am, 08 Ninja 650r
wow that'd be every week and a half for me...
Originally Posted by Kyle2k View Post
You take a shit on everything fun and good on this forum.
manimsoblack is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
