BeckyD@RodgersChevrolet
Old 08-20-2009, 08:08 PM   #1
V-6_2010_Camaro_Owner
Drives: 2010 Camaro
Moisture in trunk
I found moisture in the trunk under the carpet, it seems that the drivers side trunk vent (behind the carpet wall) allows water to enter when driving in rainy conditions. Now my carpet padding stinks!
Hopeful resolution, I removed the trunk vent and applied a bead (length wise) of silicone to the outside surface to both rubber flaps. This adds weight (not too much) to the flaps, and hopefully resolves the moisture and fine dust that enters into the trunk.
V-6_2010_Camaro_Owner is offline   Reply With Quote
Old 08-20-2009, 10:45 PM   #2
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
You should be doing nothing..........that is a warranty issue.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 08-20-2009, 10:48 PM   #3
MasterZ
MasterZ's Avatar
Drives: 2010 Camaro SS/RS
2014 C7 Z51~ M7 custom paint,
Mods soon to come, researching at the moment.
MasterZ is offline   Reply With Quote
Old 08-21-2009, 12:49 PM   #4
Speedy One
Where are the vents located exactly and how do you get to them ?
Speedy One is offline   Reply With Quote
Old 08-21-2009, 09:32 PM   #5
WorldClassRS
Drives: 2010 RJT LT/RS
Those vent are to allow air to escape from the vehicle like when you shut the doors with the windows closed. It is highly unlikely that is where you are getting water from. You really should let the dealer look at it for the water leak.
WorldClassRS is offline   Reply With Quote
Old 08-21-2009, 09:34 PM   #6
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Originally Posted by MasterZ View Post
Old 09-14-2009, 09:21 PM   #7
Drives: 2010 Camaro
Well the the moisture; hell water is still coming inside the trunk. Not sure where the problem is located.
Back to the dealership...
Old 09-14-2009, 09:26 PM   #8
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
Have them check the weatherstripping on the bottom of the rear windshield. There are many coming mis-installed, which is allowing water to flow down the rear windshield and into the area surrounding the trunk. Really, it should get into the trunk from there, as the lid is shut and the stripping around the opening forms a seal with the lid, but I would still have them check it.
Just my $0.02, as someone who has an issue with his weatherstripping (and is in a long line of those waiting for GM to release a replacement part to the dealerships.)
Number_9 is offline   Reply With Quote
Old 09-14-2009, 09:55 PM   #9
coolman
Guest
Get in the trunk with a flash lite, and have someone shut the lid and run water from a hose down over the car to see where the water is coming from. I had a car that the rear window leaked and caused this.
coolman is offline   Reply With Quote
trunk release problems camaro guy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 36 04-21-2017 05:31 PM
DIY Trunk Velcro Mod TAG UR IT Camaro DIY & HOW-TO instructions & discussions 28 03-18-2011 09:18 AM
Problem with Trunk not locking? Shipsinaday.com Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 06-26-2009 04:08 PM
Gap below trunk lid scorpio 5th Gen Camaro SS LS LT General Discussions 8 09-24-2008 09:09 AM
