Old 08-21-2009, 01:07 AM   #1
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
Send a message via AIM to LS 1st gen
TSB listing?
Just a thought:
About this stage in the game of the 2004 GTO introduction, someone over on LS1gto.com was keeping a running list of Techinical Service Bullitins and the possible VIN ranges effected. This kind of list would help us out immensly.
Does anyone have access to, and the willingness to post such a list? Is there a liability involved in doing so?
Knowledge is power!
GORDON 2010 Camaro # 13694 Victory Red 2SS manual | White rally Stripes | Polished Wheels | Rotofab CAI| MGW Shifter| Kooks LT's| Magnaflow X-pipe|FM 40 Delta Flows | Elite Tunnel Brace | "Ginger"
LS 1st gen is offline   Reply With Quote
Old 08-21-2009, 10:34 AM   #2
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
i checked a few weeks ago and there really wasnt anything to report,nothing new anyway that wasnt already all over the boards but i posted what i had its on here somewhere
firestone_ss is offline   Reply With Quote
Old 08-21-2009, 10:28 PM   #3
WorldClassRS
Drives: 2010 RJT LT/RS
Here you go.
Technical
#09-08-44-015A: Radio Display Screen Scratches and Scuffs (Polish Display Screen) - (Aug 18, 2009)
#05-06-01-034G: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) - (Aug 12, 2009)
#09-06-03-004A: Intermittent Illumination of MIL, Service Lamps, Service Messages or DTC Set by Various Control Modules-Diagnosing and Repairing Fretting Corrosion (Disconnect Affected Connector and Apply Dielectric - (Aug 10, 2009)
#09-01-38-003A: Moisture from Center HVAC Vent When A/C is On, Front and Back Floor Carpet Wet (Realign A/C Drain Tube) - (Aug 5, 2009)
#07-08-46-002D: Audio Whine Noise from Radio Speakers When using OnStar (Install Noise Suppression Filter) - (Jul 29, 2009)
#09-08-42-005: Driver/Passenger Door Accent Lighting-Light Bar (Pipe) Inoperative or Loses Intensity (Check Light Bar (Pipe) Attachments, If Necessary) - (Jul 7, 2009)
#09-01-37-001: Gurgle Type Noise Coming from Instrument Panel (IP)/Heater Core Area (Perform Repair as Outlined) - (Jun 24, 2009)
#09-08-64-026: Front Side Door Window Squeaking Noise, Reversal During Express Up (Align/Replace Weatherstrip) - (Jun 22, 2009)
#05-08-51-008C: Bumps or Rust Colored Spots in Paint Due to Rail or Iron Dust (Remove Rail Dust) - (Jun 22, 2009)
#03-08-44-005I: Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids May Be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) - (Jun 18, 2009)
#09-08-49-011: Instrument Panel Cluster (IPC) Needle(s) Stick Intermittently (Replace Instrument Panel Cluster) - (Jun 15, 2009)
#99-01-39-004C: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating) - (Jun 12, 2009)
#09-07-29-002: Squeak Noise from Manual Transmission Shifter (Remove Material from Silver Cover) - (Jun 12, 2009)
#09-08-50-009A: Scraping/Moaning/Creaking Noise from Front Seats (Apply Lubricant) - (Jun 4, 2009)
#09-08-110-012: Windshield Side Garnish Molding Itching Noise (Install Adhesive Flocking Material to Mounting Tab) - (May 26, 2009)
#05-03-10-003D: Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) - (May 11, 2009)
#09-08-110-010: Rattle Noise in Rear Window Panel Trim (Install Adhesive-Backed Shim Stock) - (May 6, 2009)
#09-08-49-007: Instrument Panel Cluster Trim Plate Squeak and Rattle Noise (Install Anti-Squeak Fil Tape and Adhesive-Backed Flocking Material) - (May 4, 2009)
#09-08-48-003: Creaking/Itching Noise from Lower Windshield Area/Upper Instrument Panel Area (Add Foam Tape to Air Inlet Panel, Re-fit Windshield) - (Apr 9, 2009)
#09-08-48-002A: Marks/Stains on Windshield When Wet (Clean Windshield) - (Mar 19, 2009)
#09-08-64-006: Driver and/or Passenger Door Hinge Creak (Apply Lubricant to Check Links) - (Mar 13, 2009)
WorldClassRS is offline   Reply With Quote
Old 08-22-2009, 09:22 AM   #4
Looney Tunes
Drives: 2010 Camaro 2LT ABM auto
great list! thx
Looney Tunes is offline   Reply With Quote
Old 08-28-2009, 10:31 PM   #5
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
I think we should definitely keep this updated...TSB's are released all of the time.
Old 08-30-2009, 11:00 AM   #6
Looney Tunes
I agree, is there a way to make this a "sticky"?
Old 08-31-2009, 12:54 PM   #7
3BVert
3BVert's Avatar
Drives: 2010 Camaro 2SS/RS
Any info on a TSB for a V8 "lag/sag problem from a start of about 10 MPH" mentioned in this thread: http://www.camaro5.com/forums/showthread.php?t=39758?
We've got a few small issues to take to the shop and we have a noticable lag/sag problem when accellerating at a slow speed. Information on a TSB would be good to have going in.
Thanks!
2SS/RS Red Jewel Tintcoat
6-Speed Automatic
3BVert is offline   Reply With Quote
Old 09-01-2009, 11:20 PM   #8
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
So far I have the following 2:
#09-08-42-005
#99-01-39-004C
I wonder when we will see a TSB for the leakey master cylinder and the crappy 3rd gear synchro?
(also issues I'm experiencing)
Old 09-28-2009, 07:29 AM   #9
Verio
Taking it 1 day at a time
Verio's Avatar
Drives: 2010 Chevy Camaro 2SS/RS Auto
Send a message via MSN to Verio
Any updates in the last month?
Order#: NJWGTF
1100, Preliminary order accepted 04/27/2009
6000, Delivered to the customer 07/23/2009 - 3 Months (worth the wait!!)
Verio is offline   Reply With Quote
Old 09-29-2009, 05:12 PM   #10
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Anyone Know if there is a TSB for noisy lifters?
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
TSB for 2010 Camaro buddylok Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 09-28-2010 02:27 PM
Camaro Listing Question mikeyp15 5th Gen Camaro SS LS LT General Discussions 9 07-26-2009 07:17 PM
Chevy.com Inventory Listing turftide Camaro Price | Ordering | Tracking | Dealers Discussions 0 06-16-2009 06:57 PM
Private listing for selling your exisiting car jdanza General Automotive + Other Cars Discussion 22 05-25-2009 11:48 AM
