Old 08-21-2009, 09:10 AM   #1
Speedy One
Drives: 2010 Camaro SS/RS
CLUNKING NOISE IN FRONT END
I have noitced a slight clunking noise that sounds like it is coming from the front suspension when going over bumps in the pavement. I only have 500 miles on, but it seems to be gradually getting more noticable. Anyone else experiancing this ? Would appreciate your input.
Speedy One
Speedy One is offline   Reply With Quote
Old 08-22-2009, 03:17 PM   #2
TooCool5
Resident Gearhead
TooCool5's Avatar
Take it in for an inspection. A nut or sway bar could be loose in the front end.
Old 08-24-2009, 06:41 AM   #3
_GTO_
_GTO_'s Avatar
Drives: holden commodore
It's happen alot with the G8's .
_GTO_ is offline   Reply With Quote
Old 08-24-2009, 08:44 AM   #4
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
Was there a problem with the G8's? or is the clunking "normal'?
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 08-24-2009, 01:26 PM   #5
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
Yes, the same thing happened with mine about 800 miles,just took it to the dealer this past friday and of course they said they could find nothing wrong with it even though I went on a test drive with the technician and brought the noise to his attention they said all was ok but documented it and said if it continues bring it back. a waste of 2 1/2
hours of my time and the noise is still there, it doesn't do it all the time only only when going over ruff road not over speed bumps.
Skyblu is offline   Reply With Quote
Old 08-25-2009, 11:48 AM   #6
_GTO_
_GTO_'s Avatar
Yes there was a problem with the G8's and both " Chevrolet Lumina and caprice in ME" and the dealer claim that the tires and the shocks are the biggest reason
Old 08-26-2009, 10:42 AM   #7
Speedy One
Thanks for the input, I guess I'll have to take it in and waste 2 1/2 hours of my time also. If I find anything out I will let you know.
Speedy One
Old 08-26-2009, 12:19 PM   #8
Skyblu
Skyblu's Avatar
The more I hear the noise it sounds as if the struts are "bottoming" out (if thats a word)
but they claim they checked that also and all was good. Let us know what you find out and maybe I'll go for round two, I found out on another thread today about possible reasons for steering wheel vibration I developed so I can go back to dealer and start again!
Old 08-26-2009, 12:25 PM   #9
prostock69
Female Muscle Car Nut!
prostock69's Avatar
Drives: 2010 RS/SS IOM Camaro
Tire rod? My Dodge Charger RT developed a loud clunk in the front when ever I hit a bump or turned the wheel. The tire rod was bad. Car only had 12,000 miles on it. turns out its a big problem with Dodge Chargers.
2SS/RS Inferno Orange w/ black stripes, black/orange interior, Automatic, w/ sunroof and polished aluminum wheels
MODS: Borla "S" Type Exhaust, American Racing Headers 3" Longtubes, New Era Cold Air Intake, HP Tune, Custom Ground Camshaft, Professionally Ported Heads by Darin Morgan, Ported Throttle Body, 3000 Stall Converter, and 160 Degree Thermostat.
http://www.rehermorrison.com/; http://www.darinmorgan.com/; http://www.neweraperformance.com/
prostock69 is offline   Reply With Quote
Old 08-26-2009, 08:34 PM   #10
monkeywrenching
Drives: 1LT/RS
When you go in have them check the front swaybar bushings. Put it up on the alignment rack, take the weight off of the wheels, and jerk on the swaybar. If there is any contact between the bar and the frame you get a hard metal clunk.You don't always get the noise going over bumps. This is sometimes hard to find because the bushings still appear to be fine . But the clamp may have loosened enough so that a bushing could have slipped a hair and this all it can take to allow contact. If you remove the bar and take a ride and the noise goes away then you start the process of elimination from there.
This may seem long-winded but it can drive you nuts d*#@ing around trying to find these things.
monkeywrenching is offline   Reply With Quote
Old 09-01-2009, 08:03 PM   #11
coalblack7
coalblack7's Avatar
Drives: 2010 Chevy Camaro Black 1LT
I have a similar issue... when parking or going over bumps and turning left or right. A very loud knocking noise, which has been getting louder since I took delivery 6/27. I took it to my BMW mech (I work there) told me it was the strut mounts.. took it to Chevy and yup! he was right...they are replacing both strut months (left and right). I didn't let them keep it over night, they are calling me when the parts are in. I can't sleep a wink with out it!
coalblack7 is offline   Reply With Quote
Old 11-03-2010, 09:42 PM   #12
jtcamaro
Drives: 2010 Chevy Camaro SS2 RS
I have a 2010 Camaro ss2 and I am having the same issues with clunking noises in the front end. My dealer keep telling me that this is just the way it is with the Camaros and that there is no fix for it. Any advice? I feel like I am driving a 10 year old car.
jtcamaro is offline   Reply With Quote
Old 11-03-2010, 10:00 PM   #13
MasterZ
MasterZ's Avatar
mine just started doing the same thing about 2 weeks ago... my issue is I have the Eibach Pro kit ( springs & swaybars) so I was thinking something maybe loose.
Last weekend I got under the car and inspected all the nuts/bolts and didnt see anything loose or where it happened to be making contact with the frams.
I did discover while the car was up on jacks if I grab the tire and tried to turn it by hand. There seems to be some slack in the steering assebly and if I did it pretty hard it would make a bit of clucking noise. I wonder if this is what it could be?
Wonder if my warranty would be void cause I changed the springs/swaybars?
2014 C7 Z51~ M7 custom paint,
Mods soon to come, researching at the moment.
MasterZ is offline   Reply With Quote
Old 11-03-2010, 10:22 PM   #14
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
GM is still claiming this sound is normal for the Camaros...there is an ongoing thread here: http://www.camaro5.com/forums/showthread.php?t=49036
rolnslo is offline   Reply With Quote
New Camaro photoshop with beefier front end, drop and smoked wheels Tran Camaro Photoshops / Renderings Forum 60 10-25-2010 06:02 PM
Interesting Front End Mod. (Pics from Dealer) - billet grill MikeySoft Cosmetics and Lighting Modification Discussions 35 08-02-2009 09:06 AM
front end wreck, black SS (Bad!) MLL67RSSS Camaro Photos | Spyshots | Video | Media Gallery 131 07-11-2009 03:19 PM
:'( Another black 2010 destroyed...front end this time (hope not a repost!) scotchsride09 Camaro Photos | Spyshots | Video | Media Gallery 3 07-02-2009 12:18 PM
2008 camaro front nose, do you like it?? Gary English 5th Gen Camaro SS LS LT General Discussions 83 07-31-2007 11:18 PM
