Gen5DIY
Old 08-22-2009, 01:35 AM   #1
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Adding a Clutch Reservoir to Isolate it from Brake System
Here's some pics of the new clutch reservoir I installed on my Camaro.
Total cost of parts was aprox. $35.00. It took me about an hour, the most time was spent fabricating an aluminum bracket to hold the reservoir. I got the reservoir from the local Yamaha Motorcycle shop. I saw one on the handlebars of a new crotch rocket. The hose fitting on the clutch res. is the right size for the hose coming off the brake reservoir. And the hose is exactly the right length. Then I just put a cap and clamp on the nipple coming out of the brake reservoir.
If anyone wants the Yamaha part #'s for doing this, let me know.
This makes it very easy to change out your clutch fluid and it keeps clutch
dust from contaminating your expensive brake system, preventing very
costly repairs in the future. I am now using Motul RBF 600 Dot 4
fluid in the brake and the clutch system instead of the factory Dot 3 fluid.
The Motul has a lot higher wet boiling point so the brakes work much better on the track.
Name:  Clutch Reservoir 001.jpg
Name:  Clutch Reservoir 002.jpg
Name:  Clutch Reservoir 003.jpg
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 08-22-2009, 02:29 AM   #2
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Nice job...should have been separate from the factory.
Kilo-9 is offline   Reply With Quote
Old 08-22-2009, 08:50 AM   #3
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Why wasn't this done by GM? Do they no something we don't?
Old 08-22-2009, 08:59 AM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Nice to see that members have good Common Sense, But you can do it with all gm parts like i did, And you did not need to fabricate an aluminum bracket, Go to post 13 on this thread.
http://www.camaro5.com/forums/showthread.php?t=34085
Old 08-22-2009, 04:18 PM   #5
PsyDoc
Drives: Soon-to-be 1st Gen
mtcwby, nice job.
2SSRS, do you have photos of your reservoir installed?
PsyDoc is offline   Reply With Quote
Old 08-22-2009, 04:23 PM   #6
mtcwby
mtcwby's Avatar
[QUOTE=2SSRS;830358]Nice to see that members have good Common Sense, But you can do it with all gm parts like i did, And you did not need to fabricate an aluminum bracket, Go to post 13 on this thread.
Well, before I found the reservoir from Yamaha, I called Chevy and Dodge dealers in the Denver area and they all told me the same thing....That the clutch systems are all sold as sealed units (reservoir, mastercylinder, and slave cylinder with fluid already in them) They couldn't get just a reservoir separately. I even checked with NAPA and they said the same thing. If I had known about the Holden part I would have gone that way.
All I know is that I really wanted to separate the clutch system, It was always a problem on my C6 Corvette and I sure didn't want to contaminate
my brake system with all that clutch dust.
Old 08-22-2009, 05:02 PM   #7
2SSRS@Gen5diy
Originally Posted by PsyDoc View Post
mtcwby, nice job.
Yes same thread as my last post and #5 post have photos of your reservoir installed
[QUOTE=mtcwby;831566]
I agree on the separating of the clutch system and the brakes, like i posted nice to see good work.
Do you think that the car needs a separate Clutch Fluid reservoir 2SSRS@Gen5diy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 620 09-04-2017 07:59 PM
Nitrous info CamaroSpike23 Forced Induction - V8 63 06-20-2017 11:15 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Question for seasoned stick shift drivers tommygun6644 Dragstrip and Launch Techniques Discussion 69 10-11-2010 11:42 PM
Nitrous Info Milk 1027 Wiki 0 08-12-2009 07:26 PM
