Old 08-22-2009, 07:41 PM   #1
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
tire pressure issues
anyone have any problems with the tpms not allowing you to shift over 5k when u have lowered tire pressure?
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 08-23-2009, 03:55 AM   #2
toehead93
Drives: 2014 2SS/1LE
How low? I had mine down to 28psi and had no issues.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-23-2009, 09:58 AM   #3
boostedyards86
28psi cold or hot? i had it down to 26psi cold and the thing was not allowing me to play.
Old 08-23-2009, 10:02 AM   #4
boostedyards86
if ur down around 28psi hot the sensor will come on again and not allow you to go over 5k. really sucks.
Old 08-23-2009, 10:04 AM   #5
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
What sensor comes on??
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 08-23-2009, 10:08 AM   #6
boostedyards86
the low tire pressure light.
Old 08-23-2009, 10:35 AM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
interesting...
thing with steet tires is a lot of times lowering your pressure really doesn't do much good at all... in fact can end up hurting you...
scrming is offline   Reply With Quote
Old 08-23-2009, 11:43 AM   #8
boostedyards86
actually the launch seemed to get better with the lower pressure...just wouldn't let me run then. but then comes the problem of how we are going to put drag radials or slicks on with low tire pressure... is there a way to bypass the system so it doesn't cause a disruption in rpm?
Old 08-23-2009, 12:29 PM   #9
OrangeChevyII
Drives: 2010 RS/SS2
I change all 4 of my wheels at the track and have none of these symptoms.
OrangeChevyII is offline   Reply With Quote
Old 08-23-2009, 04:00 PM   #10
ShnOmac
ShnOmac's Avatar
Something seems askew......
ShnOmac is offline   Reply With Quote
Old 08-23-2009, 04:03 PM   #11
Mayhem Matt
Mayhem Matt's Avatar
Drives: 10' 2SS/RS M6 SUPERCHRGED BUMBLEBEE
WHAT!!! That's ridiculous, sensors suck sometimes
Ordered Bumblebee 10/15/2008Part of the Family 6/11/2009 #11423
My Bumblebee to Superbee build story...http://www.camaro5.com/forums/showthread.php?t=105163
Superbee's 536hp Dyno Run...http://www.youtube.com/watch?v=AE7wePluPAc
Mayhem Matt is offline   Reply With Quote
Old 08-23-2009, 07:03 PM   #12
boostedyards86
you dont have this issue at all? does ur low pressure light come on?
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 06:42 AM
How does onstar know what tire pressure I have? FLYNNZL1 Wheels and Tires Talk Sponsored by The Tire Rack 8 08-09-2009 02:11 PM
Resetting TPMS Tire Pressure System jvmax Wheels and Tires Talk Sponsored by The Tire Rack 4 07-10-2009 12:37 AM
Tire Pressure toehead93 Dragstrip and Launch Techniques Discussion 4 06-09-2009 12:24 PM
Tire Pressure Monitoring System-Inside or external monitors? Fogey 5th Gen Camaro SS LS LT General Discussions 11 05-19-2009 10:50 AM
