Old 08-22-2009, 09:55 PM   #1
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Mobil 1 Oil Filter leaking ?
Has anyone had any leaking issue with they filter? Specifically a Mobil 1?
Im using the M1-113 Oil Filter and i put it on hand tight and put new oil it, let car run for 10-15 minutes to warm up and check for leaks. I noticed a very tiny amount of oil that had run down my filter and pooled up a little on the bottom of my filter... not enough to drip on to the floor though.
I tightened it a little more but with a oil filter tool... wiped it off good and started it again for 10-15 minutes... Same thing.
Is M1-113 not the correct Mobil 1 Filter for the V8 engine ??
Any thoughts or Ideas?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 08-23-2009, 12:25 AM   #2
shiftz33
shiftz33's Avatar
Drives: SS Sedan, SSR, T-Bird, Highlander
The M1-113 Mobil 1 oil filter is the correct filter for the V8 engines.
I had to replace the PF48 oil filter the service department installed during my Camaro's first oil change because it was leaking. I tried to tighten the PF48 filter and it did not stop leaking. I could not find the "leak source" after I removed the PF48 filter.
I installed the M1-113 filter and tightened it about 3/4 turn (by hand) after the initial gasket contact. The M1-113 filter has been leak free since it was installed 7/7/2009.
15 Chevy SS | 04 Chevy SSR | 04 Ford Thunderbird PCR #428 | 06 Toyota Highlander Hybrid
shiftz33 is offline   Reply With Quote
Old 08-23-2009, 12:53 AM   #3
Ject
aka Patrick
Ject's Avatar
my acdelco (factory) filter worked fine, no leak signs.
The M1-113 seems to have stopped now, I hand tightened it as tight as possible and it leaked initially.
Gave it a good snug 1/2 turn with an oil filter tool and same results... just went out and gave it all the might I had to go 1/4 turn more and so far no leak after 20 min run time.
crosses fingers......
Old 04-21-2010, 12:16 AM   #4
Texhawk
Texhawk's Avatar
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray
I have had problems with AC Delco filters leaking, I think because of a weak base plate design. I switched to WIX filters and have never had another leak.
I use WIX filters on all my cars.
Texhawk is offline   Reply With Quote
Old 04-21-2010, 12:23 AM   #5
ron10
Drives: 2010 2SS IOM L99
i always spread a layer of grease around the filter gasket.i was told years ago that this helps seal the filter.i've never had a leak on any of my cars.
Old 04-21-2010, 05:16 AM   #6
duder4thgen
Drives: Bird
Sometimes if there is excess oil on the rubber seal of a filter a tiny bit will leak out when it heats up and expands. Usually if you keep an eye on it, it should stop after the first time you drive it.
I wouldn't use an oil filter tool to tighten an oil filter, they are designed to seal hand tight. Clamping them down too much will actually increase the chances of the seal going bad, not to mention make it a pain in the ass to get off the next time. If you had a honest leak from a filter it would be a much better idea to just replace the filter from the start.
duder4thgen is offline   Reply With Quote
Old 04-21-2010, 08:47 AM   #7
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Well this is a shot in the dark but did you check if the gasket from the old filter remained on the housing?
The only time I did this a whole lot of oil came out so I doubt that is your problem but still.....
tradosaurus is offline   Reply With Quote
Old 04-21-2010, 09:00 AM   #8
Ject
aka Patrick
Ject's Avatar
I switched to a Different filter and it solved the issue (from August '2009')
I've always put a little oil on the rubber seal before putting it on as well. I believe the filter was just faulty.
Old 04-21-2010, 09:05 AM   #9
tradosaurus
Buddha dang!
I didn't even realize that this thread was that old!
Old 04-29-2010, 06:26 PM   #10
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I always tighten them 'hand-tight', then turn it another half-turn with the filter wrench. Filters just tightened by hand can vibrate loose. And always dip your finger in new oil and wet the filter gasket before installing.
Old 04-29-2010, 06:52 PM   #11
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I use an impact wrench to tighten mine...
Oh, that was last August..I've learned better now
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 05-06-2010, 12:29 PM   #12
kpwalls06
Cory
kpwalls06's Avatar
Drives: 2010 Camaro 2SS/RS M6;
Anytime you're changing a screw on fluid filter, like our Camaro oil filters, it's good practice to take some of the new oil and wipe the rubber gasket of the filter with it. A good ring of oil on the filter gasket will help it seal against the filter housing and prevent leaks. If you've already put the filter on and new oil in, there's not much can be done save for draining it again, removing the filter, and wetting the gasket properly. But with the small leak amount you're describing, that may be more trouble than you'er looking for. Hope this helps, and best of luck!
kpwalls06 is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
