Old 08-23-2009, 12:34 AM   #1
kellertxgen5
kellertxgen5's Avatar
Drives: 2LT RS - Black w' black 21's
DIY on changing your own oil?
Anybody changed their own yet?
How hard is the filter to get to?
What all do I need to get the plug out?
What filter is on there so I know what to get at the store?
Any other suggestions?
Black 2LT RS w/ Black 21's Driving since 7/17
kellertxgen5 is offline   Reply With Quote
Old 08-23-2009, 04:01 AM   #2
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
I have not done one on my own yet , put from what I have observered it looks easy enough to do so i'll give it a try next time I'm due for one..
Here's some info. that might help you with how much oil and what filter you will need :
Owners Manual section 11-2
Engine Oil w/ Filter
3.6L V6 Engine : 6-qts
6.2L V8 Engine : 8-qts
(L99 & LS3)
V6 : SAE 5w-30 GM6094M
Do Not use 10w-40,20w-50 or any other viscosity grade oil not recommended
V8 : SAE 5w-30 / GM4718M (L99 & LS3) Mobil 1 is Factory fill ..
GM#12593333 ( PF459G )
AC Delco Filter for the V6L # PF459G / **PF2129
**this part # is easier to find at most Auto Parts Stores ..
Wix / Napa Gold : #57090 / #7090 @ $ 7.69
If you are Military / Veteran always ask your local Auto Parts Store for the discount ! !
(Bumper to Bumper Auto Parts @ around $5.10 ea.)
Left one is Wix/Napa #57090 , 7090 / Right one is AC DELCO #PF2129
Hope this helps ...
fee5fofum is offline   Reply With Quote
Old 08-23-2009, 09:46 AM   #3
katman
Drives: 2LT Auto RS sunroof
For V-6 the oil plug is 15mm I think. I changed my oil yesterday, Mobil 1 5W30. The oil change sure is easy with the top mounted oil filter! I just raised the front end off the ground with service jack, wheel chocks behind rear tires, and 4 point jack stands. I had to lift front wheels off of the ground, so I decided to clean the rear inside of front rims by spinning the wheels by hand while using a clean rag to remove dirt.
katman is offline   Reply With Quote
Old 08-23-2009, 10:23 AM   #4
FI4T0MCAT
FI4T0MCAT's Avatar
Drives: 1969 SS Camaro
I have done it, for the v8 the oil plug is also 15mm and it does take 8 qts. Its not any harder than any other vehicle. Actually i found it easier, because the oil filter is about 4 inches behind the drain plug on the very bottom. Makes it very simple.
FI4T0MCAT is offline   Reply With Quote
Old 08-23-2009, 10:44 AM   #5
DEW
Drives: Hoopdee
When you say service jack, do you mean floor jack that can go under the engine (crossmember if there is one). I have not looked under mine yet (2LT) and was wondering if a floor jack can be used to jack the whole front end up at the same time? Also what size wrench for the top mounted oil filter? Thanks in advance for the info.
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 08-26-2009, 10:06 AM   #6
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Ok, so does the K&N oil filter 1017 not fit this car?? http://www.amazon.com/gp/product/B00..._ya_oh_product
The picture looks like it's a plain filter and not a cartridge. I already ordered 2 of these :(
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 08-26-2009, 10:08 AM   #7
ppphfwhatever
Drives: car
looks similar to the one I used, surprisingly small
ppphfwhatever is offline   Reply With Quote
Old 08-26-2009, 10:10 AM   #8
Michael_Js
Michael_Js's Avatar
Ok, I was worried since the pictures in this thread show a filter with no casing...I obviously don't have my car yet but I'm all setup to do the first oil change since she'll have over 500 miles by the time I get her home!
Old 08-26-2009, 10:26 AM   #9
montej23
montej23's Avatar
Drives: 2011 VR Camaro
plan on changing mine at 500 and doing it myself
montej23 is offline   Reply With Quote
Old 08-28-2009, 11:24 PM   #10
traip93
Drives: Ralley Yellow, Black Sripes 2L
Is he filter just a drop in?
my car doesn't come with a jack...can I use my wife's from her G35? I may just buy some ramps.
Chad 2Lt
traip93 is offline   Reply With Quote
Old 08-28-2009, 11:25 PM   #11
traip93
oh...how does resetting the "oil remaining" computer? I've read others have had issues...
Chad 2Lt
Old 09-03-2009, 01:05 AM   #12
PunkRockSS
Drives: 96 Chevy Half-Ton
first post! I thought this was important though.
DO NOT use the car jack that comes with a car. That is for an emergency tire swap while you are on the outside of your car. It is extremely dangerous to be under a car that is supported using one of these. Go buy yourself a nice floor jack or some ramps and block the back wheels!
PunkRockSS is offline   Reply With Quote
Old 09-03-2009, 10:02 PM   #13
ace2777
ace2777's Avatar
Drives: 2010 2SS RS Inferno Orange
Did mine last week
ramps,
mobil 1 oil
ac delco filter
pretty straight forward
ace2777 is offline   Reply With Quote
Old 09-05-2009, 10:55 AM   #14
aldaran
aldaran's Avatar
Drives: 2016 Camaro 2SS/RS
I haven't seen the Camaro's but newer V6 Engines have a filter on the top. You unsrew a large cap, pull out the old one and drop in the new one, close cap and you are done. Based on the previous replies, the V8 is underneath near the drain plug so that one would have a casing.
aldaran is offline   Reply With Quote
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
Synthetic? shroomjohn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 09-18-2008 02:31 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
