| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#76 | ||
CAM346
Drives: 99 t/a Join Date: Jun 2008
#77 | ||||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
![]() Quote:
![]() in front of the passenger strut tower in the engine bay, there is the fuse box, pull the cover and you'll see the fuses. check pages 9-42 thru 9-44 for the location of the two fuses to pull
#78 | |||||||||
Drives a Maro
Thanks GMRULZ. ![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
![]() Oh, and the pics of the car with 'decoration', are coming.
#79 |
Drives a Maro
I'm still speaking to a person at GM that is now helping me and looking further into this problem, BEFORE the fuse pull I did. This person has some 'pull' at GM and is being very responsive in helping.
He has asked me not to expierement further with my car as to not possibly creating any other issues. I will respect his request. (of course it's easy when you're rollin like I am) He wants to have my dealer do some tests to see what happened. It only makes sense. So anyway, not sure if a stickey would be the right thing. It's well documented on the site and should be easy to search for someone who has problems. This way Camaro5 isn't 'pushing' the fuse pull, but providing it if someone wants to find it. |
#80 | |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#81 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
http://www.dashhawk.com/ Universal Parameters Calculated Engine Load Engine Coolant Temp (ECT) Short Term Fuel Trim Bank 1 Short Term Fuel Trim Bank 2 Long Term Fuel Trim Bank 1 Long Term Fuel Trim Bank 2 Fuel Pressure Manifold Absolute Pressure (MAP) Engine RPM Vehicle Speed Timing Advance (Spark) Intake Air Temp (IAT) Mass Air Flow (MAF) Absolute Throttle Position O2 Bank 1 Sensor 1 O2 Bank 1 Sensor 2 O2 Bank 1 Sensor 3 O2 Bank 1 Sensor 4 O2 Bank 2 Sensor 1 O2 Bank 2 Sensor 2 O2 Bank 2 Sensor 3 O2 Bank 2 Sensor 4 Relative Fuel Pressure Diesel/Direct Injection Fuel Pressure Commanded EGR Duty Cycle EGR Error Commanded EVAP Purge Duty Cycle Fuel Level Evap Vapor Pressure Barometric Pressure Catalyst Temp Bank 1 Sensor 1 Catalyst Temp Bank 1 Sensor 2 Catalyst Temp Bank 2 Sensor 1 Catalyst Temp Bank 2 Sensor 2 Fuel Type (MultiFuel vehicles) Alcohol % Fuel System Status (Closed/Open Loop) Module Voltage Absolute Load Number of O2 sensors Number of WB O2 sensors Commanded Equivalence Ratio Relative Throttle Position Ambient Air Temp (AAT) Absolute Throttle Position B Absolute Throttle Position C Absolute Pedal Position D Absolute Pedal Position E Absolute Pedal Position F Commanded Throttle Actuator Wide Band O2 Sensor 1 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 2 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 3 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 4 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 5 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 6 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 7 Equivalency Ratio (FACTORY) Wide Band O2 Sensor 8 Equivalency Ratio (FACTORY) Auxiliary O2 Short Term Fuel Trim Auxiliary O2 Long Term Fuel Trim Wide Band O2 Sensor 1 Heater Current (FACTORY) Wide Band O2 Sensor 2 Heater Current (FACTORY) Wide Band O2 Sensor 3 Heater Current (FACTORY) Wide Band O2 Sensor 4 Heater Current (FACTORY) Wide Band O2 Sensor 5 Heater Current (FACTORY) Wide Band O2 Sensor 6 Heater Current (FACTORY) Wide Band O2 Sensor 7 Heater Current (FACTORY) Wide Band O2 Sensor 8 Heater Current (FACTORY) Wide Band O2 Sensor 1 Voltage (FACTORY) Wide Band O2 Sensor 2 Voltage (FACTORY) Wide Band O2 Sensor 3 Voltage (FACTORY) Wide Band O2 Sensor 4 Voltage (FACTORY) Wide Band O2 Sensor 5 Voltage (FACTORY) Wide Band O2 Sensor 6 Voltage (FACTORY) Wide Band O2 Sensor 7 Voltage (FACTORY) Wide Band O2 Sensor 8 Voltage (FACTORY) BOOST/VACUUM (Calculated and corrected for altitude!) GM Enhanced Parameters BLM Cell # Torque Management Spark Retard (Shift) Commanded A/F Ratio Knock Retard Cylinder That Knocked Learned Spark Oil Pressure Calculated Vacuum (GM) Calculated Air Flow (GM) Current Misfire Cyl1 (GM) Current Misfire Cyl2 (GM) Current Misfire Cyl3 (GM) Current Misfire Cyl4 (GM) Current Misfire Cyl5 (GM) Current Misfire Cyl6 (GM) Current Misfire Cyl7 (GM) Current Misfire Cyl8 (GM) Total Misfires (GM) History Misfire Cyl1 (GM) History Misfire Cyl2 (GM) History Misfire Cyl3 (GM) History Misfire Cyl4 (GM) History Misfire Cyl5 (GM) History Misfire Cyl6 (GM) History Misfire Cyl7 (GM) History Misfire Cyl8 (GM) Misfire Cycles (GM) Desired Throttle Position (GM) Pedal Rotation (GM) Fan Speed (GM) Desired Fan Speed (GM) Fan Speed Error % (GM) Command Fans 1, 2, 3 ON/OFF Command Fuel Trim Reset Command Crank Angle Sensor Error (CASE) Relearn Last Shift Time Trans Input Shaft Speed Trans Output Shaft Speed Trans Temp TCC Slip Current Gear VBS Force (Amps) VBS Force % TCC DC % 1->2 Shift Time 2->3 Shift Time 3->4 Shift Time 1->2 Shift Error 2->3 Shift Error 3->4 Shift Error Ford Enhanced PID’s Engine Oil Temp Trans Fluid Temp Cylinder Head Temp Fuel Pressure Torque Converter Slippage Pedal Position Dodge/Chrysler (DCx) Enhanced PID’s Knock Sensor 1 Voltage Knock Sensor 2 Voltage Spark Retard (Knock Retard) Multiple Displacement System (MDS) status (Hemi) Engine Oil Pressure Fuel Level % (DCxspecific since SAE Fuel Level doesn’t seem to read correctly for DCxvehicles) Transmission Input Shaft Speed1 Transmission Input Shaft Speed2 Transmission Turbine Speed Current Gear Status Target Gear Status Transmission Oil Temperature Blade Position (Throttle Blade) Coming Soon! More manufacturer specific functions/parameters
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
#82 | |
Drives a Maro
I didn't know you could do that.Of course, I wouldn't know what to do with the info.
#83 | |
It also just plugs into the diag port under the dash, no fancy wiring skills required...
#84 |
![]() Drives: 2010 SS AMB , mini revo Join Date: Aug 2008
irpq11
Glad you got your car running right .
#85 | |
gfx installed
Drives: abm2ssrs Join Date: Apr 2009
[SIGPIC]
#86 |
Nice to see the car running like it should. My car takes hours to reach that speed you did by the end lol
#87 |
Drives a Maro
Correct.
#88 | |
Drives a Maro
#89 |
![]() Drives: BMW 335i Join Date: Aug 2009
To prove that your car works you should film yourself doing some smokey ass donuts.
#90 |
#91 |
The permagrin was from the car, right? or did the Mrs. buy you some Crown Royal?
#92 |
Danny
Congrats Randy and Scott. Is there really any risk to pulling these fuses? Not really sure if I have a fast A6, never really timed it.
2SS/RS CGM with black rally stripes
DON_RAFA describing my Noweeds cutouts - "Very Strong. When I couldn't see you I still heard you. Sounds like your car is pissed at the world." Please help me fight back by supporting me in the 2010 American Cancer Society's Relay for Life. Every little bit helps. Click here for more information. Thank you to those that have donated! |
#93 |
![]() Drives: 2010 Camaro SS/RS Join Date: Aug 2009
So where do I find the fuses???
#94 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
From what I can tell, the fuse panel is on the passenger's side strut tower, on the front. Pull the panel cover, and there you go.
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#95 |
I am the internets.
Congrats bro! When is the rematch with your old lady?
#96 | ||||
Drives a Maro
I hear; chaching, chaching, chaching ![]() Quote:
![]() But now that the car is right, I'm a guy with nothing to keep permagrin off my face. lol Quote:
She said she's retiring on top.
#97 |
Don't worry, Bonnie will come out of retirement for a great comeback match... they always do... you just gotta build up the hype for it first
haha
#98 |
Drives a Maro
Maybe a public shouting match. I'll call the press conference. lol
#99 |
Just don't get one of those california dusters with the purple handle.....
#100 |
That third video was freakin awesome!!
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! |
| Thread Tools | |
| Help irpq11 stop SMOKING!!!!! | GTAHVIT | Off-topic Discussions | 331 | 07-16-2010 06:24 PM |
| irpq11, L99 Dyno results. | PQ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 483 | 01-11-2010 01:56 PM |
| This 0-60 video is for irpq11 and other L99 guys... | Indpowr | Camaro Photos | Spyshots | Video | Media Gallery | 15 | 08-02-2009 03:23 PM |
| irpq11 needs help. Car here this week. Question. | PQ | Camaro Price | Ordering | Tracking | Dealers Discussions | 78 | 05-30-2009 08:24 PM |
| PERMAGRIN!!! Test Drive and Write-Up! | VenomZ302 | 5th Gen Camaro SS LS LT General Discussions | 17 | 04-21-2009 02:01 PM |
