Old 08-23-2009, 07:16 PM   #1
BlackRS
BlackRS's Avatar
Drives: 2011 Camaro SS/RS
Regular or synthetic oil?
...Sorry if this was already discussed, I did look for it in search.
What do you think is BETTER to use, Synthetic or Regular oil? I hear that using synthetic oil prolongs the engine life, but if you switch between types when the car is older, it can cause problems. so I want to know what I should use before i get it. it's a V6, I will put mostly highway miles on it
BlackRS is offline   Reply With Quote
Old 08-23-2009, 07:43 PM   #2
ShnOmac
ShnOmac's Avatar
Your going to get alot of different opinions on this one...... Here is some threads that will keep you busy for alittle bit...
http://www.camaro5.com/forums/showth...&highlight=oil
http://www.camaro5.com/forums/showth...&highlight=Oil
ShnOmac is offline   Reply With Quote
Old 08-23-2009, 08:14 PM   #3
hollywoodjose
hollywoodjose's Avatar
Drives: 2010 Black 1LT
I used regular oil in my 03 honda i bought it with 14k miles on it in 03 and now it has 172k miles on it, i changed oil every 3k miles, changed tranny fluid, air filters, etc and it still runs good.
For my camaro i bought the lifetime synthetic oil change from the dealership. I wouldnt recommend the lifetime oil change but i would recommend synthetic
hollywoodjose is offline   Reply With Quote
Old 08-23-2009, 09:08 PM   #4
myold88
myold88's Avatar
The oil filler cap on my SS says: Mobil 1.
Old 08-28-2009, 07:24 PM   #5
mutant chicken
Mutant Member
mutant chicken's Avatar
Drives: '10 SS/RS, '10 Mini , 07 Harley
We took ours in for it's first oil change and the dealerhip pretty much told us that they would only use Mobil 1. I really don't have a problem with that, I don't use anything but synthetic in my Harley, it keeps the engine running cooler and certainly prolongs the life of the engine. If this were a $10k Toyota disposable car I might not care, but then I wouldn't drive one of those anyway .... : )
Ordered Oct. 13th, Del. Jun. 29th! CGM, 2SS/RS
mutant chicken is offline   Reply With Quote
Old 08-29-2009, 01:59 AM   #6
AZ2SSRS
AZ2SSRS's Avatar
Drives: 2013 CRT ZL1
Owners Manual Says Synthetic
Check the manual. It states that synthetic oil (5W30) must be used.
AZ2SSRS is offline   Reply With Quote
Old 08-29-2009, 03:42 AM   #7
SNV
SNV's Avatar
Drives: 2014 RRM 2ls
I don't think it says that on the v6 the OP has.
I only run synthetic in my cars though. Have always used Mobil1. I was thinking about giving Royal Purple a try. Now to find a shop that uses it haha.
2010 IBM 1LT out. 2013 BRM 1LS in. It's like having a blank canvas once again. Modding has started! Now on to a 2014......
SNV is offline   Reply With Quote
Old 08-29-2009, 05:57 AM   #8
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Do not put Dino oil in it. It says in the manual do no do it so don't do it.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-29-2009, 06:11 AM   #9
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
OP states it's a V6.
The V8 comes from the factory with synthetic. The V6 comes from the factory with dino oil. So in your V6 it's really your choice. In my V6 I changed the oil at 1,400 miles and put 5-30 dino oil in. I will change my oil again at 3,000 and put in Mobil 1. I will keep using Mobil 1 for the life of the car.
BTW, you can switch back and forth from dino to synthetic without doing any harm, but why would you? Just pick one and stick with it.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 09-01-2009, 10:14 PM   #10
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
Your right , only the V8's are Factory Filled with synthetic oil like it says on the oil filler cap " Mobil 1 " ...
I did it just about the same way you are going to do..The only difference is that I changed the oil twice already with dino 5w-30 then I switched over to Mobil 1 / 5w-30 at 2500 mi. and will be sticking with Mobil 1 from here on out ! !
I added a Mobil 1 emblem under the hood , I was going to put it somewhere on the engine cover but it looked kind of awkward in different places on the cover due to the size & length of the emblem (but thats my own opinion)..
fee5fofum is offline   Reply With Quote
Old 09-02-2009, 07:38 AM   #11
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
I have used Mobil1 Delvac 15W/40 in all my cars from V4 to V8 for the past 5 years with no adverse affects.
Personally I believe as long as you change the oil every 5,000 miles or 6 months you can use regular oil unless the car specifically calls out synthetic.
You wouldn't want to void the warranty.
tradosaurus is offline   Reply With Quote
Old 09-02-2009, 10:04 AM   #12
Tex
Texas Military Forces
Tex's Avatar
Drives: 2017 ZL1 Red Hot Auto
What about Penzoil Platinum Sythetic or Quaker State HP Synthetic oil. I only ask because it's going on sale this weekend for $3.99 a quart.
Tex is offline   Reply With Quote
Old 09-02-2009, 11:26 AM   #13
DrDave83
Drives: Black 2SS/RS
a V4 huh???? never seen one of those.....
DrDave83 is offline   Reply With Quote
Old 09-02-2009, 04:12 PM   #14
Sassy
Sassy's Avatar
Drives: 2010 Camaro 2LT RS - Red Jewel
I put Royal Purple Break-in oil in my car at 278 miles. It says to run it for the required break in period (1,500 per manual) but NO longer than 2,500. After the 1,500, I will be keep using Royal Purple. They say you should not use the regular Royal Purple until after the engine is broke in. It's good for 12,000 or should be changed annually. I have the V6, so I am not required to buy stock in Mobil 1. I am sure it's really all pretty much the same stuff. I wouldn't use conventional, but would go for any kind of synthetic. I am sure it's all good.
Sassy is offline   Reply With Quote
Regular motor oil or Synthetic 2SSRS shopritehw USA - NY / NJ / PA 1 06-10-2009 11:45 AM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
