Old 08-23-2009, 10:53 PM   #1
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
Please EXPLAIN Stabilitrak/Traction Control, Launch Control!
I've tried to search for this topic, I thought I had seen it before, but please explain the settings and how to set them.
1) Stabilitrak
2) Traction Control
3) What is the advantage of shutting one of these off over the other?
4) I recall holding the button for seven seconds? What is that for?
5) What does it mean when both TC and Stabilitrak OFF lights are lit (is this in Launch Control?
Sorry if this is a repeat, but no where had a concise explanation that I could find! Thanks
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 08-24-2009, 01:09 AM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Launch Control http://www.camaro5.com/forums/showthread.php?t=30849
Old 08-24-2009, 09:05 AM   #3
drtwo
drtwo's Avatar
Originally Posted by slick rick View Post
Cool, this answers the 7 second question and how to turn off both traction control and stabilitrak!
Still need help understanding questions 1, 2 and 3 above! Keep it coming!!
Old 09-01-2009, 06:36 PM   #4
wflineman3
Drives: 2010 white 2SS RS L99
stabilitrak and traction control
Stabilitrak Adjusts engine torque and/or brake pressure at the individual wheels to get you back on your intended path.
Traction control senses and reduces wheel spin to help maintain traction.
wflineman3 is offline   Reply With Quote
Old 09-18-2009, 08:58 PM   #5
Warr3nc
Drives: 1969 Camaro
Traction Control
When drive wheel slip is noted, the EBCM will enter traction control mode.
First, the EBCM requests the engine control module (ECM) to reduce the amount of torque to the drive wheels via a serial data message. The ECM reduces torque to the drive wheels and reports the amount of delivered torque.
If the engine torque reduction does not reduce drive wheel slip, the EBCM will actively apply the brakes on the slipping drive wheel. During traction control braking, hydraulic pressure in each drive wheel circuit is controlled to prevent the drive wheels from slipping. The EBCM commands the pump motor and appropriate solenoid valves ON and OFF to apply brake pressure to the slipping wheel.
Traction control can be manually disabled by pressing the traction control switch.
Stability Control
Stability control provides added stability during aggressive maneuvers. Yaw rate is the rate of rotation about the vehicle's vertical axis. The stability control is activated when the EBCM determines that the desired yaw rate does not match the actual yaw rate as measured by the yaw rate sensor.
The desired yaw rate is calculated by the EBCM using the following inputs:
• Steering wheel position
• Vehicle speed
• Lateral acceleration
The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. When a yaw rate error is detected, the EBCM attempts to correct the vehicle's yaw motion by applying brake pressure to one or more of the wheels. The amount of brake pressure which is applied varies, depending on the correction required. The engine torque may be reduced also, if it is necessary to slow the vehicle while maintaining stability.
Stability control activations generally occur in turns during aggressive driving. When braking during stability control activation, the brake pedal may pulsate.
Stability control can be manually disabled by pressing the traction control switch for 5 s.
Warr3nc is offline   Reply With Quote
Old 09-27-2009, 12:37 AM   #6
bonnhew
Drives: Audi A5
this video describes it all including ABS
bonnhew is offline   Reply With Quote
Old 09-27-2009, 01:00 AM   #7
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
i was havin the same problem to your not alone
1100, Preliminary order accepted - 13oct08
2000, Order accepted by GM ----- n/a
3000, Order acc. by P.R---------- n/a
3100, Order available to sequence- n/a
3300, Order sch. for production--- 21may09
3400, Order broadcast------------ 28may09
3800, Order produced ------------ 2jun09(2G1FT1EW8A9114199)
4000, Available to ship
4200, Shipped--------------------9june09
ITS HERE 18JUNE09
LSP2010 is offline   Reply With Quote
Old 09-27-2009, 02:22 AM   #8
Arkanian
"World of Warcraft" Gamer
Arkanian's Avatar
Drives: IBM 2SS/RS LS3 AFO
Great input, thnx....
2030, Order re-edited (if necessary)
2051, Order changed thru Web
2500, Order preferenced
3000, Order accepted by production control
Arkanian is offline   Reply With Quote
Old 09-27-2009, 02:40 AM   #9
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
http://www.camaro5.com/forums/showth...t=stabilitrack
Old 09-29-2009, 12:54 PM   #10
Coop
tagged for later read.
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
2010 Camaro Launch Control = Transmission Failure camaroguy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 140 07-06-2013 12:27 AM
Camaro SS Launch Control jdpickering Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 12-23-2009 10:29 AM
First time on Launch control, tranny is dead MarkSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 37 09-04-2009 10:34 PM
COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 80 05-02-2009 01:20 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
