JUICEDMOTORSPORTS
Old 08-24-2009, 12:15 AM   #1
Rob53
Rob53's Avatar
Drives: 2012 2SS/RS VR Camaro convertible
Mobil 1 10W-30
After doing some poking around on the internet trying to get an official yea or nay on Mobil 1 10W-30 for my SS Camaro. The bottle shows a GM6094M designation. I finally came across the GM approved engine oils list at:
http://www.gm.com/corporate/responsi...ngine_oils.pdf
It is current as of June 1, 2009 and lists Mobil 1 10W-30 as a GM4718M registered product. Other High Performance Engine Oils are also listed. So if you want to check for sure if what you want to use in your new Camaro is "warranty safe," this list on the GM website should answer that question for you. Just posting this as an FYI. Doing my first oil change @1400 miles using Mobil 1 10-30.
Rob53 is offline   Reply With Quote
Old 08-24-2009, 09:26 AM   #2
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
I wouldn't use anything other than 5w-30 in my engine. 10w is unnecessary and will reduce hp. 5w is just fine.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-24-2009, 11:03 AM   #3
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
I'd use 10W in a higher mileage car, like my '02, but, I'd stick with the 5W for the 2010.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 08-24-2009, 12:27 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I gotta agree with Banshee on this. The only advantage 10w has over 5w is it has better viscosity at higher start up temperatures. Unless you live in an area that routinely sees 120+, you won't see any change between 5w-30 and 10w-30 as the 30 designates that they both have the same viscosity at running temperatures.
Also with winter coming, unless you plan on doing another oil change in 2 months you're better off sticking with 5w-30 as 5w has better viscosity at colder temperatures. Running 10w in winter can cause engine damage until the oil warms up.
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Mobil 1 Oil Filter leaking ? Ject Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 05-06-2010 12:29 PM
V6 Oil - hopefully the final thread calflan Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 33 03-27-2010 07:20 AM
Mobil 1 Information Germann Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 16 07-09-2009 03:00 PM
Mobil 1 on sale Halo2 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 07-07-2009 07:59 PM
