Jason 98 TA
Old 08-24-2009, 10:39 AM   #1
barley67
Drives: 1967 450bhp race car
Removing from the firewall - HELP -
Apologies I think i posted this in the wrong forum a minute ago, could a moderator delete if so...
hello all..
im stripping down my firewall to get it ready for paint and ive hit a wall.
If you look at the pic ive attatched – ive drawn a box around what I presume is the brake fluid reservoir etc. How on earth does this thing come off the firewall? I've tried disconnecting the bolt that attaches to the brake pedal but that wouldn’t work. In the end I stopped because I didn’t want to brake anything but I couldn’t work out how to get it all off.
If someone can help it would be much appreciated.
barley67 is offline   Reply With Quote
Old 08-24-2009, 10:47 AM   #2
Tooblue
Drives: 95 Caprice (LQ4+L92+L76) NOS
Should be four studs on the firewall side (engine compartment)that you just need to remove the four nuts on them. From the inside on the brake pedal you will need to remove the rod that attaches to brake pedal. Then remove all of the attached brake lines (Master cylinder).. Should come right out / off..
Tooblue is offline   Reply With Quote
Old 08-24-2009, 10:50 AM   #3
barley67
Thanks for the reply. I got the four off the firewall, then spent a good 15 minutes lying upside down in the drivers footwell trying to remove the rod connected to the brake - with no joy. Hard to explain what I was trying to do but I was expecting a nut bolt combo to hold it on but its not.
Restoring a '67 Camaro back to race spec.
Old 08-24-2009, 10:53 AM   #4
Tooblue
Yah (been a while) but if I remember correct there is a clip that slides off. Kinda need two hands to get it off. Roger
Old 08-24-2009, 11:04 AM   #5
barley67
yer i got the clip off that was on one side, i guess a safety feature? but now there is still the u shape peice of metal hugging the brake with a stell rod through the middle.
VERY poor picture i've done to try and show what i mean attatched.
Cheers for the help guys.
Removing from the firewall - HELP - barley67 1st & 2nd Generation Camaros 2 08-27-2009 03:56 AM
Removing Staggered set up? srevoal Wheels and Tires Talk Sponsored by The Tire Rack 5 08-17-2009 07:48 PM
removing air bag sticker from visor strshp5 5th Gen Camaro SS LS LT General Discussions 11 08-16-2009 10:28 PM
Removing Badges Shurenuff 5th Gen Camaro SS LS LT General Discussions 29 02-09-2009 01:42 PM
Removing the Cats? ctk1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 55 12-27-2008 11:59 PM
