HeadlightArmor
Old 05-07-2011, 04:14 PM   #1429
Without Remorse
Without Remorse's Avatar
Drives: 2011 2SS/RS RJT Convertible
Dynolicious is an awesome app. It's pretty acurate. I found within a tenth either way if you have it set up right. You gotta get the weight right in order to use the horsepower feature but it's pretty fun to play with.
I haven't used it for a long time but here is an old run from before my supercharger.
Attachment 237701
Attachment 237702
Attachment 237703
That is the coolest darn thing I have ever seen. Problem is that I have a Blackberry Bold. This only works on Blackberry Storm.....Drats!
What is the one common thread in all of your failed relationships?
Without Remorse is offline   Reply With Quote
Old 05-07-2011, 05:36 PM   #1430
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Time for an iPhone.......
Old 05-07-2011, 11:09 PM   #1431
Without Remorse
It makes me want to buy the IPhone just to get this app. BTW, I left the fuses out for 20 hours and got no result. Fuse pull/no fuse pull, nannies/no nannies.....no change in performance or punch. I'll try to rig up my camera and do a 0-60 test.
Maybe I'll buy an LS9 badge. I've been told that adds 20 horses.....
Old 05-07-2011, 11:35 PM   #1432
PQ
Booooosted.
PQ's Avatar
I have an LS9 Map sensor and got 25 hp.
Old 05-08-2011, 12:35 AM   #1433
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
okay so i just pulled mine lets see if I have better luck than you, WR.
Will check back in the morning....
SlowSS is offline   Reply With Quote
Old 05-08-2011, 09:51 AM   #1434
SlowSS
SlowSS's Avatar
Well just got back from a short drive. The car seems to idle alot better...I would like to think that it pulls a little harder but I think that is just me looking for improvement
Old 05-09-2011, 10:04 PM   #1435
faussy
Mechanical Engineer
Drives: 2013 camaro zl1
Send a message via AIM to faussy
will this effect performance say if there are any mods to the car such as intake exhaust etc
faussy is offline   Reply With Quote
Old 05-19-2011, 11:37 PM   #1436
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
If you have been using 87 oct and have not done the fuse pull before then yes. The fuse pull is just to reset the ecu if the dealer or yourself put in low grade gas, if you and the dealer have always used high grade gas then don't need to pull the fuses.
bajamoon is offline   Reply With Quote
Old 05-19-2011, 11:45 PM   #1437
PQ
Booooosted.
PQ's Avatar
Could be. But at least you know you're getting he full 8s worth.
Old 05-20-2011, 05:27 AM   #1438
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Originally Posted by TACamaroSS View Post
Also I bought it in Jan. which means it sat since may 2010 with only 87 octane I'm on my first tank of premium now so it might take a couple of tanks I'm thinking...and hoping. If I get a chance I'll time it this weekend and report back.
YES, if it gets any hint of knocking with some of the old gas weakening the octane level it will drop right away back to the low octane tables. Best to run two to 3 tanks and then fuse pull.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-20-2011, 05:31 AM   #1439
Scott@Bjorn3D
Problem is sometimes you can get old gas. Meaning as 93/91 octane site in the tank in the ground the octane blend will seperate. So it will get lower. That is the big problem for all of us right now since not many people that should use high octane are not.
There was testing done that 93 octane sitting in the in ground tanks more than a month actually droped to 89 octane. That will kick in the low octane table.
So always try to go to a name brand station and a very busy one if you can.
Old 05-20-2011, 06:48 PM   #1440
TACamaroSS
TACamaroSS's Avatar
Drives: 2010 Camaro 2SS RS SW IOM interior
Just an update. I did the fuse pull again for 3 hrs. and unhooked the neg cable. The car is now a monster! It will light em up without trying. I turned off the traction control and had lots of fun. I haven't tried it with all the nannies off but it should be exciting to say the least. Also I did the muffler delete so it sounds good too.
TACamaroSS is offline   Reply With Quote
Old 05-22-2011, 09:51 AM   #1441
bajamoon
bajamoon's Avatar
Always use name brand, chevron or shell only with 91, highest we have here.
Old 05-22-2011, 11:41 AM   #1442
zare6
Drives: 2011 ss ls3
Is this necessary-fuse pull
Hi, I just brought my new ss home it has the ls3 engine, I asked my dealer about this apparent flaw in the fuel mapping and he said there is none. I have other vehicles with knock sensors and if they happened to detonate they reset when you restart them, always. I cant believe this car would not do the same, the engine cant tell what kind of fuel you have put in it, it can only react when it senses detonation, none of what you guys are talking about makes sense imo.
zare6 is offline   Reply With Quote
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 05:07 AM
What kind of gas are you filling up with in your '10 Camaro? JewelZ 5th Gen Camaro SS LS LT General Discussions 42 08-02-2009 10:31 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
