BeckyD @ James Martin Chevy
Old 04-27-2011, 12:51 AM   #1373
HighMtnSS
HighMtnSS's Avatar
Drives: '13 AGM 2SS/RS 1LE, 1 of 139
Sounds like the answer would be "Yes!"
Definitely can't hurt...
My fuses are pulled now and I plan to plug 'em back in tomorrow...
I'll report back w/results!
HighMtnSS is offline   Reply With Quote
Old 04-27-2011, 01:28 AM   #1374
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by jmat View Post
Unfortunately I didn't notice much change. But I haven't really felt that there was a problem. This is still an excellent find for those who it has helped!
Sounds like you were good to go already.
Originally Posted by Raptor626 View Post
Question: How do you know if your car requires this or not?
I have about 850mi on my L99 so far and can easily spin the tires/get a shitload of wheel hop with the TC turned ON and medium throttle.
Does anyone think I need it?
Doesnt sound like it but I've said all along to time it. Video tape the IP or use an accelerometer and time it 0-60mph. That will tell you.
Originally Posted by fargomike View Post
I had one tank of 89 go through and the rest have been 91 as 93 is not availabe . Would the fuse pull make any difference ?
Should. Your car should have pulled timing during the tank of low grade. Unless you never got on the gas hard.
Should have timed it first. But you'll know if it's beneficial.
Old 04-27-2011, 01:49 AM   #1375
L99CAMA2011
L99CAMA2011's Avatar
I am scared to try the fuse pull, however doing this to my CAI(Cold Air Induction) intake, replacing the restrictive CAI cone and putting this AFE 2007 Mustang GT 4.6l 3v intake filter on the CAI tube made a great difference. Engine revs and accels like a 4 valve per cylinder engine. Now no more complaints from me about performance. I also noticed that keeping my lid off the CAI allows the air flow from under the window washer fluid bottle to flow freely upwards. Is there any danger in doing the fuse pull. My CAMARO pulls hard is hell since I put the AFE filter on there.
Old 04-27-2011, 10:01 AM   #1376
nancygrl
銀幽霊
nancygrl's Avatar
Drives: '17 Z71 Truck
What's to be afraid of ??? If you've never put in low octane gas, and are 100% certain the dealership didn't either then no need to do it. If there's any chance that your Camaro has ever had low octane gas in it, the you need to do the fuse pull to get the most out of your car. There is nothing to be scared of.
Previous rides: '17 ZL1 M6,'16 2SS/A8, '15 1SS/1LE/M6, '13 Hotwheels RS, '11 2SS/M6
nancygrl is offline   Reply With Quote
Old 04-27-2011, 12:38 PM   #1377
PQ
Booooosted.
PQ's Avatar
There is much more danger in installing a CAI.
Sounds like you may not need it. Go time your car. Get a video camera, video your speedometer and you accelerate from a standstill. Put it on the computer and time it to see how long it takes you to hit 60 mph. You can cut the video at both ends to get as acurate of a time as you need. If you're down around 5 second-ish then you're probably fine. If you get a ton of wheel spin making it hard to get an acurate run, then you're probably fine.
If you're around 6 seconds-ish then you need a fuse pull. Check out my vids linked in the OP of this thread. It makes a huge difference.
Old 04-27-2011, 01:12 PM   #1378
Nvincent4708
1st State Camaro
Nvincent4708's Avatar
Drives: 2014 1SS M6
So i'm assuming if i'm HPTuned and my low octane / high octane spark tables are the same. I don't need to do this ever?
Nvincent4708 is offline   Reply With Quote
Old 04-27-2011, 02:49 PM   #1379
PQ
Booooosted.
PQ's Avatar
That is correct. If you're sure all your tables are the same, then you won't have a problem. Of course, you better not put low grade in it.
Old 04-27-2011, 02:55 PM   #1380
Nvincent4708
1st State Camaro
Drives: 2014 1SS M6
I wouldn't dare hurt my car like that. haha. 92+ is all it gets.
Old 04-27-2011, 02:57 PM   #1381
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
I'm "pullin" again tonight. Will post results tomorrow morning for LS3
f5journal is offline   Reply With Quote
Old 04-27-2011, 02:58 PM   #1382
PQ
Booooosted.
PQ's Avatar
lol
Again?
Ok, went back and looked. Ya, try it but if you can, time it first.
Old 04-27-2011, 10:12 PM   #1383
B Mccue
Drives: 2011 1ss ls3
Fyi, did nothing for my ls3 till I pulled the negative cable at the same time. Fixed it after that, I was about to take it in for service.
B Mccue is offline   Reply With Quote
Old 04-27-2011, 10:32 PM   #1384
L99CAMA2011
Actually the gas attendant put 87 octane in my car last Friday by mistake 1 gallon only, I had to return my car to stock tune after that.
Old 04-27-2011, 10:35 PM   #1385
GQ4Life
Drives: 2010 Camaro SS LS3
I always watch what button they hit when I am in NJ.. I usually still try to pump my own gas in NJ eventhough you are not allowed
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 04-27-2011, 10:41 PM   #1386
PQ
Booooosted.
PQ's Avatar
It's weird to hear that. Since the schematics are nearly identical. Should be just the fuses but we've had enough people swear by it. Must have to do with the transmision wiring. With the TCU in line somewhere.
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 05:07 AM
What kind of gas are you filling up with in your '10 Camaro? JewelZ 5th Gen Camaro SS LS LT General Discussions 42 08-02-2009 10:31 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
