Old 08-24-2009, 04:54 PM   #1
lbs13
Wilmes Winner!
lbs13's Avatar
Drives: RS/1SS/IBM
Post Pro's and Con's L99 vs LS3
What's good and bad? Which is easiest to mod? What has the most potential?Currently awaiting my RS/1SS/A6/IBM
lbs13 is offline   Reply With Quote
Old 08-24-2009, 05:00 PM   #2
attymf
attymf's Avatar
Drives: 2017 SS
The obvious first:
426 hp and 420 tq for the LS3 to 400 hp and 410 tq for the L99.
attymf is offline   Reply With Quote
Old 08-24-2009, 05:02 PM   #3
H & E
Hinson
H & E's Avatar
Drives: 2018 Hyper Blue 1LE
Why did I wait this long to buy this car?
H & E is offline   Reply With Quote
Old 08-24-2009, 05:03 PM   #4
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Originally Posted by attymf View Post
The obvious first:
L99 Tune vs LS3 tune will pretty much null those numbers out... assuming you will tune at some point....
Auto start is cool for L99
Old 08-24-2009, 05:06 PM   #5
Ammo7
I GOT HER
Ammo7's Avatar
Drives: 2010 Camaro 2ss/rs RJT
Anyone know where to get a tune done in the north atlanta GA, area?
thanks
2SS RJT sun roof RS package Auto.
Order Detail # NMMXX3.
Order date- 07/21/2009
2000, Order accepted by GM0-8/11/09
3000, Order accepted by production control 8/12/2009 TPW 09/07/2009
3300, Order scheduled for production 08/25/09
3800, Order produced 09/12/09 2G1FK1EJ6A9145958
4200, shipped 09/14/09
5000 vehicle at dealer 09/28/09
6000 vehicle delivered to customer 09/28/09
Ammo7 is offline   Reply With Quote
Old 08-24-2009, 05:08 PM   #6
Lee9710
Drives: 2013 Summit White ZL1
Send a message via Yahoo to Lee9710
Roughly the same power regardless of what the hp and torque numbers say. L99 will be more mod-friendly and seems to respond much better to a good tune. The L99s that are actually running correctly have been a touch quicker in the 0-60 times but the LS3 takes it by .1 or .2 in the 1/4 with a higher top end speed. The paddle shifters once you get good at it could make up for that .1 or .2 secs in the 1/4. Seems like the LS3 sounds a little better with an aftermarket exhaust put on, but both are great engines as long as the L99 isn't one of the ''problem children''.
Proud Owner of the baddest Camaro ever built
ZL1
Lee9710 is offline   Reply With Quote
Old 08-24-2009, 05:12 PM   #7
lbs13
Wilmes Winner!
lbs13's Avatar
Drives: RS/1SS/IBM
What exactly is envoled with a good "tune" with one of these. I'm one of the old caburated guys, been out of it all for a few years. They just hook it to a laptop or what?
Old 08-24-2009, 05:38 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
The "problem child" issue on the L99s seem to have a fix now. Pulling the fuses for the ECM...Do a search...so far it seems to make a big difference.
Yes...they use a laptop to make the adjustments but there is WAY more to it than just hooking it up to the lap top. Where you would change out the Jets and Squirts and things like that on a carb you do those sort of things using software. Obviously you can fine tune it much more than a carb and you typically need the car on a dyno to get a baseline run and then some runs after adjustments. This is NOT something you are going to want to try on your new Camaro. Take it to a professional speed shop and make sure they've actually worked on a 2010 Camaro before. Also know that more than likely you will void your drivetrain warranty with a tune because the ECM (on board computer) will let GM know that the factory tune has been overwritten thus voiding the warranty.
Build Journal
Old 08-24-2009, 05:40 PM   #9
lbs13
Wilmes Winner!
lbs13's Avatar
Drives: RS/1SS/IBM
Anything we can do and keep the warranty, at least that is worth doing?
Old 08-24-2009, 05:41 PM   #10
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
thanks
MTI Racing is in Marietta and Vengeance Racing is also right around there.
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 08-24-2009, 05:51 PM   #11
1320junkie
Drives: The Imperial Army
thanks
MTI, Vengeance and a bunch of other shops...do you have an L99 or LS3? I got a great deal that I can turn you onto with the guys at MTI...you cant beat it
Old 08-24-2009, 05:59 PM   #12
mlee
www.CamaroFans.com
mlee's Avatar
Basically a flash to your ECM (electronic control module). These cars are setup very conservative and run VERY rich. Timing, fuel mixture... For L99 the TM torque managment is a huge upgrade to when and how your transmission shifts. You can also get rid of AFM so it won't cut down to 4 cylinders.
Drivetrain warranty is basically dead with a tune. Try CAI Cold Air intake and Catback exhaust for starters if you want to keep warranty.
Old 08-24-2009, 09:06 PM   #13
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
There is no better Camaro. For those who drive for function, the automatic transmission will always be more consistent, but manual transmission proponents will always proclaim that their car is more fun to drive. Both are 6.2L V8s, and both will have equal access to tuning software that will allow users to make them hit similar performance numbers when using the same afermarket components. Each has mainstream aftermarket manufacturers building parts, and the internals match. Even if it were possible to argue that one would have slightly better track numbers in an ideal match, the other could just as easily win the next race. In all truth, they are such an even match when the same parts are applied that there is no difference in performance.
If you're going to compare the two Camaros, then it all comes down to discussing the transmission. Is a flywheel better than a torque converter? Which company makes the best part that would create a significant gap when compared to the other car? In order to tell, we'd need to test two identical Camaros except for their transmissions.
At the end of all of this analysis, it comes down to miniscule differences, begging a question: which one would you rather drive? That's all the really matters.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 08-25-2009, 03:34 AM   #14
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
neither are bad both are great
could one be better then the other for you and your overall goal and intentions for the car sure. but that only comes down to what tranny you prefer auto or manual
both are really the same when it comes to modding, one is the same as it's been for a long time, the other is slightly different due to newer technology(that actually works this time lol)
Gentry78 is offline   Reply With Quote
ls3 vs l99
What are the pros and cons of supercharger vs. turbo kellertxgen5 Forced Induction - V8 10 10-20-2009 11:00 PM
Pros & Cons on muffler delete RoyalKev Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 12:51 AM
Sunroof Option: Yes or No...Pros and Cons DCJ 5th Gen Camaro SS LS LT General Discussions 55 06-24-2009 10:04 AM
What do you think the pros and cons are of these colors? Ant 5th Gen Camaro SS LS LT General Discussions 18 03-22-2009 07:33 PM
