Rick@Livernois
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 08-27-2009, 01:36 PM   #1
25th anniversary
Drives: 1992 RS 25th Anniv. Edition
Camaro stops running
Has anyone has this problem? I have a 1992 RS 305 V8 and twice, once while driving and once sitting at a stop light, the car just stops running. The best way I can describe it is as though someone has turned the light switch off. I wait a few minutes and I can start it again and it seems to run just fine. Have had it to the shop on both occasions and they cannot get the problem to duplicate. Had the fuel pump relay switch replaced about a year ago. Anyone have any thoughts?
25th anniversary is offline   Reply With Quote
Old 08-27-2009, 02:52 PM   #2
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '00-Z28
Possibly the pump itself? My '92 RS 305 went through 2 fuel pumps, but when they went out that was it, no starting it back up.
'98 Dodge Avenger - Beater
'72 Cutlass - Toy
'00 Z28 - REDRUM - 12.312@111.62 DA:2500' blowing through TC, new TC installed, 11s here I come
Chocolate Apocalypse is offline   Reply With Quote
Old 09-02-2009, 05:09 PM   #3
25th anniversary
Camaro Stops Running
Apparently it's not the fuel pump because I can restart the car. Have talked to the mechanic and the new catalytic converter has no bearing on this issue. Any other thoughts?
Old 09-02-2009, 05:26 PM   #4
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
That happened to my old mans Celebrity station wagon. The CPU was going bad. He spend around $600 to get a new board. Computer related issue.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 09-02-2009, 05:35 PM   #5
25th anniversary
Okay, thanks so much. I will advise my mechanic and see where we go from there.
Old 09-05-2009, 10:54 AM   #6
AZCamaroFan
9 YEARS on Camaro5/6
AZCamaroFan's Avatar
Drives: sometimes
Yeah i had to replace a fuel pump in my 3rd gen. This doesn't sound like that.
Old 09-18-2009, 11:58 PM   #7
jimwww
jimwww's Avatar
Drives: 1987 Camaro IROC-Z 350, 5spd
Yup - had the same issue - buy some anti freeze for the gas tank (methyl hydrate me thinks) and put it in - usually white bottle. It absorbs water which sometimes forms in the gas tank - like mine did when sitting for 7 months. I put it in - and viola it does not do it anymore.
]1987 Camaro Iroc-Z, 350tpi, 5spd, t-tops, flat black, 4 wheel disc, posi, susp lowered 1.5 inches.
http://www.jimwww.com/jimsz/jimszfrntx200.jpg
2010 Dodge Challenger SXT.
jimwww is offline   Reply With Quote
Old 10-11-2009, 09:08 PM   #8
camaro pilot
Drives: 1989 IROC Z28 w/350 engine
I had the exact same problem back about a year ago and also thought it was the fuel pump, it wasn't. the problme that you are having is with your mas airflow senser. It ia a chip that measures the air flow from your intake down into your engine to make sure it is being ventilated properly. When the chip goes bad it doesn't signal properly so the computer shuts the car off to prevent a blown engine. The chip is housed in a piece of plastic pipe right at the back of where your air filter covers go down from two to one right there in the very front of the engine compartment.
There are two fixes. 1) you can just unplug teh wire form it and leave it hanging. as long as the computer doesn't receive a bad signal you are good. No signal means a good signal for the computer. 2) spend about $35 on a new one. I got a new one from an Auto Parts store. Walk in and tell them you need a "mas airflow senser" for your camaro and if they know anything abou their job they can get it for you really fast.
camaro pilot is offline   Reply With Quote
Old 10-13-2009, 12:33 PM   #9
IROCanSS
Drives: 89 IROC 350
Its not a fuel pump, your cat, your MAS, or your computer.
Bad pump = no start
bad cat = rough running, smelly, chokes it self out, poor flow, hesitation
bad MAF = check engine light
bad computer = dead car
I'd bet its your ignition module. Very common problem. They overheat and the car just shuts off like a switch. Usually you wait a few minutes to let it cool and it starts back up. very easy and cheap fix. Its under the dist. cap. take off the cap, pop off the rotor button and its right there. unscrew/unplug it and replace it. don't forget the heat gel. easy job.
Old 10-13-2009, 09:54 PM   #10
burnout88
burnout88's Avatar
Drives: 88 IROC
I agree it's sounds like the ign. module. Very common. He has an RS which does not have a MAF sensor. The ign. module is the the most likely cause.
88 IROC, Medium Orange Metallic, 5.0, Auto, 3.73 gears, nitrous
burnout88 is offline   Reply With Quote
Old 12-26-2009, 03:09 PM   #11
Dmeine13
Drives: 25th Anni. Z28 Camaro 25000< Miles
Not sure what the prob is. Mine had a fan cut through the ignition wire so when I came out of blockbuster... boy did I have a scare.
Dmeine13 is offline   Reply With Quote
Old 12-27-2009, 02:52 AM   #12
Iroczlover
The Krazzy bytch
Iroczlover's Avatar
Drives: Which car I have 9 vehicles?
Send a message via MSN to Iroczlover Send a message via Yahoo to Iroczlover
check your battery connections. lose or bad battery cable can cause this
Heart breaks everyday when you cant take care of your family because you are unemployed, cant give your family what you want or what they need
I am not a man I have boobies.
Cars are like women, If you treat her rough shes going to complain & you will hear about it. If you treat her right she will purrrrrrrrrrrrr
Current cars owned , 72 Skylark vert,86 fiero GT Sold , 87 Iroc-z, 90 Vette Vert SOLD , 95 Z28, 99 Silverado K1500, 2010 CGM Camaro 2ss/rs (had to sell & I hate it ) ,2012 Cruze LT
Iroczlover is offline   Reply With Quote
Old 12-27-2009, 02:58 AM   #13
rodimus prime
Drives: Cargo van.
Bad pump = no start
What he said.
My 91z28 pulled this stunt on me a couple times and I needed a new coil.....twice in about a year. The second time I bought an MSD coil and no more problems. But it pissed me off to holy hell. Happened once at a red light too.
rodimus prime is offline   Reply With Quote
Old 01-09-2010, 03:33 AM   #14
GOBLIN
burnin rubber
GOBLIN's Avatar
Drives: 1992 CAMARO RS
Yea I agree with jrhaus76. Mine would do the same thing everyday after being on for a while. I changed the ign. module and starts every time and stays.
GOBLIN is offline   Reply With Quote
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 370 02-19-2017 02:24 AM
Songs About Camaros (for your driving pleasure) Emjay 5th Gen Camaro SS LS LT General Discussions 74 12-18-2014 12:42 AM
Chevrolet Camaro convertible reportedly back on, albeit running late camaro5 5th Gen Camaro SS LS LT General Discussions 15 03-24-2009 06:42 PM
4 SEMA CAMAROS finally unveiled by GM! (hi-res images & details) FenwickHockey65 Camaro Photos | Spyshots | Video | Media Gallery 237 11-03-2008 10:39 PM
