Old 08-27-2009, 05:58 PM   #1
SS2w/aSCREW
Drives: Silver ss
Driveline noise/clunking
Hey, Experiencing clunking sound when I unload clutch at lo speeds.
Would like to know if anyone else has found this to be an issue.
Thanks
SS2w/aSCREW is offline   Reply With Quote
Old 08-27-2009, 07:34 PM   #2
WySS
WySS's Avatar
Drives: 2010 Camaro 2SS RS M6 CGM A9125214
There is a post about this already. Normal operating characteristic with the independent rear suspension.
http://www.camaro5.com/forums/showth...ighlight=clunk
"Well from your description it sounds like you're lugging the car a bit when shifting (which actually is normal since these cars are designed to be skip shifted and lugged in the next gear). If you take the revs up a little higher you'll notice that the clunk goes away.
The clunk is the slack in the driveline. Because of the IRS, you now have 2 extra U joints that will "slack" when you press the clutch in to shift and then when you begin to let the clutch back out, that "slack" is drawn back up quickly. It's very normal for IRS cars.
But if you're concerned, by all means, take the car into the dealer and have her looked at. "
WySS is offline   Reply With Quote
Old 08-31-2009, 11:23 AM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I hear the sound you are refering to also. Sounds like the front u-joint or the output shaft area, only happens when shifts are a little sloppy, but it makes me wonder.
Old 08-31-2009, 11:57 PM   #4
slacker
Troubled 40 something
slacker's Avatar
Drives: 2010 IOM RS/SS M6
I have it too, but chalk it up to piss poor shifting ability...on my part. It only happens at low speeds.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=8680&dateline=1260288  130
slacker is offline   Reply With Quote
Old 09-01-2009, 12:00 AM   #5
rharon
rharon's Avatar
Drives: 2010 Yellow 2SS/RS
While i was installing the exhaust I noticed that there was a bolt loose on the transmission mount. Take a look. There should be 2bolts I beleive its a 15 mm
Magnacharger TVS2300, ARH HEADERS, ROTO-FAB CAI, NOWEEDS.NET DIVERTERS
rharon is offline   Reply With Quote
Old 09-01-2009, 12:05 AM   #6
slacker
slacker's Avatar
Nice- I'll check that.
Old 10-09-2009, 08:20 PM   #7
Dboy23
2G1FB1EV7A9100028
Dboy23's Avatar
Drives: 2010 Jeep Wrangler Hemi
The rear driveshaft needs a spacer, GM's gonna release a fix for it within the next week or two. Nothing you can do about it but wait trust me.
# 28 - Victory Red 1LT/RS (SOLD)
Dboy23 is offline   Reply With Quote
Old 10-09-2009, 08:40 PM   #8
camarorick
camarorick's Avatar
Drives: .
Originally Posted by DOB View Post
The rear drive shaft needs a spacer, Gem's gonna release a fix for it within the next week or two. Nothing you can do about it but wait trust me.
When I was in Oshawa for the meet & greet, we had a tour in the Martinrea plant ( suspension manufacturer ). The gentleman who was giving us the tour mentioned that there was some type of washer added to the drive shafts to eliminate the drive line noise....
camarorick is offline   Reply With Quote
Old 10-09-2009, 08:46 PM   #9
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
Wow that is great news the clunking sound from my drive train drives me nuts,I have driven many manual cars including vettes and have never heard sounds like this.
rex113 is offline   Reply With Quote
Old 10-09-2009, 09:09 PM   #10
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
i got the same problem but never researched it. so its normal?
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 10-10-2009, 07:39 PM   #11
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
yeah, i have the same thing--just posted in another thread. only at very low speeds when disengaging the clutch sometimes into neutral. glad to hear it's not a clutch issue.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 12-17-2009, 10:14 AM   #12
IndyStrube
IndyStrube's Avatar
Drives: CGM SS/RS
Is there any update for a possible driveshaft spacer? If something is avaialble has anyone tried it?
IndyStrube is offline   Reply With Quote
Old 12-17-2009, 12:35 PM   #13
JHart
I haz camaro again :)
JHart's Avatar
Drives: 2010 Chevrolet Camaro 1SS
mine does this really bad when i'm in reverse, i back it up 10-15 feet out of my garage and push the clutch in all i hear is clank clank clank, then it stops, hardly ever does it going through the gears, but every now and again i hear it. any help????
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd)
2010 camaro1ss(sold, missed, will have another someday)
JHart is offline   Reply With Quote
Old 12-17-2009, 03:28 PM   #14
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
When I shift perfectly it doesnt happen.
SleepWarz is offline   Reply With Quote
