Cold Air Inductions
Old 08-29-2009, 12:43 PM   #1
Croathlete
Danny
Croathlete's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to Croathlete
Question How much can I do before I need to tune?
Well, I'm still leery on tuning the car unless someone comes out with a 100% method of going to back to stock and being undetectable. I've seen the thread posted earlier, but I'll need to see some more people give it the go ahead before I consider it.
So this is where I stand; I have the Noweeds cutouts already installed. The car sounds amazing. I'm planning on getting the Vararam intake when it becomes available in September. Both (cutouts and intake) are advertised to work within the ECU's parameters to adjust to whatever changes occur and do not throw any codes.
I'm now looking at headers. Long tubes are out of the question since even high flow cats can throw a code and would need to be tuned out. So that leaves me with the Doug Thorley shorties. My only concern with purchasing these is, will this become the tipping point where I begin to run lean with all this increased airflow? Is it possible with all these bolt-ons that I will need to tune for the car to run efficiently/correctly?
Any suggestions are welcome as I'm nowhere as knowledgeable as some on this board. I know many will say to just tune the car, but as to many others, having that powertrain warranty to lean back is important to those that can't afford to just go out and buy another car. Sorry if that sounds rash, but I don't want to take that risk.
2SS/RS CGM with black rally stripes
DON_RAFA describing my Noweeds cutouts - "Very Strong. When I couldn't see you I still heard you. Sounds like your car is pissed at the world."
Please help me fight back by supporting me in the 2010 American Cancer Society's Relay for Life. Every little bit helps. Click here for more information. Thank you to those that have donated!
Croathlete is offline   Reply With Quote
Old 08-29-2009, 12:49 PM   #2
fdjizm
Drives: 2008 Mustang GT/CS
axle backs, underdrive pulleys, i have also heard of non-tune cams. maybe a new air filter, not much you can do without a tune if you want some nice HP gains, even new rear end gears require recal. of the ECU to fix the speedometer.
fdjizm is offline   Reply With Quote
Old 08-29-2009, 01:25 PM   #3
SGOS252382
SGOS252382's Avatar
For anyone that wants to be 100% safe about their full factory warranty, you should limit your mods to a catback exhaust and maybe an intake.
And anything more than just an intake and catback exhaust "should" be tuned.
If you do plan on long tubes (without a tune) I would suggest getting the car on a dyno to make sure the a/f ratio is safe. If you damage your motor because of a lean conditions, your warranty's out the window even if you don't have a tune (if your running long tubes and high flow cats).
Old 08-29-2009, 02:32 PM   #4
Croathlete
Danny
Croathlete's Avatar
Well, I said in my OP that I wouldn't go with LT's and that I would consider shorties. Good idea though to check the A/F ratio after the mods.
Old 08-29-2009, 03:40 PM   #5
SGOS252382
SGOS252382's Avatar
GM should eventually come out with their shorties. And if you go with shorties you shouldn't run into any warranty issues as long as you leave the stock cats alone.
But that will keep the HP gains in check.
I put shorties on one of my LS1 z28s (not sure why because I ended up putting cam/heads on the car later) and saw modest gains. But its a good alternative for someone wanting to keep their warranty.
Old 08-29-2009, 04:57 PM   #6
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
without a tune the torque management will restrict so much. Needs to be tuned to off for real performance gains.
lawdogg149 is offline   Reply With Quote
Old 08-29-2009, 05:25 PM   #7
SGOS252382
SGOS252382's Avatar
Yeah, its always been my first mod. But I can see why some guys are avoiding it (want to keep their warranty).
But it is by far the best mod for the L99. Just removing the Torque Managment is like adding 30hp to the car.
Old 09-03-2009, 01:17 PM   #8
How do I remove the torque management on my L99?
Old 09-20-2009, 04:28 PM   #9
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
Get a tuner or get it tuned.
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
RickyTheStorm is offline   Reply With Quote
Old 09-25-2009, 12:25 AM   #10
2Tightwads
Banned
Drives: 2002 LS1 swapped into a 1994 Z
Short of a cam install (small cams may not require one) you really don't NEED a tune. Now if you want to take full advantage of the power on tap...TUNE IT!
2Tightwads is offline   Reply With Quote
Old 10-10-2009, 05:59 PM   #11
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Is torque managment calibrated into both the L99 and the LS3?
Jeanius is offline   Reply With Quote
Old 10-12-2009, 01:32 AM   #12
rcracer78
rcracer78's Avatar
+1
rcracer78 is offline   Reply With Quote
Old 10-12-2009, 09:54 AM   #13
2Tightwads
Banned
Yes, but different between the (2) for certain. There is some form of trans/engine torque management settings that can be updated between either one.
American Racing Headers for 2010 Camaro yields +32rwhp w/o tune, +50rwhp with tune ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 226 08-09-2013 06:01 PM
Another L99 Dyno tune (with headers and CAI) pcmforless Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 02-26-2011 07:36 AM
Do I really need a tune or will the Computer re-calibrate? Edrock Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 07-30-2009 02:56 PM
GMPP LNF Tune The_Blur General Automotive + Other Cars Discussion 22 01-07-2009 05:57 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
