Jason 98 TA
Old 03-06-2015, 02:21 PM   #29
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Interesting
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you donít forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 03-06-2015, 03:25 PM   #30
AquaSSRS
AquaSSRS's Avatar
Drives: formerly a AGM ZL1 (sold)
Subscribed. Will be doing this once my garage is warmer and this weather breaks.
2013 Ashen gray ZL1 M6 with Roto-fab, Vmax TB, Pfadt headers, 10% pulley, JRE tuned. 11.459 @125mph. 566hp/517tq. Sold due to not enough seat belts. FML.
AquaSSRS is offline   Reply With Quote
Old 03-06-2015, 03:30 PM   #31
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Are we really going to feel 10-15hp in a 580hp car......just wondering....
Mods:
Old 03-06-2015, 03:32 PM   #32
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Does anyone know if there are negative affects from this? Why doesn't the factory do this or is it just an adjustment that is off? How does it affect a tune or no tune?
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 03-06-2015, 04:15 PM   #33
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Well if the difference was larger but 1 psi isn't a huge amount. It could also create more heat which would reduce the hp. So it becomes a balancing act.
9/26/09 Took delivery!
Old 03-06-2015, 04:58 PM   #34
RockerBox
RockerBox's Avatar
Drives: 2010 Silverado. Stock height now
I would only make the gap just large enough to keep it shut. You will want the bypass to work when it needs to.
RockerBox is offline   Reply With Quote
Old 03-06-2015, 05:08 PM   #35
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
What if someone adjust this too tight and the WG does not open when needed? Kaboom?
Mods:
Old 03-06-2015, 05:14 PM   #36
unstable vic
Drives: 2014 ZL1
Good point
unstable vic is offline   Reply With Quote
Old 03-06-2015, 08:43 PM   #37
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
I don't think that's possible. The top bolt hole on the bracket has a enough wiggle room to only adjust it a small amount. I did it to mine today.
CAM....ZL1 is offline   Reply With Quote
Old 03-06-2015, 08:44 PM   #38
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
I just got the boost back I lost with my headers. Lol
Old 03-06-2015, 08:46 PM   #39
EvilZL1
Snake Eater
EvilZL1's Avatar
Forgot about that lost boost lol
Sent from Wayne's Manor
Old 03-06-2015, 08:47 PM   #40
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
Could this possibly make you run a little lean? Can someone that knows give a little insight on this. Would I need a retune?
Old 03-06-2015, 09:12 PM   #41
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Added heat and stress on the supercharger. Kaboom, probably not unless the computer manually opened the bypass to avoid something catastrophic.
I know of some people who disable the bypass at the strip but not something I really wanted to try...
2013 ZL1 #7860 is offline   Reply With Quote
Old 03-06-2015, 09:14 PM   #42
2013 ZL1 #7860
I am by means no expert so take this as my uneducated opinion only...
The air is already measured (MAF) regardless of whether it is bypassed or not. So I would think, the computer would measure more airflow (MAF) and then adjust accordingly. If it made a huge change in PSi then I would consider having the tune adjusted just to be on the safe side and make sure you are using all the power available.
