B&M Racing
Old 08-29-2009, 06:44 PM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Check out this new 6 Speed Auto!!
http://www.gmhightechperformance.com...rts/index.html
They say it can handle 800HP. L99 fans get ready to soup up that car.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-29-2009, 07:02 PM   #2
rodimus prime
Drives: Cargo van.
That would actually be sick for the 4th gens. It would be a direct swap.
rodimus prime is offline   Reply With Quote
Old 08-29-2009, 07:09 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
not really a direct swap for anything unless it came with a 4l80e(most older 3/4 ton trucks)
that is just a modified 4l80e and even the 4th gen guys have to do extensive modifications to get them to fit/work
and would truly be a step backwards from the 6L80E that we have in the gen 5 camaro
Old 08-29-2009, 10:19 PM   #4
Scott@Bjorn3D
So you are telling me our trannies could handle 850HP?
If so why does GM have the torque management making our cars dogs off the line.
Old 08-31-2009, 09:09 AM   #5
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
FYI -
TCI has been advertising this for about 6 months. Supposedly the transmission TCI is selling is NOT the 6L80E.
"The TCI 6x is a 4L80E that splits the first second and third gears with the overdrive unit. It is very much like a TH400 with a Gear Vendors overdrive unit, but it's all in one case and the ratios are a bit different. (First and second are both lower than stock, which makes a lot of sense to do, since the splitter (OD) reduces the gear drop significantly.)"
GM offers sneak peek of Detroit auto show display KILLER74Z28 General Automotive + Other Cars Discussion 7 12-02-2013 06:01 PM
2006 TRAVERSE CITY AUTO CONFERENCE KILLER74Z28 Off-topic Discussions 2 09-18-2010 10:45 AM
Speed Cameras...Know Your Enemy 1_2Many Off-topic Discussions 20 08-13-2009 02:37 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Help for Auto Industry Could Come Soon - Treasury Sec. Paulson to be Car Czar camaro5 General Automotive + Other Cars Discussion 7 12-15-2008 05:52 PM
