IPS Motorsports
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 08-30-2009, 02:06 PM   #1
Bbrock25
Bbrock25's Avatar
Drives: 2010 1SS/RS Inferno Orange
Parking
So whenever I park, I always put it in neutral, and pull on the E-brake. However my dad has drove it a few times, and always leaves it in 1st, and it tends to roll up an inch or two, like any auto trans would w/o using the E-brake. My question is, well I don't think once or twice is gonna hurt anything, but either way N w/ Ebrake, or 1st w/o it will it do any damage or hurt the longevity of the tranny?
I live in Ky, and it tends to get pretty cold here in the winter (the coldest is like 10 or so which only happens a handful of times (nov-feb), but the normal is 20-35) and my dad says pulling the E-brake when it gets cold it will freeze up n stuff?
Bbrock25 is offline   Reply With Quote
Old 08-30-2009, 02:23 PM   #2
jpsuperman81
That's Right 478whp450tq!
jpsuperman81's Avatar
Drives: 2010 2SS/RS Rally Yellow
I think for safety you should use ebrake and 1st or reverse depending on incline. Some people swear by parking in gear, I have always been a ebrake only person but some people have mentoned that not holding the camaro unless you make sure you pull it until it fully clicks, I been using brake and gear lately just to get into habit.
I would like to apoligize ahead of time if any of my posts bother you, I am quite a large smartass and very expressive of my opinion!
I came here to chew bubble gum and kick ass and I'm all out of bubble gum!
Ordered Feb. 13 2009: 2SS/RS/M6/Sunroof/ Rally Yellow built 8/7 Vin# 33534, Delivered 8/26/09!
jpsuperman81 is offline   Reply With Quote
Old 08-30-2009, 02:35 PM   #3
Bbrock25
Bbrock25's Avatar
I see, I park pretty much in the dead level lol.
Old 08-30-2009, 03:08 PM   #4
Timberline
Timberline's Avatar
Drives: 2010 SS/RS,LS3,M6,VR
1st no e-brake will be fine, the car won't go anywhere.
Your dad is correct using e-brake in the winter will more than likely freeze in one possition or the other, I have seen this happen.
You really only need th e-brake when you park on a hill or slight grade.
If you insist on using the e-brake put in 1st not nuetral.
2SS/RS, Victory Red, Black Leather, LS3, 6spd, Polished wheels - R6P -
Timberline is offline   Reply With Quote
Old 08-30-2009, 03:47 PM   #5
Dan3
Captain of the Failboat
Dan3's Avatar
Drives: 2010 IBM Camaro 2SS/RS
On level ground w/e, but on an incline put it in gear. The E-brake alone will not hold this car. I have always parked in neutral with the ebrake on in previous cars, but yesterday broke me of that.
My driveway has a moderate incline and yesterday my ebrake let go. The car had been parked for around 5min, and I had gone in and got a screwdriver to put my new license plate holder on. As I was taking off the plastic I heard a pop and the Camaro rolled right back into me. Luckily I was outside and standing right behind the car to stop it, otherwise my car would have been sitting in the middle of the road.
2010 Camaro 2SS - Imperial Blue w/Black Leather Interior
Ordered - 22 June 2009
Produced - 10 August 2009 : #34143
Delivered - 25 August 2009
Dan3 is offline   Reply With Quote
Old 08-30-2009, 05:37 PM   #6
Bbrock25
Bbrock25's Avatar
Alright thanks guys.
Old 09-03-2009, 11:53 PM   #7
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
Interesting stuff. For the manuals I've owned in the past, I've never parked in gear and just relied on my emergency brake. After reading this thread plus the manual, I'm definitely going to rethink things (even though it's flat here in Houston!).
The manual says for manual transmissions, "shift lever into reverse and then apply the parking brake. With the clutch still pressed in, then turn off the engine."
Order date: 7/17/09
3000 TPW: 8/17/09
3400 status on 8/11/09
3800: 8/21/09
4200: 8/24/09 on rail car ETTX850796
5000/6000: 9/2/09
crzycicada is offline   Reply With Quote
Old 09-06-2009, 02:04 PM   #8
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
this is just a habit but i put it in 1st and set the e-brake. untill 2 months a go when i broke my drive shaft and took out my ebrake. now i just leave it in 1st.
2000 Z28 = Beast
forged 383 ls6, to many mods to list
Dyno= 453hp 430tq at the wheels
best time= 12.6@110 in the July heat at 6000ft alt
DA Corrected = 11.396@121.765
75 shot Giggle Gas = 12.2@118
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 09-09-2009, 05:40 AM   #9
HDDAN
HDDAN's Avatar
Drives: 2010 Camaro 1SS 2007 HD FLSTC
I live in Boston and I use the E-brake all year long when parking and it does not freeze up or stick even in our harsh, snowy, sub zero winters. The reason for using the E-brake is that on a hill you can get a condition called "torque lock" with the automatic where the transmission will not be able to be shifted out of park. If this happens, you must have a couple of people push the car slightly up the hill to unload the transmission. It is kind of like what happens to your steering wheel when you force it to lock with the key removed and you must turn it slightly to unlock it. The right way to park an automatic, is to hold the car with the brake, set the E-brake, then put the car into park. When driving off, start the car, step on the brake, put the car into gear, then release the E-brake. This info is in the owners manual.
HDDAN is offline   Reply With Quote
Old 09-22-2009, 10:33 PM   #10
beowulf80
beowulf80's Avatar
Drives: 2010 2SS / RS MT, IBM
I use both a gear and the parking brake. Personally I use 4th gear. My logic: If its hard to turn the wheels in 1st, it'll be even harder in 4th. Additionally if you forget either you're still got the other going for you.
Also, its called a parking brake instead of an e-brake for a reason. =] And there is truth that you do have to make sure that the lever is all the way up, anything less will not hold you on an incline.
Just something fun to consider: Why do people call it an emergency brake? What emergency was ever resolved by locking up your rear tires? Or is it called this because a crazy g/f suddenly yanking on it at 60 MPH will send you to the emergency room? I'd personally call it a Fun-In-Snow-Brake. Or maybe I-Want-To-Spin-Out-brake
beowulf80 is offline   Reply With Quote
Old 09-26-2009, 10:36 AM   #11
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
I always leave in in R and put the parking brake on. That way the habit is there so you don't drain your battery by leaving it other gears when you take a break from driving your car.
I always use the parking brake with cars in gear for all manual transmissions. Like described above, it could pop out of gear, your kid hits the shifter crawling around, etc. and the bad boy starts rolling away.
Current Camaros: 1968 convertible, original 327, Iron Eagle heads, DT headers, Magnaflows, Muncie 4-speed, 3.08 posi, 17" Torque Thrusts,
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust Delivered 5/14/11
ckaram is offline   Reply With Quote
Old 09-27-2009, 12:53 AM   #12
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Don't leave it in 4th, always use 1st or reverse. If you use 4th, it can roll easier, not harder. 4th is 1:1 ratio, meaning one rev driveline= one revolution of the engine. 1st gear is 3.01:1 ratio, meaning one rev driveline= 3 revolutions engine. Reverse is the best at 3.28:1 ratio. Get it.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 09-27-2009, 07:21 AM   #13
mnywstr
Drives: 2010 Rally Yellow 2SS/RS
+1
An old friend that is a mechanic told me that most times that people have problems with the ebrake freezing up or seizing is that it isn't used enough. The cable has a lubricant in it that is moved around when used. I use my brake all the time and always put it in gear when parking no matter an incline or a level surface. Just a good habit and it ensures the car isn't moving. After having a car rolled away on me that first time I make sure to use both 1st gear and the brake.
mnywstr is offline   Reply With Quote
Old 09-27-2009, 08:54 PM   #14
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Some vehicles I have had in the past. (Not the Camaro). When it is slushy in the day time and set the ebrake. Then gets down to 10 degrees or lower. The brake has frozen up. Would probably not use it in this situation.
Icefsh is offline   Reply With Quote
Old 09-28-2009, 11:58 AM   #15
metaphysician
metaphysician's Avatar
Drives: 2SSRS CGM & Harley Crossbones
I always park in 1st w/ e-brake. Insurance for my insurance. I got used to using the e-brake for parking on my car w/ rear drum brakes. Using the e-brake allows the tension springs on the drum to adjust themselves to maximum efficiency. This allows the e-brake to actually work when you need it for it's actual purpose!
metaphysician is offline   Reply With Quote
Parking in single car garage, any issues? 2bravo 5th Gen Camaro SS LS LT General Discussions 43 08-25-2009 10:50 AM
Is it better to park far away or closer to the building in a parking lot? Ant 5th Gen Camaro SS LS LT General Discussions 64 08-17-2009 01:00 PM
Parking lights ? Becustom Cosmetics and Lighting Modification Discussions 1 08-16-2009 11:12 AM
Thought about rear parking sensors? Scotsman 5th Gen Camaro SS LS LT General Discussions 30 08-31-2008 12:44 AM
Parking scandal... The_Stache General Automotive + Other Cars Discussion 3 06-24-2008 10:11 PM
