Gen5DIY
Old 08-30-2009, 03:15 PM   #1
1fine79
Drives: 2010 2SS/RS Victory Red
Nitrogen in tires
I was reading an article in the Sept 09 Family Handyman magazine and ran across an article about "Making your tires last". In the article it made reference to tires that have green caps on the valve stems indicate that the tire is filled with nitrogen. Based on the article they do not recommend that you fill the tire with compressed air because it will negate the advantages of the nitrogen. Does anyone know if this will also cause damage to the tires. My 2SS has green caps on the valve stems so I am making an assumption that the tires are filled with nitrogen. Going to dealer tomorrow to check on this and find out what do I do when I get a low tire warning. More to come. Any thoughts from experts out there?
1fine79 is offline   Reply With Quote
Old 08-30-2009, 03:27 PM   #2
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
I have mine filled with 78% nitrogen. Very easy to find/refill.
patriotpa is offline   Reply With Quote
Old 08-30-2009, 03:49 PM   #3
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
It will not damage the tires. Adding "air" just diminishes the value of having nitrogen in there.
CamaroScotty is offline   Reply With Quote
Old 08-30-2009, 03:52 PM   #4
rodimus prime
Drives: Cargo van.
Waste of time. If you have it fine, but its not worth going out of your way to find.
rodimus prime is offline   Reply With Quote
Old 08-30-2009, 04:00 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 1LE...Drove: 2012 ZL1
You know...nitrogen doesn't leak out of the tires as quick as "air" does...so if you just keep refilling them, eventually, they'll be filled with 99.9% nitrogen, and won't deflate for a while...like mine.
Mr. Wyndham is online now   Reply With Quote
Old 08-30-2009, 04:23 PM   #6
FI4T0MCAT
FI4T0MCAT's Avatar
Drives: 1969 SS Camaro
That is awesome
FI4T0MCAT is offline   Reply With Quote
Old 08-30-2009, 05:00 PM   #7
ShnOmac
ShnOmac's Avatar
Yep green caps means nitrogen...
ShnOmac is offline   Reply With Quote
Old 08-31-2009, 04:10 AM   #8
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
lmao
another advantage of using nitrogen is that you wont get water in side your tires, if you happen to use so old compressor that never gets drained of have a drier
Gentry78 is offline   Reply With Quote
Old 08-31-2009, 08:11 AM   #9
5th Gen SS
5th Gen SS's Avatar
Drives: 2010 2SS/RS M6 IOM and Black/IOM
The biggest advantage about Nitrogen in your tires is the fact that Nitrogen is not affected by temperature.
5th Gen SS is offline   Reply With Quote
Old 08-31-2009, 08:50 AM   #10
Ranger 75
Ranger 75's Avatar
Drives: 2010 Camaro 2SS IBM
So can you put Nitrogen in any tires or do you have to have special components in the tire and wheel?
Ranger 75 is offline   Reply With Quote
Old 08-31-2009, 12:45 PM   #11
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Huh? 78% Funny...Most wont get it.
Nitrogen fill at less than 95% is a waste..
Nitrogen molecules hold no moisture, less prone to temp changes and molecule is larger leading to less tire pressure fluctuation.
Beneficial? Never tried it..I prefer my 78% blend..much easier to access than time wasted waiting for a refill.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-31-2009, 04:41 PM   #12
patriotpa
Nitrogen is a liquid below −195.9 °C
Nitrogen freezes solid below −209.9 °C
Liquid nitrogen boils at −195.8 °C
I'd say those cover "affected by temperature"
Old 08-31-2009, 04:53 PM   #13
FI4T0MCAT
FI4T0MCAT's Avatar
he is talking about temperatures that occur in nature, in which the car would be operating.
Old 08-31-2009, 04:56 PM   #14
Banshee
Banshee's Avatar
To the two posts above...If you look at the temperature differential, it is true that temperature differential does not affect nitrogen. Just depends on how statement is worded and application.
I am not a chemestry major, but the difference between the three elemental states (liquid/gas/solid) is key here.
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
All season tires on RS??? iyam_lorne Wheels and Tires Talk Sponsored by The Tire Rack 6 10-07-2010 09:25 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Help with selling a car: tires Teddydog General Automotive + Other Cars Discussion 2 08-03-2009 01:28 AM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 05:27 PM
