| 4th Generation Camaros 1993-2002 |
Thread Tools |
Camaro Freak
Engine Swap ;) info requested
Hey ppl
am new here am a 1996 V6 camaro driver n i wanna swap the V6 to LS1 so does the LS1 fit in the 3.8 V6 body?? and how much does it cost? and wt parts need to b changed? thx alot ![]()
The bad guy
This will probably be better answered in the 4th gen section. I don't own a 4th gen so I can't help you. Sorry.
![]() "And the funny thing, your chick is huger than Pun, Fcuk a dimepiece, that chick's a mutual fund..." Owner of the REAL post 20,000 in the PWA II thread... |
Inform the men.
Drives: 78LT,94Z,86,08Silverado,98F150 Join Date: Sep 2006
first off, you need the motor. if you can get it with the wiring and pcm it will be better cus the v-6 pcm will not work and the wiring harness will have to be spliced in some places. the price can vary depending on how much you can get the motor for. also if you can get a transmission with the motor it would benefit you also. as for swapping it out, it will fit in the engine bay tho you will need new motor mounts, also its a good idea to swap your front suspension as the v6's had a weaker setup than the v-8s.
as for dropping the motor http://www.michiganspeed.com/enginepull/index.html then you can swap the suspension and motor/trans all at the same time. ill do some more research, ive got some more sites with info on the swap. ill get back to you.
Camaro Freak
thx guyz and ya the suspension need to be changed coz of the heavier weight also but can u get me a range of the price.... i thought of getting half cut camaro from the junk yard n replace parts....n also i think the fuel pump n the rear axel should b replaced am not sure......is it a gd idea anyways?? i love the model n body i have thats why i wanna swap engine rather than getting a new one plus my interior is all changed soo is it a gd idea?? thx alot
| Thread Tools | |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine Discussions | 74 | 06-05-2008 07:29 PM |
| Engine swap is under way | KILLER74Z28 | 1st & 2nd Generation Camaros | 30 | 04-06-2008 03:03 AM |
| Mobile magazine claims more engine info... | MerF | 5th Gen Camaro SS LS LT General Discussions | 5 | 09-06-2007 01:06 PM |
| Axial Vector Engine | Dragoneye | General Automotive + Other Cars Discussion | 6 | 06-20-2007 06:00 PM |
| Engine Swap Shops in Maryland area | Guy withda bowtie | General Automotive + Other Cars Discussion | 5 | 06-14-2007 06:47 PM |
