Old 09-07-2010, 08:42 PM   #4229
600hp-lpe
Drives: 2010
Originally Posted by paul2010 View Post
All of my bushings are stock in the rear.
Yeah? firm up them bushings! It's bound to help if those bushings are stiffer.. Less flex means more power transfer.
The diff is probably moving (flexing on the stock ruber mounts), but it can't go far.
Have you upgraded any of the suspension arms yet?
Spohn has some great parts for the rear arms of the Camaro.
600hp-lpe is offline   Reply With Quote
Old 09-07-2010, 08:45 PM   #4230
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
Originally Posted by 600hp-lpe View Post
We're not hard on equipment... are we?
I think it's more like keeping vendor's honest...
testing parts durability.
I will have to remember get the HD ones whenever my stock ones go bad. I think I have over 14k miles on mine so far. Maybe I'm not as hard on my car as you guys are on yours.
I think you are harder on yours at the drag strip but we are putting them through the ringer on the autocross / road course. I test it hard on the track to make sure it holds up on the street
Anymore snap might put me in the hospital. Could snap my neck if I wasn't paying attention.
Funny thing is.....I believe it.
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline   Reply With Quote
Old 09-07-2010, 08:46 PM   #4231
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
The only thing I have is Pedders Coilovers, Hotchkis Sway Bars, Hotchkis Chassis Brace and Pedders Radius Arm Bushings.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 09-07-2010, 08:51 PM   #4232
paul2010
paul2010's Avatar
I am up to a top speed of 140.73 in the 1/4. Now I just need Graham and crew to get me car into the 9s!
2012 ZL1 #1278
Old 09-07-2010, 08:54 PM   #4233
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
I'm just messing with ya Pete. Send me some things over I need to gain a few tenths!
Talk to Graham or Bruce about a Supercar coilover upgrade or 600hp-lpe that I used to know before he confused me with hi avatar change . My guess is you would find close to 2/10ths with them and EP1167HDs.
Old 09-07-2010, 08:59 PM   #4234
paul2010
paul2010's Avatar
I am hovering around the 10.3s I have a 10.309, 10.339, 10.348, 10.302.... Of course several of those were spinning the first 20 feet.
2012 ZL1 #1278
Old 09-07-2010, 09:02 PM   #4235
JusticePete
Slicks and Supercars to make your Camaro a LPE SSSS Try saying that fast three times --
LPE SSSS
LPE SSSS
LPE SSSS
Old 09-07-2010, 09:08 PM   #4236
600hp-lpe
Drives: 2010
must be the difference between the hard hit of the standard trans compared to the soft hit of the auto trans and the difference in the tranny's gear ratio's.
I had a lot of wheelhop when burning rubber in 1st gear until I got the HD bushings installed on the diff carrier. Stock or the soft poly bushings didn't cut it. With the HD bushings, you can't baby the car when burning rubber or it still will wheelhop a little.
If I launch in 2nd gear, there is enough wheel spin to overpower the grip that would grab and create wheel hop. It did not matter in second gear which bushings are installed (stock, wimpy, hd
) as the tires are doing 60 mph and the car is moving less than 10 mph.
I am assuming you are getting past the "grip" point quicker with the auto than we do with the standard trans. That's probably the difference and why you aren't seeing the same traction issue in 1st gear that we see.
Old 09-07-2010, 09:16 PM   #4237
paul2010
paul2010's Avatar
I have an RPM Built Transmission and a Coan 3200 stall speed tq converter. It's not really a very soft hit at the line when it takes off. I do have trouble hooking up but no wheel hop. I definately need some slicks and I think some softer springs from Pete and I bet I could hook up pretty good.
2012 ZL1 #1278
Old 09-07-2010, 09:23 PM   #4238
600hp-lpe
Drives: 2010
yeah... the supercar shocks are a noticeable improvement over the xa's. I can see how these would pick up time on the drag strip..The separate (bound/rebound) adjustments make a world of difference on how the shocks/car will react to get you out of the hole.
I know they will improve my autocross track times.. I am anxious to try them out. My next event is on the 26th.
Hey pete... I'll swap back to my red devil avatar tomorrow so you know it's me.. it's on my other computer in my office. Just for you Buddy..
Old 09-07-2010, 09:26 PM   #4239
600hp-lpe
Drives: 2010
LPE SSSS
LPE SSSS
LPE SSSS
Wife said to hold my tounge and say it..
LPE SSSS
LPE SSSS
LPE SSSS
nope... can't say it 3 times fast but can type it faster.. (cut/paste is my friend)
Old 09-08-2010, 11:01 AM   #4240
JusticePete
I know YOU!
Old 09-08-2010, 11:01 AM   #4241
JusticePete
Old 09-08-2010, 11:03 AM   #4242
JusticePete
Dan,
Aside from the performance gains with Supercar coilovers, can you comment on the ride quality compared to OE and compared to the Xas?
Lingenfelter 2010 Camaro Engine Packages Including New Vehicle Now Available Tim@Lingenfelter Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 06-18-2010 07:11 AM
Lingenfelter 2010 Camaro Engine Packages - up to 800hp! Sizzox 5th Gen Camaro SS LS LT General Discussions 108 04-14-2010 07:09 PM
My Lingenfelter Camaro Build Speed74SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 244 10-08-2009 10:00 PM
Lingenfelter Supercharged Camaro makes 600 RWHP!! Kevin@Lingenfelter Forced Induction - V8 218 06-24-2009 02:26 PM
Three 2010 Camaros Arrive at Lingenfelter Performance Engineering Sizzox 5th Gen Camaro SS LS LT General Discussions 25 04-26-2009 01:15 PM
