Old 08-31-2009, 08:05 AM   #1
jmcbeth
THR 2SS/RS Supercharged
Drives: 1st and 5th Gen Camaros
Asymmetric Lift Points for 2010 Camaro
Can someone post a picture of a new Camaro on a lift? I am particularly interested in where to place the lift arms. I was too nervous to try the points I thought were correct and am worried that the lift arms aren't long enough to reach the obvious points.
Thanks in advance.
jmcbeth is offline   Reply With Quote
Old 09-06-2009, 03:59 PM   #2
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
i use the engine cradle mounts in the front and the rear suspension mounts in the rear if you look under the car the mounts are black with a bolt going up through them were you would want to jack it by
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 07-30-2011, 06:38 AM   #3
Augie1978
Augie1978's Avatar
Drives: 2011 2SS RS Vert
Anybody have a picture of this?
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
Augie1978 is offline   Reply With Quote
Old 07-30-2011, 07:14 AM   #4
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Tale a look at this - http://www.camaro5.com/forums/showpost.php?p=2630531
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 35 12-20-2016 09:49 AM
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 369 10-18-2016 04:56 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 05:36 PM
