Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 08-31-2009, 10:07 PM   #1
jrpxxii's Avatar
Whats Up w/gears???
Why in the world is it so difficult to find anyone to make us rearend gears for our cars? Is it really that in depth compared to all the other parts coming out? Im dying for a set of 3.90. Please hurry up already.
Old 08-31-2009, 10:27 PM   #2
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
Old 08-31-2009, 10:43 PM   #3
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
There has been posts there is something unique to the camaro and it's not as of yet a simple ring/pinion style swap. Apparently they are having alot of trouble figuring it out.
jpsuperman81 is offline   Reply With Quote
Old 09-01-2009, 07:25 AM   #4
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
hope its figured out by the time i get mine...would love to put a 4.11 or 4.56 in it. Being that i only plan to drive it 3 or 4 days a week, i dont mind having the steeper gear.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 09-01-2009, 09:29 AM   #5
Jason@RPM-Motorsports's Avatar
Drives: 98 WS6
Guys I have been talking with some people that are working on 4.10's for your 5th Gen's ..Its going to probally be around January before you see anything !
Jason@RPM-Motorsports is offline   Reply With Quote
