PFYC
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 05-06-2008, 05:06 PM   #1
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
GM moves closer to HCCI engine production
Imagine getting V6 fuel economy from your V8 Camaro. It could happen sooner than later with HCCI engine technology
Previously we reported on a new technology dubbed homogeneous charge compression ignition, or HCCI, which allows petrol cars to improve fuel efficiency by as much as 15% by achieving combustion with only compression of the air-fuel mix rather than using a spark plug. The technology was pioneered almost 30 years ago but has only recently been subject to a great deal of interest from the auto industry, most notably from Mercedes-Benz and GM.
GM’s commitment to HCCI technology is especially strong, with the General implementing the technology into prototypes, including the Saturn Aura (pictured). In a new breakthrough, GM has announced it has engineered the technology to operate while a car is idling (previously it could only operate while a car was in motion), increasing fuel savings even further.
The HCCI system can now be used while idling and up to speeds of 55mph, but at speeds greater than this or when more vigorous acceleration is required, a traditional spark-plug system will be used. This means that HCCI equipped cars will have both technologies under the hood.
If combined with other fuel-saving technologies such as low-resistance tires and hybrid systems, the savings from HCCI could add up to be very significant.
While GM has been eager to develop the technology, other companies have adopted a ‘wait and see’ attitude towards HCCI, including BMW who is researching alternative methods to reduce the dependence on oil such as its hydrogen program.
How HCCI works
HCCI, along with other enabling advanced technologies, approaches the engine efficiency benefit of a diesel, but without the need for expensive lean NOx after-treatment systems. Its efficiency comes from reduced pumping losses, burning fuel faster at lower temperatures and reducing the heat energy lost during the combustion process. Consequently, less carbon dioxide is released because the vehicle’s operation in HCCI mode is more efficient.
Highlights of the technology include:
- Engine efficiency approaching the benefit of a diesel with substantially reduced after-treatment cost
- Builds off proven gasoline direct-injection and variable valve actuation technologies
- Adaptable to conventional gasoline engine architectures
- Requires only conventional automotive exhaust after-treatment
- Compatible with all commercially available gasoline and E85 ethanol fuels.
An HCCI engine ignites a mixture of fuel and air by compressing it in the cylinder. Unlike a spark ignition gas engine or diesel engine, HCCI produces a low-temperature, flameless release of energy throughout the entire combustion chamber. All of the fuel in the chamber is burned simultaneously. This produces power similar to today’s conventional gas engines, but uses less fuel to do it.
Heat is a necessary enabler for the HCCI process, so a traditional spark ignition is used when the engine is started cold to generate heat within the cylinders and quickly heat up the exhaust catalyst and enable HCCI operation. During HCCI mode, the mixture’s dilution is comparatively lean, meaning there is a larger percentage of air in the mixture. This reduces the throttle losses of a conventional spark-ignited engine at low loads, helping the HCCI engine approach the efficiency of a diesel, but requiring only a conventional automotive exhaust after-treatment. Diesel engines require more elaborate and more expensive after-treatment to reduce emissions.
HCCI builds on the integration of other advanced engine technologies - some of which are already in production and can be adapted to existing gas engines. The cylinder compression ratio is similar to a conventional direct-injected gas engine and is compatible with all commercially available gasoline and E85 fuels.
“I am pleased with our engineering team’s progress,” said Stephens. “It is another initiative in GM’s advanced propulsion technology strategy to lessen our dependence on oil. HCCI, direct injection, variable valve timing and lift, and Active Fuel Management all help improve the fuel economy and performance of our internal combustion engines. I am confident that HCCI will have a place within our portfolio of future fuel-saving technologies.”
Achieving HCCI operation at idle has long been a challenge for HCCI engineers, because the relatively low-temperature and light engine load characteristics generally inhibit the proper thermodynamic conditions for successful, controllable autoignition. Also, heat is needed at start-up and idle to light-off the catalytic converter.
GM’s engineers overcame these challenges with advanced control of the direct injection system and a HCCI-specific cylinder pressure sensor system. After spark ignition is used to start the engine, the engine’s sophisticated control system manipulates the combustion process via input from the cylinder pressure sensors so that auto-ignition can occur during idle.
“Fuel consumption with a spark ignition engine is relatively high when idling, so this new development in our HCCI process helps to enhance fuel efficiency,” said Dr. Matthias Alt, HCCI program manager, GM Powertrain.
The emerging HCCI technology offers several paths for implementation in a production vehicle. GM’s strategy combines the efficiency enhancements of HCCI and the power-on-demand attributes of spark ignition. This combination delivers enhanced fuel savings over a comparable, non-HCCI engine, but with the performance consumers have come to expect during higher engine load situations, such as passing or entering a freeway.
“GM’s HCCI development focuses the technology where it will deliver the most benefit at the most reasonable cost for the consumer,” said Alt. “An HCCI engine that uses HCCI in the entire operating mode would be heavier, noisier, more costly and would not deliver the performance experience people expect from a modern car.”
With GM’s technology, proven gasoline engine technology is retained and the engine has spark plugs and a conventional ignition system. The vehicle operates in HCCI mode up to about 55 mph (88 km/h) and switches to spark-ignition for higher-speed, higher-load conditions. It also engages spark ignition mode for passing at lower speeds and other higher-load demands.
The Aura concept is powered by a 2.2-liter Ecotec engine that makes 180 horsepower (134 kW) and 170 lb.-ft of torque (230 Nm). It features a central direct-injection system, with variable valve lift on both the intake and exhaust sides, dual electric camshaft phasers and individual cylinder pressure transducers to control the combustion as well as deliver a smooth transition between combustion modes.
A sophisticated controller, using cylinder pressure sensors and GM-developed control algorithms, manages the HCCI combustion process, as well as the transition between HCCI combustion and conventional spark-ignition combustion.
Challenges for production
The biggest challenge of HCCI is controlling the combustion process. With spark ignition, the timing of the combustion can be easily adjusted by the powertrain control module, with control of the spark event. That is not possible with HCCI’s flameless combustion.
The mixture composition and temperature must be changed in a complex and timely manner to achieve comparable performance of spark-ignition engines in the wide range of operating conditions. That includes extreme temperatures - both hot and cold - as well as the thin-air effect of high-altitude driving.
Advancements such as idle operation and improved noise, vibration and harshness bring HCCI technology one step closer to production. GM’s global HCCI team will continue to refine the technology in the wide range of driving conditions experienced around the globe.
“Our development costs for HCCI are very expensive; however, we have made tremendous strides in bringing this much awaited combustion technology out of the lab and onto the test track with the Saturn Aura concept vehicle,” said Prof. Dr. Uwe Grebe, executive director for GM Powertrain Advanced Engineering. “More research and testing are required to ensure the technology is ready for the great variety of driving conditions that customers experience.”
http://www.motorauthority.com/news/t...ci-technology/
"Let the rest of the world dream of Ferraris, Lamborghinis and dinky little British two-seaters. In this country speed doesn't look like that." Got SS?
Scotsman is offline   Reply With Quote
Old 05-06-2008, 05:18 PM   #2
ToneyTone
ToneyTone's Avatar
Drives: 07' Sunburst Cobalt SS/SC
Hmmm Interesting
ToneyTone is offline   Reply With Quote
Old 05-06-2008, 05:38 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
+2; very interesting. You know the bug-eaters are having their way when a gas engine runs like a diesel. J/K
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 05-06-2008, 11:16 PM   #4
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I wonder how much gas would this system save?
Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP
No. Let me repeat that. No. FbodFather
Camaro5 Fest III Information
Camaro5 Fest III pre-registration
Old 05-06-2008, 11:20 PM   #5
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Sounds like diesel technology. Heat up the cylinder and then use compression to combust the fuel. It's a diesel engine that uses gasoline, right?
"J, you're my favorite Pokemod" ~Revo1
Old 05-06-2008, 11:34 PM   #6
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I think the 305 in my 3rd Gen had this technology. Every time I let someone else drive it, when I got it back it would run after I shut the engine off. That was working at idle for about a minute anyway... if I kept giving it gas I bet it would have done it longer.
Sterling is offline   Reply With Quote
Old 05-06-2008, 11:36 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
"or HCCI, which allows petrol cars to improve fuel efficiency by as much as 15%"
The current, non-HCCI, 2.2 in the Cobalt XFE gets 25city/36hwy...so 15 percent increase: 28/40? Plus the DI and the VVT they've included in the Aura's test engine,...I'd say we're looking at an easy 45mpg four-banger.
Eat that, Prius!!!
"Keep the faith." - - Read Before You Post.
Old 05-07-2008, 12:15 AM   #8
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
[I]
Eat that, Prius!!!
Amen to that!
Old 05-07-2008, 09:54 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
LOL; dieseling for the win!!! See, and no one like the LB9s (is that right?...) and L98s back in the day.
Old 05-07-2008, 10:27 AM   #10
The_Blur
Moderator, USN
The_Blur's Avatar
Drives: 2000 Firebird Formula NHRA SE
I'd love to see this happen. It's technology like this that makes me think GM will overcome new regulations on efficiency. Plus, more efficiency is always good.
newborn gifts
Old 05-07-2008, 12:53 PM   #11
GothamCamaro
Then you're gonna love me
GothamCamaro's Avatar
Drives: 2010 Black Camaro Tumbler RS
Interesting, well that puts it back in my mind when it was mentioned early on that the Camaro could have 30 MPG, this sorta development now makes me think maybe it wasn't the 4 cyc that was only suppose to do that kinda mileage. Hmmmm..
Wow if this is in the new Camaro. I'm just losing my mind, is it April 2009 yet?!?!?!?!
Own- "Does it come in Black?" Exterior/ Grey Interior 2LT/RS Automatic
_____________________________________
The Batman would only drive a 2010 Camaro and buy from Camaro Scotty. 'Nuff said.
Anyone that knows of a place that is making the Concept Shifter for the new Camaro. (Auto specifically) Please let me know.
Order# NDTMVP Ordered 10/23/08.
2000 on 5/21/09... It begins.....
4B00 on 6/26/09... In transit to the Cave
5000 on 7/6/09 it waits for my arrival!
1000000 on 7/10/09 The Tumbler is in the Cave!
GothamCamaro is offline   Reply With Quote
Old 05-07-2008, 01:47 PM   #12
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
Hmm.
There's something I still haven't been able to fathom yet. My '91 vert I had (305 TPI) got 21+ MPG on the highway, and this was 17 years ago in a CONVERTIBLE. My 400+ HP Supra got 25 MPG hwy, and it was a '94. early 90's HOndas could easily get 40 MPG on the highway...so why are these numbers so hard to believe now? I know cars are heavier now (duh, make them lighter and save gas folks!) but there's got to be something else wrong with the picture here that it's so difficult to fathom a V8 making over 25 MPG.
MerF is offline   Reply With Quote
Old 05-07-2008, 01:49 PM   #13
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
It mentions the added benefit of not using expensive diesel emissions systems. It also so should mention the benefit of diesel efficiency without diesel prices.
I'd pay a little extra to get this system in my Camaro.
stovt001 is offline   Reply With Quote
Old 05-13-2008, 11:49 AM   #14
Good53X
Drives: 1988Nissan Pulsar (meh,beater)
Actually, the large arguement for HCCI is the improvement in emissions.
Normally combusted gasoline burns, producing HEAT andthus NOx emissions. HCCI doesn't burn the charge, but actually harnesses the compression energy to combust the entire charge simultaneously. Because it doesn't technically *burn* (like in a diesel) there is actually very little heat produced.
They already have these engines running, but only for certain drive cycles. They are working on a way to get them to run under more conditions.
Essentially, using computer controlled forced induction and constantly monitoring cylinder temperature, intake charge temperature, and barometric pressure they can calculate how much intake duration (valve control) they need to get the engine to 'knock' at the right time.
Differenced between this and diesel... Much lighter block, less torque (no sustained burn). Ignition timing isn't adjustable by adjusting fuel, it's all computer controlled.
I don't know if that made any sense, but when I learned about this technology in class I geeked out. I'd be more excited in looking at what kind of POWER you can get out of your V8 than what kind of fuel economy you can get. HCCI engines produce vastly more power than standard combustion because of the energy that isn't lost as heat. However the engine sounds a little different :S
Good53X is offline   Reply With Quote
Old 05-16-2008, 10:28 AM   #15
3whiterag
GM Powertrain Retired
3whiterag's Avatar
Drives: 67SS350, 87 IROC L98, 96SS ver
That is very intersting stuff! IMO hybrid technology is not the way to go. Emissons are lower but the impact on the environment in the long term is much more damaging with all the used up battery cells laying around. I think they are only good for 5 years use? and very expensive to replace. I would like to see hydrogen powered vehicles but I am not sure about the consequences of that either.
I was reading Cottage Life magazine the other day and there was a letter to the editor from a guy that drives a prius and he was extolling the virtues of it. Very ill informed and an unknown victim of mass advertising!
http://i17.photobucket.com/albums/b7...g/100_1224.jpg
http://i17.photobucket.com/albums/b7...g/100_1227.jpg
http://i17.photobucket.com/albums/b7...g/100_1230.jpg
I say nothing and by saying nothing or not, not saying anything does not imply that what you say is true or not true.
3whiterag is offline   Reply With Quote
Old 05-16-2008, 12:02 PM   #16
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
Dude.....I'll take 15% better fuel efficiency any day. Add that to VVT and AFM and we've got a winner!!!!!!!!!!!!
The build of THRSS #2
Old 05-16-2008, 06:16 PM   #17
shadowed_Stranger
WAITING!
Drives: 97 V6 5spd
Hey, if Al Gore invented the internet, why would he lie to us about the prius and global warming?
shadowed_Stranger is offline   Reply With Quote
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
Another tidbit about production date and engine lineup...LOOK HERE! CamaroSpike23 5th Gen Camaro SS LS LT General Discussions 154 02-03-2008 03:38 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
