Gen5DIY
Old 09-01-2009, 05:58 PM   #1
tbyrne
tbyrne's Avatar
Drives: 1993+1998 Z-28s - past cars
Diablosport Predator and Trinity Programmers Available!
Diablosport has recently released their tuning for the 2010 Camaro SS!
The Predator is by far the most popular handheld programmer that we carry.
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Average power gains are per tune. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline. Customers have reported a 15-20hp increase with this programmer!
U7194 Specific Features:
� COT time delay
� DoD disable (truck/SUV only)
� Idle RPM Drive/Neutral
� Injector Slope adjustment
� WOT Fuel 2k-3.8k / 4k-7k
� Rev Limit
� WOT Spark 1k-1.8k / 2k-3.8k / 4k-7k
� Fan adjustment, individual adjustment per temp dependent cell
� Tire Size
� Speed limit(truck/SUV only)
� Read/Write time is approx 60 seconds
� Clear codes supported
� Live data and log supported
� Initial release will only support ONE custom tune Dat viewer is supported.
� All standard DiabloSport Predator features
The Trinity programmer is also available. You'll see the same horsepower increase as the Predator but it has many more features -
tbyrne is offline   Reply With Quote
Old 09-22-2009, 10:44 PM   #2
Merc
In The Circle
Merc's Avatar
Is this something that almost anyboby can use. I have aready put a CAI and MSD 8.5 wires on my Maro 2SS stick and planning to put on LT headers, cat back exhaust and 160 thermostat. By then it will need a tune. My goal is 12 something.
Old 09-23-2009, 07:27 AM   #3
tbyrne
tbyrne's Avatar
Yes, it is very easy to use. It pretty much walks you through what you need to do and also comes with a detailed manual. You can view that online too - Trinity Users Manual
Old 09-23-2009, 07:51 AM   #4
Merc
In The Circle
Merc's Avatar
Put it on my list. Is the manual for the Predator available for download.
Old 09-23-2009, 08:43 AM   #5
tbyrne
tbyrne's Avatar
For some reason they list the U7191 manual for the U7194. Same procedure, different vehicles - http://www.diablosport.com/downloads...nual_U7191.pdf
Old 09-30-2009, 08:06 AM   #6
domano 68
domano 68's Avatar
Drives: 2014 1LE
To understand what this does, plug the hanheld in to your car and it tunes the ECM by optimizing various parameters? Or is there a tune file on the handheld that downloads to your ECM? Never tuned before so I appologize for novice questions.
domano 68 is offline   Reply With Quote
Old 09-30-2009, 11:51 AM   #7
tbyrne
tbyrne's Avatar
You plug the programmer into the port under your dash on the driver's side. That provides it with power. The programmer then reads the vehicle's vin number and saves the stock program before uploading the performance tune from the handheld to the vehicle's computer.
Old 10-10-2009, 06:35 PM   #8
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
Anyone have hard numbers about hp and torque gains?
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 10-10-2009, 07:02 PM   #9
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
Dont know if anyone has the hard numbers just know what Diablo is claiming. 15hp/tq for the L99 and 20hp/tq for the LS3's. That is their canned tunes. They can always be adjusted when adding other parts to your car to help make more.
Hesh is offline   Reply With Quote
Old 10-15-2009, 06:01 PM   #10
Demo Dude
Drives: 2SS/RS IBM Blk Stripes
Will it clear codes and turn off my engine light? It came on after I installed headers. Also, will it go back to stock if I need warranty work? And once I put my VIN in is it only usable for my car? Does it get updates when new info comes out? Thanks for your help
Hennessy CAI w/heat shield, Stainless Works 2" long tube headers, hi-flow cats, full 3" exhaust with aggressive s-tube mufflers.
Demo Dude is offline   Reply With Quote
Old 10-15-2009, 06:52 PM   #11
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Yes it will clear codes, datalog, etc and you can return the ECU back to stock. It becomes locked to that specific VIN and can not be used on another car unless it is unlocked. Diablo's website will have updates with revisions when available
Meister@Torq is offline   Reply With Quote
Old 10-15-2009, 06:57 PM   #12
Demo Dude
Thanks for the info. How much better is a dyno tune than the Diablo? or is it?
Old 10-15-2009, 06:59 PM   #13
Meister@Torq
It all depends on what is done to the vehicle. A custom dyno tune is always better than a canned tune and custom mail order tunes, calibrated for the specific modifications on your car from a tuner is typically better than the canned tunes from flash programmer manufacturers.
Old 10-15-2009, 07:04 PM   #14
Demo Dude
If I'm not doing a cam or heads just CAI, headers, exhaust will the dyno tune be that much better. Are we talking alot more hp then the Diablo?
