Cold Air Inductions
Old 09-02-2009, 08:44 AM   #1
GamecockFan
Drives: 2G1FK1EJ7A9117103
Did my oil change, what else?
I am right under 3k miles and did my first oil change. After reading some stories on here where people took their cars in for service, I'm trying to avoid that as much as possible, but other than changing the oil and filter, not sure what else I can or should do until say my 10k checkup.
GamecockFan is offline   Reply With Quote
Old 09-02-2009, 11:14 AM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Change rear differential fluid. I plan on changing mine around 1500 miles
BigMatt is offline   Reply With Quote
Old 09-04-2009, 12:48 AM   #3
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Nothing else...Just do routine checks..coolant, tire pressure, oil level..
If you are not racing your Camaro as in prolonged road course, the differential lube will be fine for minimum 100,000 miles. I change mine at 50 or 60k though.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 09-04-2009, 01:41 AM   #4
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
It is all in the owners manual. (leave the diff alone)
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Oil Capacity LS3 Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 77 04-21-2014 10:19 PM
Where are you going for your 1st oil change? Yellow2010 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 26 09-03-2009 11:25 PM
what are dealers charging for a oil change ? camarossrs2150 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 16 06-25-2009 09:10 PM
Oil change MustangKillr 4th Generation Camaros 52 06-09-2009 05:21 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
