Emblempros
Old 12-09-2009, 09:43 PM   #57
runt69421
runt69421's Avatar
Drives: 2010 chevy black camaro 2ss
Send a message via Yahoo to runt69421
I have a 2ss camaro with the rettro lights,non halo, i got the lights, i need help installing them, anyone?
runt69421 is offline   Reply With Quote
Old 12-10-2009, 12:13 PM   #58
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Originally Posted by jimmi-no View Post
I have a 1SS, non RS, can I get a kit to put halos in a camaro that did NOT come
with them originally?
Yes, our kit installs into RS AND non-RS Headlights.
http://www.camaro5.com/forums/showthread.php?t=35663
AACstyle is offline   Reply With Quote
Old 12-10-2009, 12:14 PM   #59
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
Dual Halo Install - tools
Bumper removal
For fun I put my 2 cents in the pictures
Tools: "Click on images below to enlarge"
Tools used to remove Bumper. Only requires 7 tools including the beer opener.
Foglight removal tools - Non-RS
Foglight Halo install tools
itsadryheat79 is offline   Reply With Quote
Old 12-15-2009, 09:47 PM   #60
runt69421
runt69421's Avatar
Originally Posted by AACstyle View Post
My advise would be to return those and get your $2000 back. Order our Halo Kit for $169 (save yourself $1,831) and enjoy a more brilliant ring that does not require a BCM code to operate.
. Be advised ur thing on acc website is not it unless im looking at the right one,my. Email is runt69421@yahoo.com n let me know what i can do,thanks
Old 12-26-2009, 08:35 PM   #61
camarossowner
Drives: 2010 2SS Black Camaro
This thread sure help me to complete my halo upgrade. Here are some pics of the lights. More pics to come when there back into the car. and now I'm adding halo's and hid's to my fog lights. Pic to follow soon.
Originally Posted by klove View Post
OK so this next part was kind of difficult(it feals like your breaking your headlight assembly but i called Oracle and he said it just sucks to do and have at it). From here on in there are pretty detailed instructions from Oracle, you heat up the oven to 230( i heated mine up to 275 after a couple of rounds at 230) and stick a headlight in there, i suppose a heat gun would have worked just as well but i decided to follow instructions. Put it in there for 20 mins and the pop the tabs on the headlight lens and get a screw driver up under the lens with the plastic still soft. This was far easier said then done. It took me a lot of tries at 275, you have to push one side down pretty far to get the screw driver under there. Once the first edge is up it is pretty simple but i still reheated it several times after the first edge was up to aid in the process. After thats done you take out the old halo and install the new LED halo. You epoxy it in the housing, and i snipped the old halo wiring and connected it to the new ones to make it an easy fit back to the power wires. After the new halos are in its time to put your lenses back on your headlight. You use black silicon around the edges of the housing and then put the lens back on and hold it in place with vice grips for a reccommended 3-4 hours. Mine are an hour and a half into the silicon drying time. I hooked the lights up to test them before i sealed the lenses again and it is a pretty sight. I cant wait till they dry and i can see them at night. On to the fog light halos
camarossowner is offline   Reply With Quote
Old 01-14-2010, 07:23 PM   #62
monstertodd
monstertodd's Avatar
bumper removal
Can anyone help me out? I can't find the proper bolts to remove to get the bumper cover off. I removed three bolts around the amber signal light including a painted one. The DIY talks about a star bolt that you remove at this point, but I cannot find it for the life of me. Anyone with FHE know where to look?
*edit
The term "star bolt" was throwing me off. I was looking for a torx fastener. Didn't realize that it was a six sided hex bolt I was supposed to be looking for. Can you update your DIY to reflect this please?
Old 01-14-2010, 11:45 PM   #63
Mecha
AAC Certified Installer
Mecha's Avatar
Drives: 2011 Mini Cooper S Convertible
RS and Non-RS halos are the same.
http://nmcmotorsports.com/store/cata...products_id=31
Same product
Mecha is offline   Reply With Quote
Old 01-17-2010, 08:03 AM   #64
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
Nice write up.
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
Old 01-20-2010, 07:57 PM   #65
Ukd73
Drives: 2010 1ss/rs Ls3
can you put halos in the fog lamps withou removin the bumper?
Ukd73 is offline   Reply With Quote
Old 01-20-2010, 08:31 PM   #66
camarossowner
Yes, I removed the bumper to do mine. Because I wired them to the side marks so if I needed to remove the bumper I didn't have to unhook wiring. Plus, I installed HID's in my fog lights and screwed the ballast to the botttominside of the bumper.
Old 01-21-2010, 12:20 AM   #67
Ivan @ Southwest Speed
So who wants to be a rockstar and do a nice colorfuly write up on how to correctly wire up a RS car so we can manually turn on fogs with hi and low beams with a auxillary switch?
I'm sure alot of people would love this information.
It would be a great sticky for somebody who knows and can illustrate it in something really easy like paint. lmao
Thanks and great looking rig,
Ivan
Old 01-25-2010, 11:20 AM   #68
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
can you do the halo's to a 1ss to turn on with the fog lights? i just want to clikc it to the left once and have all 4 in ambler come on instead of having a remote to do it.
SSTony is offline   Reply With Quote
Old 01-25-2010, 11:27 AM   #69
AACstyle
AACstyle's Avatar
Yes, in that case you just wire these to your parking lights
Just connect red and black to your sidemarkers to enable the parking light halos.
Old 02-07-2010, 02:08 PM   #70
SSTony
SSTony's Avatar
Drives: SS Camaro
do you have to cut the lense off the fog light to put the halo ring in? There is no other way of doing it?
