| Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions |
Thread Tools |
#801 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
#802 |
www.Camaro5store.com
![]() FYI, this pic was taken by me at INDY on a CTF car. This is the GM ABL on the dash they were going to do. It was not 100%....but, this is kinda the idea. |
#803 |
Treasure Coast Camaro 5
Drives: SW 11' 2SS/RS LS3 Vert, Blk/Blk Join Date: Feb 2009
Doug, from that pic, it looks like the GM version had the tube exposed at the top as well as the tube visible from the side.... how did they get the trim pushed back in so far?
I'm planning on cutting a groove into the dash on the D side behind the trim that the tube can recess into, hopefully being able to close the gap a bit. Id already sanded the paint off the top, trying to drop the tube behind, but currently, there's no getting it back there without modifying the trim or closing it without cutting the dash that I can find.
#804 |
Why not try to heat up the tube? Heat it up and bend it? That part was flush with the car when I looked at it. It didn't stick out that I coudl tell. Then again, that was back in 2008. I'd just be careful about cutting the dash. maybe you can trim the back of the trim too?
Sorry about the quality of the pic too....they didn't know I was taking it. HA! |
#805 |
I did a little already, its not just the angle, but the overall depth of the tube pushing the trim piece out. Depending on how brave I get, might end up carving down a little of each, tube, dash and trim. I just hate that huge driver side gap
#806 |
Alright, so some trial and significant error, then, much like my Chiefs finally winning today, a light shone down from above and it clicked!
While trying to heat and bend the tube for the driver side, I snapped the tube! It still works, but you can definitely tell. Luckily, I had the original piece left over, its about 1/4" short, but its better than the other... I WAS heating the tube, bending it, then trying to fit it in the car... then rebending when the angle wasn't right. What worked- using a hair dryer and oven mits- holding the bar in place, using the hair dryer on hot-low, slowly moving the pressure finger the length of the tube, about 20 sec per inch. Let go and the bar conformed so well to the plastic, it actually held in place! The trim snapped back in place and cut my gap in about half! I no longer see the actual tube and the light reflects up through the gap and sanded area! I also used clear plastic tape instead of the plastic tubing to connect the led and light tube together, also cutting down the thickness. Finally, i'm content... ...for now
#807 |
![]() Drives: 2010 Camaro 1LT Join Date: May 2010
TTT
#808 |
![]() ![]() Drives: '10 Black V6 2LT RS Join Date: Jul 2011
Finished mine last week. Kinda dim in the center on the passenger side, but doesn't bother me too much. If anyone knows a simple way to fix that, I'd appreciate it.
#809 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
you may have one of the bad light pipes i got, PM me i have new ones.
#810 |
Mines fairly dim in the center as well, I ended up pushing the center up higher than the ends to equal it out. Looks fine at night, but in late evening hours the ends are rediculously brite, while the center is barely visible.
#811 |
I taped over the ends to dim them. They look fine. And the center is held up as high as it'll go (with weather stripping) without the pipe showing. PMing Ofer now, maybe it's just a bad light pipe like he said.
#812 |
*UPDATE* Definitely a bad light pipe. Ofer was kind enough to send me a new one and it looks perfect now. Very simple install. This is the only pic I have right now but I will post more later.
#813 |
#814 |
Since i changed my door LED's to red, i also had the window switch LED's changed as well. If you want to do this and, like me, dont have the means to solder something so tiny, send a PM to "creektrack". He swapped mine out and had my switches back to me within the week and it was dirt cheap, lol, hopefully he'll continue to ask for so little to have it done. He does ask for you to send him the LED's that you want installed though and you can get those from Oznium (website). The LED's are 0805 surface mount. The website also has the diagram showing its polarity as well.
#815 | |
#816 |
Just did this with my leftover blue door LEDs.
#817 |
Treasurer LoneStarCamaro
Drives: 2011 Synergy Green 2SS/RS Join Date: Oct 2010
cool!
#818 |
![]() Drives: black with white stripe Join Date: Nov 2011
i am looking for the blue tape light for my black camaro 2ss and i have been looking around but dont know where to get them. can anyone help me out and show me where to get some for cheap. i want to put it around the door like this. so where can i find them and how many would i need
i am looking for the blue tape light for my black camaro 2ss and i have been looking around but dont know where to get them. can anyone help me out and show me where to get some for cheap. i want to put it around the door like this. so where can i find them and how many would i need |
#819 | |
#820 |
what do you want ? tape or what GM used in the doors ?
#821 |
which one is better.. i wanted neon blue
#822 |
That is up to you, But if you want neon blue then that is a aftermarket Color the ones that come in most cars is ice blue.
#823 |
#824 |
I do not know what it looks like, so i have no idea, if you can post a pic that may help.
#825 |
something like this
| Thread Tools | |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 79 | 03-04-2013 09:25 AM |
| EXHAUST | Milk 1027 | Wiki | 2 | 03-07-2010 09:20 PM |
| IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 11:37 AM |
| got my new Camaro today pictures included !! | yesno20102ssblack | Camaro Photos | Spyshots | Video | Media Gallery | 33 | 05-02-2009 10:05 AM |
| First Camaro Impressions (Pictures Included) --- Red Jewel Tintcoat! | dect | Camaro Photos | Spyshots | Video | Media Gallery | 80 | 01-27-2009 06:45 PM |
