BeckyD @ James Martin Chevy
Old 09-04-2009, 08:48 PM   #1
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Cheap Mobil1 XP
just a FYI....
Advanced Auto Parts is selling 5 quarts of Mobil1 synthetic and a Mobil1 filter for $29.99... even the "extended performance" stuff that usually sells for $8/qt.
http://advanceauto.shoplocal.com/adv...nceAuto-090827
thats ~$53 worth of Mobil1 for $30
But Wait!!!!
...........if you act now.....
you get a $10 mail in rebate...
https://www.mobiloil.com/USA-English...llustrated.pdf
so thats $53 worth for $20
I just bought 15qts and 3filters for $60... (it was $160 before the cashier entered the promotion)
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 09-05-2009, 03:42 PM   #2
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
Wow! Excellent find! Thanks for sharing.
Order date: 7/17/09
3000 TPW: 8/17/09
3400 status on 8/11/09
3800: 8/21/09
4200: 8/24/09 on rail car ETTX850796
5000/6000: 9/2/09
crzycicada is offline   Reply With Quote
Old 09-06-2009, 02:41 PM   #3
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
iwent and got some yesterday but they said that it was for only the regular mobile 1 wich is still a good deal i got 15 quarts and three filters for 95$ i took back the 10 quarts and one filter i bought from autozone for 87 ucks
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 09-06-2009, 03:58 PM   #4
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
I concur. I picked up 10 quarts and 2 M1-113 oil filters today and it's only for the regular M1, not the EP. I also picked up their 3 ton floor jacks for $30 too. So I spent the same amount as you! Good deals I think...
Just remember everyone, the sale is through the 30th so stock up! Note the mail-in rebate is only for M1 EP.
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 09-06-2009, 07:03 PM   #5
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
It gets better. Save $10 off your purchase of $25 or more by entering their contest!
http://advancegrandopenings.com/
This plus the special plus the mail-in rebate (if buying EP)...you might be making money!
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 09-06-2009, 09:31 PM   #6
Yellojacket
Yellojacket's Avatar
Drives: 2SS/RS Inferno Orange
What is the mobile 1 filter # for the LS3 engine? I may pick some up while the sale is still on.
Yellojacket is offline   Reply With Quote
Old 09-07-2009, 08:15 PM   #7
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
The store should be able to tell you but if I remember correctly, it's M1-113.
In the long run you're probably only saving maybe $5-8 not including the mail-in rebate. I say this because the regular price for a 5 quart jug of regular M1 at Walmart is $22. Add the price of the oil filter (I haven't bought one at regular price so I'm guessing ~$15.00) so you're saving just a couple bucks. Of course this is better than nothing! I just point this out in case someone misses the sale.
Note: I found a mail-in rebate form via Google for regular M1. It's a $10 rebate if you buy 6 quarts of M1. This one can be used in conjunction with the above stated sale since they are both for regular M1.
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 09-08-2009, 03:20 PM   #8
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
I just used this coupon today. It came out to be $21.59 after taxes for 5 quarts of M1 and an oil filter. Awesome deal!!
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 09-08-2009, 03:27 PM   #9
Bell040
Bell040's Avatar
tell them to try and ring up the EP...
They told me it would not work, but then they rang it up and it worked after all.
Ordered: 10-13-08
Recieved: 6-12-09
Old 09-11-2009, 10:57 PM   #10
bluedevil02
bluedevil02's Avatar
Drives: 2LT/RS
thanks for the info guys i went and picked up 10 quarts and 2 mobil-1 filters ($12.99) all for $50 and some change, plus i have 2 gift cards on the way, so pretty much two oil changes for the camaro for $30 bucks
bluedevil02 is offline   Reply With Quote
Old 09-11-2009, 11:17 PM   #11
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
Please correct me if I'm wrong but from what i know and confirmed with Mobil 1 this past Wednesday , they do not have an oil filter out yet for the V6Camaro . I have done three oil changes with Dino oil on my 2LT already ( I get free oil changes from my Dealership) , one @ 1000 mi. , the other @ 2000 mi and the previous one @ 2500 mi. which is when i switched over to Mobil 1 and have been using the AC Delco PF-2129 (which is what is called for the V6Camaro)for all three changes .. Plus the V6 takes only 6 qts. so if your thinking of doing TWO oil changes in the near future , you are going to be short two quarts , one short for each oil change or at least two on the 2nd change.. If i was you i would pick up two more qts. and the right oil filter if the Mobil 1 filter is wrong to cover yourself for both.
Can you please give me the Mobil 1 oil filter part# you picked up for your LT/Camaro ?
Thanks..
fee5fofum is offline   Reply With Quote
Old 09-11-2009, 11:26 PM   #12
bluedevil02
Drives: 2LT/RS
Originally Posted by fee5fofum View Post
Please correct me if I'm wrong but from what i know and confirmed with Mobil 1 this past Wednesday , they do not have an oil filter out yet for the V6 .
Can you please give me the Mobil 1 filter part# you picked up for your LT/Camaro ?
Thanks..
nah , you're right brotha its still not out or the mobil-1 one at least, i do believe K&n has one out, but i just grabbed a $12.99 mobil-1 filter and they said its cool that i can go back and exchange it for the camaro one, when its released..
Old 09-12-2009, 12:04 AM   #13
fee5fofum
fee5fofum's Avatar
Any time you can get a sale like that , go for it and worry about the filter later (if they do not have the right filter for the car) when you need too and then swap it out.
I do the same thing when oil/filter bundles are on sale . I buy enough for at least 2-3 oil/filter changes..
Check my post again i just added more information i think you should know about ..
Owners Manual section 11-2
Engine Oil w/ Filter
3.6L V6 Engine : 6-qts
6.2L V8 Engine : 8-qts
(L99 & LS3)
V6 : SAE 5w-30 GM6094M
Do Not use 10w-40, 20w-50 or any other viscosity grade oil not recommended
V8 : SAE 5w-30 / GM4718M (L99 & LS3) Mobil 1 is Factory fill ..
Do Not use 10w-40,20w-50 or any other viscosity grade oil not recommended
AC-Delco PF-2129 is the right oil filter for the V6 .
Here's the best place to find any part for your 2010 Camaro:
http://www.rockauto.com/catalog/shoppingcart.php
Also if you want to cross reference this with others like the K&N HP-7003 and others , here is the chart to confirm that the PF-2129 is the right filter for the V6:
http://www.knfilters.com/search/kn_c...x?part=HP-7003
Hope this helps ...
Old 09-12-2009, 12:08 AM   #14
bluedevil02
Drives: 2LT/RS
cool man appreciate the info i wasn't sure if it took 5 or 6, looks like i'll go pick up a couple more...and yea advanced showed the part in their system, just weren't stocking it yet from what i understood..
